Ball Joints.... Again
Discussion in '1st Gen Tundras (2000-2006)' started by Meaux, Aug 25, 2023.
  1. Aug 25, 2023 at 10:44 PM
    Meaux
    Meaux [OP] New Member
    Louisiana
    Time to replace the ball joints, 158K on the 05. I've been reading about how great this or that one is only to see them end up getting trashed elsewhere. So here's three I'm looking OEM, XRF and Sankei 555. The Sankei 555 you can service, the others are sealed. The XRF is supposedly built stronger, hence better and the OEM is supposed to be the best. Opinions anyone??
  2. Aug 25, 2023 at 10:52 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
  3. Aug 25, 2023 at 11:10 PM
    208Tyler
    208Tyler New Member
    Tyler
    Silver 2001 AC 4x4 V8
    Stock
  4. Aug 25, 2023 at 11:40 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    My OEMs always go at least 100k before I decide to replace them, lots of off-roading rough driving and zero issues...confidence is what they deliver.
  5. Aug 26, 2023 at 12:01 AM
    Meaux
    Louisiana
    Thanks looks like OEM...
  6. Aug 26, 2023 at 8:00 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
  7. Aug 26, 2023 at 8:15 AM
    GreenMachineDream
    GreenMachineDream New Member
    West Central, OH
    2002 Tundra SR5, 4WD, RCLB, Metallic Green
    Just did my ball joints and control arms. OEM all the way on critical parts brother!
    Adventundra likes this.
  8. Aug 26, 2023 at 8:39 AM
  9. Aug 26, 2023 at 9:01 AM
    Meaux
    Louisiana
    Thanks to all, finally watched the youtube vid... Oh yea 100% OEM, have them in a shopping cart at McGeorge's
    unless someone knows a cheaper place?? So far it's right at 3 c-notes(new bolts included) and I just drop some
    coin for strut kits, Monroe from RockAuto... Looking for the struts led me to the ball joint issue...
    Go figure it's only money.... Thanks again to everyone!!
  10. Aug 26, 2023 at 9:12 AM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Should have asked about the struts as well.
  11. Aug 26, 2023 at 9:16 AM
    Meaux
    Louisiana
    Live and learn..
  12. Aug 26, 2023 at 10:02 AM
    Yeah, Monroe is absolute garbage. Good on other stuff, shit on our trucks. Very squishy.
  13. Aug 26, 2023 at 10:19 AM
    Yup, that's the major complaint: Soft and sloppy. KYB is OEM quality and about the same price, at least last I checked. Bilstein 4600 is equivalent to the OEM TRD/Offroad setup.
    At least he didn't order Rough Country or Rancho. Could be worse.
    bmf4069[QUOTED] likes this.
  14. Aug 26, 2023 at 10:23 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    RIP Bob Barker
    Adventundra and bmf4069 like this.
  15. Aug 26, 2023 at 10:38 AM
    Adventundra
    Adventundra New Member
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    I have an annoying that this bolt that has a washer on it for alignments…is this the area of the control arm? And is it hard job to replace this squeaky bolt?
  16. Aug 26, 2023 at 10:56 AM
    That's one of your cam bolts, it holds your lower control arm (LCA) on. It shouldn't be squeaking necessarily, are you sure your lower control arm bushings aren't shot?
    Whatever you do, DO NOT recommend to replace it with aftermarket. You'll regret it. Others have in order to save $$ (the OEM part is pricy), apparently all the aftermarket cam bolts come with plastic sleeves that disintegrate/crush.
    Adventundra[QUOTED] likes this.
  17. Aug 26, 2023 at 11:47 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Gotchya! Thanks! We had it on my pals lift and he said the squeak was coming from that bolt…he said there is a bushing that the bolt goes thru that is probably the culprit.
  18. Aug 26, 2023 at 11:58 AM
    GreenMachineDream
    West Central, OH
    I strongly recommend replacing your UCAs and LCAs when you do the ball joints. As @shifty` said make sure your cam bolts, sleeves and toes are all OEM. I got 192k outta mine so I'm expecting the same.
  19. Aug 26, 2023 at 12:05 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Gotchya! Didn’t plan on putting much $ into since I’m looking to upgrade into a newer long bed…..but I cannot stand the squeak anymore!! Any ideas how much all that front end work would cost?
  20. Aug 26, 2023 at 12:16 PM
    It's more of a "tube" than what I'd call it a "bushing". But sometimes the terminology I use doesn't jibe with others' preferences.
    I'm just trying to figure out what would squeak in there. Maybe you've got some rust built up inside and the squeak is just that? I'd check the bolt and bushings, in case your LCA bushings are shot, and that's the source.
  21. Aug 26, 2023 at 12:23 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    If the rubber bushing is bad enough, the arm itself can be off center far enough that the metal of the arm can rub against the frame, inside where it's mounted.
    Easy enough to spray with lubricant and see if noise temporarily goes away.
    The bolt goes through a sleeve or tube as @shifty` said, so it's not gonna be the bolt. Although the sleeve and inner bushing could make noise too. Usually not though, as it's clamped when the bolt is tight.
    shifty`[QUOTED] and Adventundra like this.
  22. Aug 26, 2023 at 12:46 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    I been douching it out w blaster n lithium spray w minimal effectiveness….but that’s only from crawling down there n not on a lift.
  23. Aug 26, 2023 at 1:40 PM
    GreenMachineDream
    West Central, OH
    If you go OEM (a must for LBJs and highly recommended for all else mentioned) you're roughly looking somewhere between $1200 - $1300 for parts alone. Don't know how much it'd cost to take to a shop or dealer.
  24. Aug 26, 2023 at 1:46 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Thanks!!
  25. Aug 26, 2023 at 2:08 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Have you removed the sway bar end link (temporarily) to eliminate it as a possibility?
    shifty` and Adventundra[QUOTED] like this.
  26. Aug 26, 2023 at 2:10 PM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Na. Haven’t gotten that far yet. I think Tuesday I will be able to get it on my pals lift again.
  27. Aug 27, 2023 at 6:19 AM
    Mr Badwrench and BubbaW like this.
  28. Aug 27, 2023 at 7:12 AM
    Adventundra
    NJ
    2016 SR5 Long Bed
    Cap and bed slide
    Come on down!!!!!!
  29. Aug 27, 2023 at 7:55 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    OEM... Preventive maintenance is better than repair. :(
    jerryallday, 208Tyler and Adventundra like this.
