  1. Aug 26, 2023 at 9:29 PM
    AthenaOffroad
    AthenaOffroad YouTube wannabe
    Niko
    2014 Blue Ribbon Metallic Tundra DC SR5
    I think it looks great!
    Dooders[QUOTED] and J&ATundra like this.
  2. Aug 26, 2023 at 10:21 PM
    AggiePhil
    College Station, TX
    I love the look of these (in black). Reminds me of the 3rd Gen wheels. But the 18mm offset has me on the fence. Factory is 60mm, which means these wheels will stick out 1.65” further than factory. Don’t really like the sound of that. Thoughts?
  3. Aug 27, 2023 at 12:16 AM
    MountainMan
    MountainMan New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    Finally installed the Tyger fender flares. Not a fan of the smooth finish or the stainless bolts, but too busy these days to address them. Was ten minutes late for a birthday party as it was.
    But, the install was easy and smooth. My tires are just barely covered, but that is about perfect. Too wide of flares and skinny tires looks silly, IMHO.
    Before:
    After:
  4. Aug 27, 2023 at 1:41 AM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    :thumbsup:
    Dooders[QUOTED] likes this.
  5. Aug 27, 2023 at 6:00 AM
    Hogansheroes
    Hogansheroes New Member
    Josh
    Northern Wisconsin
    2019 Tundra CM TRD Sport
    Installed Sony xav 9500es.
  6. Aug 27, 2023 at 7:29 AM
    sofaking
    sofaking New Member
    Karl
    2021 Toyota Tundra SR5
    Awsome thanks for the info and the future help! Also I see you are in Big Bear I'm in Fullerton (Orange County)
  7. Aug 27, 2023 at 7:32 AM
    AthenaOffroad
    Niko
    What does that look like from the side? like what's behind it, just curious
    AggiePhil likes this.
  8. Aug 27, 2023 at 8:15 AM
    centex
    centex New Member
    9.5qts of fresh 0-20 and a metal oil filter cap.
    bulldog93 likes this.
  9. Aug 27, 2023 at 8:21 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Hopefully you meant 8.5?
  10. Aug 27, 2023 at 8:24 AM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    RCI plates fully installed.
    Also replaced my rear windows, since the bottom brackets that are glued to them rusted out so badly that the rear driver's window bracket fell off (thank goodness the window didn't break).
  11. Aug 27, 2023 at 8:40 AM
    centex
    centex New Member
    Nope. Started at 8.5 and didn’t measure on the dipstick. Ended up adding another qt to get it to register. Did 9qts last oil change.
  12. Aug 27, 2023 at 8:51 AM
    Hogansheroes
    Josh
    Northern Wisconsin
  13. Aug 27, 2023 at 9:04 AM
    coTony
    Tony
    Montrose, CO
    Just an FYI, after putting the guards on I had a lot of squeaking. After removing the skids and seeing the rub marks on the hardware and guards I trimmed the guards and no more squeaking
  14. Aug 27, 2023 at 9:26 AM
    drpheta
    drpheta New Member
    Thanks for the heads up. I'll keep an ear out for any squeaking.
  15. Aug 27, 2023 at 9:50 AM
    AthenaOffroad
    Niko
    That doesnt look near as bad as i thought it was going to. I like the stock Head Unit but i kinda like that too. be nice to have an updated head unit. Looks good man!
    Hogansheroes[QUOTED] likes this.
  16. Aug 27, 2023 at 11:00 AM
    Hogansheroes
    Josh
    Northern Wisconsin
    Thanks! I was on the fence too, but glad I went this route instead of a flush mount one.
    AthenaOffroad[QUOTED] likes this.
  17. Aug 27, 2023 at 2:05 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    Working on a few small projects. Rago dash plate, Bulletpoint MagSafe charger (which required adding a quick-charge USB port), and front cam. Had a pretty good day considering mobility and stamina are WAY down because of a back injury - 3 herniated disks and a compressed nerve root. And feet that are extremely swollen and painful from a combination of an abnormal gait (I have to use a walker to get around) and several medications that cause swelling of the feet and ankles.
    Got to the point where I just have to run the wiring for the front cam and button it up. And possibly re-flash the Maestro because the button I programmed for the front cam doesn’t seem to be working. Kind of makes me wish I had gotten the Bluetooth Maestro.
  18. Aug 27, 2023 at 2:29 PM
    Quicksand_Tundra
    Quicksand_Tundra New Member
    Jon
    2019 Quicksand Tundra CM 4x4
    -Color keyed grill & bumper -Diode Dynamic SAE LED Foglights -Headlight Revolution LED Light upgrade -SCS SR8 18x9 with 295/70/18 Toyo Open Country AT3 -Go Rhino Dominator D6 Steps -TRD OEM Intake & Dual exhaust -Bilstein 6112 front and 5160 in rear -JL Audio C2 6.5" speakers upgrade powered by JL Audio RD 400/4 amp -Pair of AudioFrog GS25 speakers front dash -10” Kicker Hideaway subwoofer under driver seat -All doors covered with Soundskins deadening mat (inside/outside) -Front window tinted at 35% -Paint protection film full front -30” Rigid Industries SAE light bar -Body Mount Chop -Diode Dynamics SS2 (red) setup for brake light & turn signal -Katzskin Custom leather upgrade (Black/Bamboo) -Amber led running lights (Hood bulge) -AJT Design: Black vent rings, steering wheel trim, shift gate trim, emblem overlay -AJT Design: Quicksand door handle cover -Carbon fiber wrap (silver part on door panel) -Air Design tailgate applique (Line-X in smooth gloss finish) -Air Design tailgate spoiler (Line-X in smooth gloss finish) -Smittybilt beaver step (Line-X) -Valhalla Cat Shield (Line-X) -Coachbuilder Shackles kit +2 -Coachbuilder Strut/Coilover shim (0.5" for driver side) -Sumosprings (rear bumpstop) -Meso Custom Led front and rear cab lights -Teton shop shift knob -TRD Seat belt shoulder pad -Husky floor liner front/back -LED courtesy door/step light -LED bed light kit w/ outside switch
    Finally installed the rear step. There goes the TRAIL badge. Like or dislike it, I think it matches the color of the truck.
    Does not interfere with the TRD dual exhaust.
    Decided to cut out the stock frame, instead of replacing it with the flimsy one provided. Since this part is discontinued by Toyota, I bought this one off of eBay for $100. Off brand, and it actually works and fits perfect.
    Tundra-XP, bulldog93, TreeCat and 8 others like this.
  19. Aug 27, 2023 at 5:40 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Currently waiting on parts. Gas lid randomly fell off, I like the black on tan and it fits the theme of my truck so I ordered a replacement from a black truck lol should be here soon. Also backed into a tree. I’ve been having an existential crisis over getting aftermarket tails or not. I had hiRev on my 21, I’ve seen some of you guys have horror stories with the Morimoto tails, and I cannot get myself to like alpharex’ offerings. There are some stunning ones I saw here but they are $800 - valentis, I can’t get myself to pull the trigger on those though https://valentiusa.com/shop/ultra-led-tail-light-for-tundra/
  20. Aug 27, 2023 at 5:57 PM
    biebs96
    PA
    after my lift and larger tires two years ago, I really think my 5’6” self needs one of these more and more..
  21. Aug 27, 2023 at 6:41 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Anyone have their tundra tuned? Had KDMAX on my Tacoma. Loved it. I’ve heard a few good things. Seeing if anyone has experience.
  22. Aug 27, 2023 at 8:57 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Pulled out the JBL DSP4086 amp today in preparation for my Alpine HU install (going to install it with factory setup first while I figure out my longer term plan). Managed to clip my front camera cable with the wire cutters while cutting off zip ties for the amp power wire.
    :facepalm::annoyed:
    So, looks like I'll be rewiring my front camera when I do the radio install...
  23. Aug 27, 2023 at 9:06 PM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    The +18 offset had me going back and forth, would’ve preferred a +25 but this is close. Been on the fence of going to dirty sevens which this offset would better handle but I was just scared about needing to regear to 5.29s so I held off to 35s for now. I’ve got some BMC plates coming so I can get some of the prep work done for 37s when the time finally comes around.
    AggiePhil[QUOTED] and ATV25 like this.
  24. Aug 28, 2023 at 2:16 AM
    Bergy24
    Bergy24 New Member
    For anyone that has cat plates on and the TRD front plate. Mine were creaking and popping and making noises when turning and going slow. My 21 Sounded like an old truck with worn out suspension. I was going to wait until the weather cooled off but decided to tackle it today. With all the plates installed, I used a sharpie to Mark the plates overlap. Then I removed all the plates except the TRD plate. I used some rubber roof scraps I had left over and glued them to the plates where they overlap. Any metal to metal now has rubber on it (including where it contracts the frame) I Put all the plates back on, and took it for a test drive, and All the noises are gone. Hopefully it won’t start to squeak now that there’s rubber on it. Stock suspension and sitting flat on the ground made it challenging but it wasn’t impossible. I will be investing in a TRD nut plate to make it easier when I need to take them off and on again.
    I hope this helps anyone that has the same issue.
  25. Aug 28, 2023 at 2:36 AM
    drpheta
    drpheta New Member
    My RCI came with a similar plate, and it makes install so much easier. Highly recommend the TRD nut plate or similar.
    Bergy24[QUOTED] likes this.
  26. Aug 28, 2023 at 6:40 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Nightmare fuel right there. I swear every time I rebuild my PC and cut old zip ties I think "this will be the time..."
  27. Aug 28, 2023 at 7:03 AM
    rockR67
    rockR67 New Member
    Northern Louisiana
    2018 Cement SR5 (sold)
    a few other things standing in ... for now.
    I've thought about the step for quite a while, never done it. Do you find the step a good add? It does fit right in, looks good.
  28. Aug 28, 2023 at 7:45 AM
    DowntownApexTundra
    DowntownApexTundra New Member
    2021 DC SR5 4x4 Sport
    3/2 leveling lift kit, pocket style fender flares (best super white color match you'll ever see - painted by my uncle), 1.5" wheel spacers, S&B CAI, TRD Pro headlights, 18" knockoff Ebay TRD Pro Wheels, wildpeak at3w 275/65R18 116t (32/11), gator roll-up tonneau, blacked out interior by AJT and others, pedal commander, blacked out exterior badges, LED everything, RCI neoprene water proof seat covers (removed back middle seat back material to make it work), weather tech floormats, flowmaster flowfx extreme 3.0 exhaust
    Did not get to everything. Work in progress. Tires, rims, 3/2 leveling lift kit install this coming Wednesday. Interior trim replacement will take a while.
    The LED replacement kit was surprisingly one of my favorite upgrades. Factory cabin lights are not bright enough to find dropped items in the dark, and the license plate lights and rear center brake light clear lights were not bright enough for the backup camera in the dark. Prior to this upgrade I wrongly assumed that the camera was just flip phone resolution. Now the quality is similar to a smart phones.
  29. Aug 28, 2023 at 7:47 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I thought it was a 3 qt spread from low to high on the dipstick, can someone confirm?
    HulkSmurf14 likes this.
  30. Aug 28, 2023 at 7:48 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I thought it was a 1qt difference universally on all manufacturers?
