Exhaust drone with skid plates
Discussion in '3rd Gen Tundras (2022+)' started by ryanjay11, Aug 20, 2023.
  1. Aug 20, 2023 at 5:29 PM
    ryanjay11
    ryanjay11 [OP] New Member
    I installed the aluminum engine and transmission skid plate with catalytic guard setup from RCI today. I have the TRD exhaust pipe that removes a resonator.
    I hopped on I-70 and drove 2.5 hours right after installing the skids today.
    The exhaust is significantly louder in the cab, and the drone is way, way louder. It's not to the point of being completely obnoxious, but I didn't expect it to make this much of a difference.
    It is trapping the sound/vibration within a few inches of the bottom of the the cab and the skid, where before it was completely open.
    Has anyone else noticed this?
    Yaboy and RickyBobbysTundra like this.
  2. Aug 20, 2023 at 5:31 PM
    firehawk003
    firehawk003 New Member
    Check to ensure none of the exhaust pipe is touching the plate.
  3. Aug 20, 2023 at 6:02 PM
    ryanjay11
    It does look like the catalytic converter might be touching the cat guard.
    Hard to tell from this angle.
  4. Aug 20, 2023 at 6:12 PM
    Lots of weird stuff happens with reverberation, im sure something changed when you added a shield.
    I don’t drive a lot of highway, but definitely notice the drone magnify under a overpass. One day I’ll get it piped passed the bumper with turn downs.
    RickyBobbysTundra likes this.
  5. Aug 20, 2023 at 6:42 PM
    ryanjay11
  6. Aug 20, 2023 at 7:47 PM
    Things can shift a little under load. My guess would also be contact of somekind with the new skid plate VS trapped noise.
  7. Aug 20, 2023 at 9:26 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I noticed no cabin noise change at all after installing a trans skid/cat guard
  8. Aug 21, 2023 at 7:29 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Same brand skids plates?
    Maybe the design of said skids plates affects harmonics.
  9. Aug 21, 2023 at 7:31 AM
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    There is some slop when installing the RCI skids so you can adjust them to the left or to the right side of the truck to be closer/further from the cats. Something to check in the event there is some contact happening when the truck is actually moving. I’m assuming the cats can also move a little since they are on hangers and those spring flanges.
  10. Aug 21, 2023 at 1:24 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I have the aluminum RCI set as well, I was worried about the possibility of noise bouncing around under there. I have to say that I haven't noticed any additional noise. I have a stock exhaust so that might help. It is pretty quiet all around.
  11. Aug 21, 2023 at 1:28 PM
    ryanjay11
    It's almost too hot to even breathe, but I'll crawl under it tonight and see if I can shift anything around and make sure all bolts are snug.
    The vibration on the floor makes me think it's either contacting the exhaust, or a loose bolt.
    I did some searching and found some people have had similar issues on various vehicles that were solved with dynamat.
  12. Aug 21, 2023 at 1:49 PM
    Black widow TRD
    Manuel
    Maybe your exhaust got loose, might want to check that when your check your skid plates.
    Are there certain torque specs that must be used?
  13. Aug 22, 2023 at 9:03 AM
    ryanjay11
    I crawled under the truck last night, loosened the bolts shifted around the plate, and retightened.
    The vibration/resonance might be slightly less, but it's still noticeable. I'll need to do some more diagnosis when it's not absurdly hot.
  14. Aug 25, 2023 at 7:05 AM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Tracking down resonation is a big PIA. Sharing an experience with my 4Runner. Had same issue and spent many hours checking clearance of system. Finally started looking at the heat shields installed over the top of the exhaust system. Started from the engine and working back found the culprit with one of them vibrating from the exhaust resonance over the section going over the rear axle down from the muffler. Did some adjustments adding a couple of rubber grommets and some bending of the ends and this did the trick. Hope this helps
  15. Aug 25, 2023 at 7:40 AM
    Tundratic
    Tundratic New (ish) member
    Canada
    2010 SR5 TRD OR 2023 Limited TRD OR
    I've got the exact same aluminum skids (engine and transmission) as well as the cat guards from RCI. I haven't noticed a difference in the exhaust sound/resonation, but I don't have the TRD exhaust though.
