No beep when locking (but lights flash)
Discussion in '2.5 Gen Tundras (2014-2021)' started by jimmyfu, Mar 10, 2022.
  1. Mar 10, 2022 at 1:33 PM
    jimmyfu
    jimmyfu [OP] New Member
    N. California
    2014 Tundra DC SR
    I've tried looking through the forums already, but haven't find any with a situation just like mine. As the title states, I'm not getting the two tone beep when I lock the car with the remote anymore. I don't think it's an issue with the actuators, as my lights still flash either once or twice depending if I'm unlocking or locking the car. I've replaced the little speaker under the hood, and I've checked the wire harness as best I can to see if a rat chewed it, but still no luck in figuring out what's the issue. Is there a fuse or some kind of setting I should check somewhere? Would rather not go to the dealer to troubleshoot this issue if I don't need to. thanks!
  2. Mar 10, 2022 at 1:59 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    What is year and trim of truck? You are using the stock fob or aftermarket? Is there any aftermarket remote start or LED lights anywhere in the truck? Does everything work as expected except the beep sound?
  3. Mar 10, 2022 at 2:01 PM
    jimmyfu
    N. California
    2014 Tundra DC SR
    Sorry, it's a 2014 Tundra DC SR. I'm using the stock fob, haven't touched the alarm system at all. I do have LED lights in the bed for bed lighting, and everything works as expected except for the beep sound. I did upgrade the HU and thought that may have been the issue, but when I put back in the original HU I still was facing the same issue.
  4. Mar 10, 2022 at 2:11 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Download Carista for a 30 day trial and see if you can toggle the settings on/off...I "customized" my HVAC for when the truck first turns on...I also removed my seat belt chime...within there, one can augmentation those settings and more versus your center cluster screen settings options...merely a suggestion...I used the app for no more than 20 min and than canceled for no cost...does thing that torque cannot and vise versa...
  5. Mar 10, 2022 at 9:26 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Mine did that when when door lock actuator went bad. After you lock it, check all 4 doors to make sure they locked.
    ZappBrannigan likes this.
  6. Mar 10, 2022 at 10:42 PM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    I would recheck the HU and if checks out ok maybe check to see if a dealer can check if its turned on. Does your panic button still sound the horn?
  7. Mar 11, 2022 at 9:59 AM
    The head unit may be what controls the beeping sound. In the 2019, I can adjust the beep volume from off to obnoxious with several steps in between.
  8. Mar 11, 2022 at 10:42 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    I agree I did the same to turn off seatbelt chime
    HulkSmurf14[QUOTED] likes this.
  9. Mar 11, 2022 at 6:15 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    One time, after I had the door panel off, I forgot to hook the cables back into their slots when I put the panel back on.
    For days, I got no beep when I went to lock the truck. I checked every door to make sure it was closed. I finally figured I’d just live with it.
    Days later, I had to sit in the passenger seat for some reason, and when I tried to exit the vehicle, the door would not open.
    THEN I remembered… I hadn’t hooked the cables back up. I did so and immediately the beep came back and I could hear more clatter of doors locking.
    If you’ve done recent work that required the panels to come off, you’ve already stopped reading and are going to hook your cables back up.
  10. Mar 11, 2022 at 6:27 PM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    ‘24 Platinum MGM
    I noticed my dads 2019 DC Limited does the same (no lock sound when locking). Would love to solve that for him.
  11. Mar 11, 2022 at 8:32 PM
    AggiePhil
    College Station, TX
    This is the stupid little beeper speaker. Be glad yours doesn’t work, it drove me crazy so I ripped it out. It’s located just inside the front drivers wheel well, behind the headlight.
    biebs96 likes this.
  12. Aug 16, 2023 at 3:48 PM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    I wonder if this issue was ever resolved. My truck just did the same thing all of a sudden. When I go into the Entune settings on the stock headunit to look for the beep volume, it doesn't exist as an option where it's supposed to.
    Lights flash and all doors lock and unlock properly. However, my door lock speaker doesn't beep at all unlock/lock/lock with door ajar.
  13. Aug 16, 2023 at 3:50 PM
    AggiePhil
    College Station, TX
    Consider yourself lucky! lol
    HulkSmurf14 likes this.
  14. Aug 16, 2023 at 3:52 PM
    drpheta
    drpheta New Member
    I actually like the audible notification. My kids sometimes don't close the door all the way, so I like to hear the long beep when they don't.
  15. Aug 16, 2023 at 4:00 PM
    AggiePhil
    College Station, TX
    Yeah. Mine was just beeping all the rest of the time, for other things. Any time I’d stop the truck and open a door, shit would start beeping like crazy.
  16. Aug 16, 2023 at 4:16 PM
    Mine started an issue where the lights don't flash when you unlock it. You have to do it a couple of times for the lights to flash.
  17. Aug 16, 2023 at 4:57 PM
    HulkSmurf14
    2014 Tundra Limited
    Battery in remotes need changed...it happens a lot on my German cars...new battery in the remote and all is solved for some reason
  18. Aug 16, 2023 at 5:42 PM
    drpheta
    drpheta New Member
    Just tried that, and it didn't work. Also doesn't make sense that the remote battery is related to the car triggering the lock speaker.
  19. Aug 16, 2023 at 5:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Hahaha I agree, makes no sense on why it coupd be the remote power...but German cars make no sense electrically sometimes so my suggestion was poor at best. I'm glad we don't have German trucks...
  20. Aug 22, 2023 at 4:06 PM
    jimmyfu
    N. California
    2014 Tundra DC SR
    I ended up fixing it with Carista. Not sure how it got shut off in the first place. Maybe it was somehow through my Chinesium Android radio install? No clue, but could never find it in the menus of the new radio. Carista option solved it
  21. Aug 23, 2023 at 6:43 PM
    drpheta
    drpheta New Member
    So the option wasn't available on the stock headunit settings menu, but carista was able to reenable it?
    My issue is there is no option to adjust the beep volume within the stock headunit, so I have no way of reactivating it. I don't know what happened for it to disable and disappear from the settings menus.
  22. Aug 23, 2023 at 6:46 PM
    drpheta
    drpheta New Member
    My doors all lock fine.
  23. Aug 27, 2023 at 5:20 PM
    drpheta
    drpheta New Member
    Couldn't find the setting in my Autel scanner to program the beep, so I just bit the bullet for the Carista. I have no idea why the setting was disabled randomly, but it's working now.
    *shrug*
  24. Aug 27, 2023 at 5:37 PM
    SAGE63
    San Diego County
    Interesting my 21 never has beeped...just blink the lights... never really thought about it
  25. Aug 28, 2023 at 7:08 PM
    ZZTheNinja
    ZZTheNinja New Member
    Zach
    2018 Tundra Limited Pearl Blue
    My tundra has the same issue. The dealer said they were going to try to install a new speaker for $290 (on mine it was so faint you had to put your ear to the headlight) or replace the $1100 unit that controls it. I said forget it
  26. Aug 28, 2023 at 7:11 PM
    drpheta
    drpheta New Member
    You can get a replacement speaker online for $60 (used). Depending on the part number, I may have one as I purchased one to see if that was the issue.
    ZZTheNinja[QUOTED] likes this.
  27. Aug 28, 2023 at 7:13 PM
    ZZTheNinja
    Zach
    Good to know! I am a novice I’ve never had a Toyota. Can you help me out?! Where would I find it? I have a 2018 Toyota Limited
    also I have the stock head unit and mine has the setting but mine is set to loud and on
  28. Aug 28, 2023 at 7:49 PM
    drpheta
    drpheta New Member
    Worth a shot to replace the speaker. Remove the bumper grill, then reach behind the driver's headlight and you'll see the speaker. It's just slightly bigger than the keyfob. One example is posted above on this thread.
