Headunit dimming (night mode) when pressing brakes.
Discussion in 'Audio & Video' started by drpheta, Aug 6, 2023.
  1. Aug 13, 2023 at 7:31 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Another thought in case that last idea doesn’t help. Under the rear of the bed, up in behind the bumper, are two connectors feeding the trailer connector. Those could also be unplugged temporarily to see if there’s any change.
    1lowlife and drpheta[OP] like this.
  2. Aug 17, 2023 at 3:21 PM
    drpheta
    drpheta [OP] New Member
    Super White 2014 TRD Off-Road DC
    I had a chance to disconnect the taillights individually to try and chase this down. Disconnecting the upper lights and reverse lights results in no change. HOWEVER, disconnecting either of the left or right brake light bulbs puts the headunit into night mode (HU LEDs are turn on and Android Auto triggers dark maps). So, it doesn't matter if the left one is disconnected and the right one is plugged in or vice versa. If one or both are unplugged the headunit goes into night mode.
    I'm guessing they activating the brake lights is doing something similar to disconnecting the bulb. The bulbs are Sylvania halogen 3157 bulbs. Not sure why the (supposed) random voltage dropout under braking (if that's what it is).
  3. Aug 17, 2023 at 4:42 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Have you replaced the rear stop/marker bulbs since the truck was new?
    This may be a stretch but in 2014 front turn signal and rear stop/marker lights were referred to as 3157CK bulbs.
    Now they show to be 3157KX in the manual, which both it and the CK (I think they are the same) are different than a standard 3157.
    The sockets are pinned differently than the standard 3157.
    Explained here;
    3157 VS 3157CK LED Bulbs — AUXITO
    Instead of turn in this diagram, refer turn to brake/stop.
    So it might be when you hit the brake, you are activating, somehow grounding, the parking circuit.
    But it's confusing that you pull the bulb and it goes into dark mode.
  4. Aug 17, 2023 at 4:54 PM
    drpheta
  5. Aug 21, 2023 at 2:54 PM
    drpheta
    I tried the Sylvania ZEVO LED bulbs (from AutoZone) that are listed as compatible for our trucks, and both left and right brake lights flash in unison when either turn signal is activated. On top of that, the head unit starts up in night mode as if there isn't a bulb installed (pretty much no load detected).
    I'm even more confused. Why would the LED brake light bulb flash if the turn signal is activated? The halogen bulb didn't do that, and putting the halogen 3157 bulb back in is "normal" (other than the random flicking night mode head unit bug).
  6. Aug 21, 2023 at 3:10 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    These are the old brake bulbs out of my 2014, I run VLEDS LEDs in a Hottails kit now.
    They appear to be 3157KX.
    The KX designates the way the socket is pinned as in my reference in my previous post.
    I think when you hit the brakes with the standard 3517 bulbs, it grounds (or powers) the illumination circuit and causes you HU to think the parking lights are on.
    As previuosly stated, the weird part is why the HU just flashes.
    it seems your HU would be dim as long as you have the brake depressed.:confused:
  7. Aug 21, 2023 at 3:16 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Wow, I've tried several rear LED bulbs over the years and none did that.
    I can't remember if you posted, are you using stock halogen front DRL/turn signal bulbs?
  8. Aug 21, 2023 at 3:27 PM
    drpheta
    Front is the OEM LED set with the plug and play harness.
  9. Aug 21, 2023 at 3:33 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    How long ago did you do that?
    Is that when this issue started?
    Who made the harness, @iHacker or headlight revolution?
    I'd bet your flashing of the rears with LED bulbs happened after you did the headlights.
    Maybe try unplugging the headlights and see if the HU still has the issue.:confused:
  10. Aug 21, 2023 at 3:53 PM
    drpheta
    I upgraded the LED headlights back in June. The harness is from Headlight Revolution, but the headunit didn't do the flickering until a week before I posted this issue. I'll try putting everything thing back to stock and testing things one by one. Ugh
    The thing is I'm not the only one with these OEM LED headlights and the harness, but I'm the only one with this odd issue.
    1lowlife likes this.
  11. Aug 21, 2023 at 5:08 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Maybe leave everything as is, start the truck, and test all your lights.
    Parking, turn signals, brake, DRLs, white strips of the new LED headlights.
    Have someone outside the truck that can verify everything is working properly.
    I doubt you have the stock rear bulbs, I'll send you my 3157KX if you want them.
    May not fix the issue, but it might.
    I don't need them anymore.
    They're already sitting here on my desk..
    If you want them PM me a name and shipping address and I'll get them out to you.
    I'll cover shipping..:thumbsup:
    drpheta[QUOTED][OP] likes this.
  12. Aug 21, 2023 at 9:13 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    TRD PRO Super White CM
    2019 TRD PRO LED Headlights, 2019 TRD PRO Rigid LED Fog lights, All LED Interior, LED Cargo Lights, Bed LED Lights, Undercover Flex, Husky Weather beater floormats, FORTIN EVO ONE remote start, TDR Cold Air Intake, Tundra tail gate inserts, Pop & Lock...
    I think I talked about this issue before in other threads.
    https://youtu.be/xPZbmI4QMQg
    Start watching in the minute 4:35 where the turn signals parts begin, they are wrong when suggest to switch pins White/black wire with the Purple wire. Your truck has to have only the 2 wires as they are showing in the video and instead of inserting Purple wire in the center hole just cover the metal contact in this wire really well with electrical tape and leave the purple wire out the turn signal plug. Fill the empty center hole with silicone to keep water out and this should work to fix your problem with the taillights.
  13. Aug 21, 2023 at 9:21 PM
    iHacker
    iHacker SW TRD PRO
    Mario
    There’s nothing wrong with your head unit I guarantee you that and the problem is exactly where I pointed. The new bulb 7444NA has the ground contact flipped so when you use the turn signals it will short your taillights circuit. And this is in all the trucks that followed HR instructions and is just a matter of time you will notice that if you pay attention to your head unit and dash lights.
  14. Aug 22, 2023 at 4:48 AM
    drpheta
    So, even though I have 3 wires, instead of swapping the pins like instructed I should have just left the purple one out?
  15. Aug 22, 2023 at 9:02 AM
    iHacker
    iHacker SW TRD PRO
    Mario
    Yes sir, you have to leave the Purple Wire out of the turn signal plug
  16. Aug 22, 2023 at 9:07 AM
    drpheta
    Welp. I'm going to try this tonight.
  17. Aug 22, 2023 at 9:11 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I'm gonna hold on shipping you the 3157KX bulbs until we see if this fixes the issue.
    Let me know how it goes
    Thank you @iHacker
    I knew there had to be a cross/short somewhere.
    So this also affects the HU when he hits the brake?
    When he mentioned HR, I figured that might be the issue..:eek2::cool:
    iHacker likes this.
  18. Aug 23, 2023 at 2:12 PM
    drpheta
    OMG I think this did it. Headlight Revolution and all the LED harness makers need to update their instructions. I'm going to drive it for a bit to see if this fixes it.
    Put the ZEVO LED lights into the brakes, and they don't flash when turn signals are activated either.
    Retired...finally likes this.
