Bump stops
Discussion in 'Suspension' started by Badge618, Aug 21, 2023.
  1. Aug 21, 2023 at 1:48 PM
    Badge618
    Badge618 [OP] New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    Going to be removing the lift block in the rear and wondering if it's worth it to change out the bump stops to some nicer ones while I have it apart and putting in new u-bolts.
  2. Aug 21, 2023 at 1:59 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    U-bolts are supposed to be one-time use, so installing new bumpstops while they're already off and being replaced helps so you don't have to buy u-bolts twice.
    Depends on your use case how much they'll benefit you though. From my experience, aftermarket bumps like Timbrens are not near as jarring as the OEM bumpstops. I was hitting the bumps often before repairing my leaf springs, so I found them useful.
    If you don't mind spending the cash and don't plan on installing airbags, I'd do 'em.
  3. Aug 21, 2023 at 2:07 PM
    2mchfun
    I'd do Sumo springs and if you off road much get a second set that you can cut down and rotate into position to gain articulation when you go wheeling. Certainly helps keep away the sag when the truck gets loaded up with cargo.
    des2mtn likes this.
  4. Aug 21, 2023 at 2:11 PM
    Badge618
    Lassen County, Ca
    I think I will go ahead and replace them with the Wheelers superbumps. No air bags in the future, probably road master.
    2mchfun likes this.
  5. Aug 26, 2023 at 1:01 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    What’s the budget? I’ve always hated hitting the bump stops, but recently went with hydraulic bumps. You want smooth control with no jarring? That’s the ticket…
  6. Aug 26, 2023 at 9:11 PM
    Badge618
    Lassen County, Ca
    I wouldn't mind going hydraulic but I don't think I need that extreme. I was only looking to change because I will be removing rear lift block and installing new u-bolts.
  7. Aug 27, 2023 at 12:27 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    If you shop around a bit, you can find pricing much lower than MSRP.
    https://jeepandtruckparts.com/products/icon-2007-toyota-tundra-rear-hyd-bump-stop-kit
    Of all places, I found and ordered mine on Walmart.com. There is a zero.zero percent chance that Walmart sells Icon bumps at a store, but some algorithm must have told them to buy and sell some online. My assumption is they didn’t sell fast so they chopped the price. I think I paid a shade over $700 shipped. They arrived in a couple days, still factory sealed in an Icon box. Saved about $250.
