Need help ASAP: Cannot reinstall strut assembly after pro-comp strut lift?
Discussion in 'Suspension' started by Teriks, Aug 19, 2017.
  1. Aug 19, 2017 at 3:44 PM
    Teriks
    Teriks [OP] New Member
    Tom
    Front Range, CO
    2008 Toyota Tundra Limited DC 4x4 5.7
    I am in the middle of working on installing a 2.5" ProComp level which is just a lift achieved by adding a "spacer" onto the top of the strut assembly. The directions make absolutely no mention of any trouble getting this back in, and I can't find anything in any of the guides on google. I'm stuck trying to get the lower strut bolt in; it will not line up at all. If I force the lower control arm down more, it makes no difference as the coil spring hits the truck, and if I get the strut in the bolt area (like my pics show) pushing the lower control arm up does allow the coil spring to clear the truck, but with the pressure on the strut, it makes it impossible to start the bolt. I've already completely removed the front sway bar as it was hitting the strut before, but I cannot figure out how to get this lower bolt in for the life of me. Any tips?
  2. Aug 19, 2017 at 3:57 PM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    unbolt the spindle from the upper control arm?
    EDIT... oh nm, I see that you separated the spindle from the lower control arm.
    maybe you are going to have to compress the spring a little?
  3. Aug 19, 2017 at 4:00 PM
    Teriks
    Tom
    Front Range, CO
    As far as I can tell, the UCA is a non-issue. I removed the lower knuckle bolts as seen in picture 1, so I can move that entire rotor/UCA as needed. However, it's not impacting anything as is - it's purely the lower half of the coil spring and the lower control arm not being "out" far enough.
  4. Aug 19, 2017 at 4:53 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Looks like double stacked lifts to me...
    Current shocks look like Rancho which provide 2.5" IIRC
    I'm probably missing something here
    mdavis likes this.
  5. Aug 19, 2017 at 5:04 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Had same prob installing struts on my lifted truck. I had to:
    Lower the LCA
    Compress coils and while compressed, force back into position
    Once in position, decompress coils.
    Try that and be careful.
  6. Aug 19, 2017 at 5:11 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    The OP (IMO from looking at the pics)....is effectively trying to shove a 5" lift "coil over" assembly into a factory position...that's what I feel is wrong. It ain't going to work on so many different levels.
    Marco, Brown Bear and Sefferston like this.
  7. Aug 19, 2017 at 5:14 PM
    Les7311
    ....... but if he compresses the spring and the measurements shows space to fit, then some knuckle and elbow grease, plus a long pry bar to force in should work.
    I guess.....
    Achuop likes this.
  8. Aug 19, 2017 at 5:17 PM
    14burrito
    2014 SR5 CM 4x4 5.7
  9. Aug 19, 2017 at 6:00 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Ok, while I don't agree with installing "stacked" lifts...this *might* solve your issue.
    Grind the lower pocket back in the lower control arm and it should work. Google Fox extended travel coilovers lca grinding. The stem Fox uses is so large in diameter it contacts the lower control arm when the suspension is fully extended. This might help.
  10. Aug 19, 2017 at 7:26 PM
    Teriks
    Tom
    Front Range, CO
    There is only one lift here, and it's the procomp portion added to top of strut assembly. The strut itself is a Rancho RS9000xl, which is stock height with adjustable stiffening settings.
    I got the driver side in by shoving a pry bar on the outside off the lower strut eye and the LCA, then jacking the LCA up a bit till I could get the bolt in, but the passenger side is not playing as nice.
    Les7311 likes this.
  11. Aug 19, 2017 at 7:31 PM
    Les7311
    Yup. We had to use a pry bar same. Then muscle the strut in.
    Did you loosen all the LCA components.....?
    ColoradoTJ likes this.
  12. Aug 19, 2017 at 7:42 PM
    This. You have to loosen the alignment cam bolts. If it doesn't swing down, your not loose enough. After the Coilover is installed, loosen the upper control arm nut and let the truck come to a rest on its own weight and re-torque it down.
    CM-LENNY, MotoTundra and Teriks[OP] like this.
  13. Aug 19, 2017 at 8:05 PM
    Teriks
    Tom
    Front Range, CO
    Well, I've got the passenger side strut assembly all in...but now it's the dang LCA knuckle bolts being a pain. One thing after another, and now it's dark and the mosquitos are tearing me up! =( I'm determined to get it in, even if this stupid project takes all night, ha.
    On the plus side, the finished driver side looks a hell lot better than stock! :thumbsup:
    Black Wolf and ColoradoTJ like this.
  14. Aug 19, 2017 at 8:13 PM
    You live in CO and didn't do a shock party?
  15. Aug 19, 2017 at 8:16 PM
    Les7311
    Take a break. Regroup. Then go at it later.
    That could be as soon as you wipe some orange peel over to rid them 'skitoes
    Teriks[OP] and MotoTundra like this.
  16. Aug 19, 2017 at 8:19 PM
    Teriks
    Tom
    Front Range, CO
    Yeah =(. I thought I'd knock it out in a few hours, since I did all four struts/shocks a couple months ago. Here I sit, 9 hours later....
    I'll call it a "lesson learned" :frusty:
  17. Aug 19, 2017 at 11:23 PM
    Teriks
    Tom
    Front Range, CO
    Finally done after probably 10.5 hours of work. I'll need that alignment ASAP since I know at least one side is waaaay off, but it looks much better already. I might have to lift the rear up 1" though, as the front is a tiny bit higher than the rear (which I hate).
    Thanks for all the replys, everyone.
  18. Aug 20, 2017 at 5:58 AM
    ToyTec shackles will take care of that.
    ColoradoTJ and Cfincke like this.
  19. Aug 20, 2017 at 1:25 PM
    Theyfzman
    Theyfzman New Member
    Pa
    08 TRD
    I have a barley used set of toytec shackles I'll sell pretty cheap. If your interested
  20. Aug 20, 2017 at 1:30 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Tundra's don't use struts
  21. Aug 20, 2017 at 1:47 PM
    Teriks
    Tom
    Front Range, CO
    Yes, but consistently using "coil-over" when the commonly used noun is "strut" gets to be a bit pendantic
  22. Aug 20, 2017 at 1:53 PM
    dandailey
    Dan D
    Newport News Va.
    This is a strut.
    If coilover is too pedantic perhaps you should use shock.
  23. Aug 20, 2017 at 2:07 PM
    Teriks
    Tom
    Front Range, CO
    Shock is just as wrong as strut.
    Sorry I used the wrong word to describe my original problem. I am aware of the right terms dude, no need to argue or try to educate here.
  24. Aug 20, 2017 at 3:42 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    No pics of said install? You know we need pics right? :)
    ColoradoTJ and Tophergt99 like this.
  25. Aug 20, 2017 at 4:12 PM
    Les7311
    Did you drive it a few well miles to let the coils settle in?
    You may see a difference with the levels after.....
  26. Aug 20, 2017 at 6:27 PM
    Teriks
    Tom
    Front Range, CO
    Not yet. I've only driven a few feet to get it back in the garage. With passenger side being an inch taller than driver, and a screwed up sway bar, I'm anxious to go much further till I get it to a shop
  27. Aug 20, 2017 at 6:30 PM
    Teriks
    Tom
    Front Range, CO
    Here's a height comparison after I finished the driver side. Don't have a pic yet of the full thing, and it's too goofy to show until it's fixed ;)
    mdavis[QUOTED] likes this.
  28. Aug 20, 2017 at 6:44 PM
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Driver side looks taller. If you get any lift from the Ranchos with 2.5" blocks you'll probably need UCA's to get it alined.
  29. Aug 20, 2017 at 7:05 PM
    Les7311
    Yeah. Does look lean. Hmmm. Is that expected?
  30. Aug 20, 2017 at 7:35 PM
    Teriks
    Tom
    Front Range, CO
    Well that's just how it stood with one side done and one side stock. Right now, the passenger side is 1" higher than driver. I'm guessing I yanked the UCA a bit too far down when putting it back together.
