  1. Aug 21, 2023 at 10:41 AM
    These 15w0s make it hard to breathe on some songs. I've already lost an AC knob, rattled my mirror off, and my rear slider and rear window won't stay shut. It's so retarded. I love it!
    I think I need new amps though. My daughter spilled something on the 300/4 so the mids/highs go out every once in a while. The 1000/1 makes the subs make weird noises when nothing is playing and the radio is on.
    JasonC. and shifty`[QUOTED] like this.
  2. Aug 21, 2023 at 10:44 AM
    DJenerated
    DJenerated Roads? Where we're going, we don't need roads!
    Dija
    The Lone Star State
    I'm on my Android phone. Using IG app
  3. Aug 21, 2023 at 10:52 AM
    Bummer on the 300/4 :(
    You may want to pop the cover/heatsink off, and douse really well with a good contact cleaner, then hit it with an air compressor to blow out anything under the components. We have a pretty awesome PCB + contact cleaner at work with an integrated brush in the head, we either buy it from DigiKey or Mouser or the other one 'I'm not thinking of.
    And the 1000/1, what kinda noise?
  4. Aug 21, 2023 at 11:02 AM
    The 300 is getting better. I'm gonna run with it and see what happens.
    The 1000 makes almost what I'd call "road noise". The subs kinda rumble real low with occasional big pops. It doesn't do it constantly, and it'll pop when you hit bumps. I jacked with the RCAs a little and that makes em go crazy. Sucks cause when you're messing with the amps, the subs are inches from your head.
  5. Aug 21, 2023 at 11:04 AM
    daveeasa
    I think I have a spare 300/4. Got refurbed from JL many years ago and unused since.
    bmf4069[QUOTED] likes this.
  6. Aug 21, 2023 at 11:05 AM
    Dammit Dave! You know I'm an amp hoarder! Why are you tempting me?
  7. Aug 21, 2023 at 11:08 AM
    See if twisting the RCA on their receptacle generates noise. If it does, I'd be double-checking the ground for that amp, both where the ground enters the amp to check for frays and strays (may as well check power also) and double-double check where it terminates to chassis.
  8. Aug 21, 2023 at 11:11 AM
    Good quality RCAs? I find some of the nice, but lower end ones don't make the best contact with the amp RCA inputs.
    shifty` likes this.
  9. Aug 21, 2023 at 11:21 AM
    That's another thing too, you can always swap RCA at the back of the HU and between the 300 and 1000, see if the sound transfers. If it does, you know it's in the amp. Or run a new, temporary pair of RCA of known-quality.
  10. Aug 21, 2023 at 11:46 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Tundra2, txagg, Sunnier and 4 others like this.
  11. Aug 21, 2023 at 11:57 AM
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Yeah, I’m thinking about it but I probably won’t. The car doesn’t have an alternator, and the 12v battery charges from a DC-DC converter that’s contained in the battery pack unit, so I’d have to do custom stuff to get the 12v battery to charge. Plus it could still be functional in the future and only weighs 70lbs.
    Yeah, as cool as they are, it isn’t really worth it if it needs major stuff like that, and if you’re commute is anything but constant speed 45-85mph. The only reason it’ll work well for me in college is 98% of the driving I’ll be doing is on the highway.
  12. Aug 21, 2023 at 12:15 PM
    They're the ones that came in the kit shifty recommended:
    I'll check some things out when it's not hot(October) outside. Or under my shade tree one Friday morning.
    j4ycub likes this.
  13. Aug 21, 2023 at 12:25 PM
    j4ycub
    j4ycub New Member
    2001 stellar blue AC
    what will get the glue from a wind guard/bud deflector off the paint above the window?
  14. Aug 21, 2023 at 12:26 PM
    I recommended the Kicker package. That looks like the Kicker kit, but I don't see any of the expected logos. Did Sonix Electronix fulfill on it? If so, I trust it. If not ...
  15. Aug 21, 2023 at 12:27 PM
    Either get a "detailing eraser" (3M makes the best I've found) or Turtle Wax's label and adhesive remover has always worked well for me when combined with plastic flat razors. You can buy the blue/orange plastic flat razor kits on scAmazon.
    j4ycub[QUOTED] likes this.
  16. Aug 21, 2023 at 12:27 PM
    Yeah, I bought it straight from them. The kicker one was on Crutchfield for almost $200.
  17. Aug 21, 2023 at 12:29 PM
    j4ycub
    j4ycub New Member
    thank you.... ive spent the past 2 days trying different things w a plastic knife and no luck.
  18. Aug 21, 2023 at 12:35 PM
    Well, if I can do this with the Turtle Wax sticker and adhesive remover and plastic razor kit, I think you can get your glue off - BUT I will warn you - two things, first being the Turtle Wax product I'm referencing, which is at any big box automotive store, explicitly says to avoid black rubber/plastics with the product, and second being, some have complained about it temporarily softening up clearcoats so if you have a metallic truck, I'd test in an inconspicuous place first, using a method similar to what I just linked.
    This is the eraser wheel, which most local big box auto stores should have too. I trust the 3M product, you have a name who will stand behind you if it were to do damage. I don't trust the generic ones you find on scAmazon, only because, who the hell is going to cough up compensation if it did any damage? Anyway, don't believe it works? Look up videos on YouTube. It's a good tool to have in the toolbox, but steep buy-in price. This video may help explain why...
    NO MATTER WHAT YOU DO, WAX THE PAINT AFTERWARD!
    artsr2002 and j4ycub[QUOTED] like this.
  19. Aug 21, 2023 at 12:57 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    We got around to warshin our 300$ fridge.
    I wish I'd taken some before and afters of the inside. Sum bitch is brand new now.
    NUDRAT[OP], txagg, RUSTYNUTS and 6 others like this.
  20. Aug 21, 2023 at 1:11 PM
    Make sure you clean out the icemaker real good.
    Real good, minus the dings in the door, but it's how the inside works that matters. You probably got it for 1/3rd the new price.
    Tundra2[QUOTED] likes this.
  21. Aug 21, 2023 at 1:24 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    We cleaned all the inside removable bits with dawn and fabulouso.
    I cleaned all the non removable bits with dawn and bleach and elbow grease.
    We were real thorough this time and will clean it again when we get to our place.
    shifty`[QUOTED] likes this.
  22. Aug 21, 2023 at 1:26 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  23. Aug 21, 2023 at 1:31 PM
    j4ycub
    j4ycub New Member
    gonna get the 3m eraser wheel! would rather go w someone who has established a name for themselves.
  24. Aug 21, 2023 at 2:52 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    How expensive and difficult to replace the battery? Chris fix has a couple of videos on replacing Toyota Prius batteries and it's not difficult. Not sure how this compares though.
  25. Aug 21, 2023 at 4:08 PM
    Seller says $300 at a JY to replace, but it may just need maintenance like @FiatRunner mentioned. And I think you may be hard pressed to find an '02 Insight at a JY anywhere near me.
    artsr2002[QUOTED] likes this.
  26. Aug 21, 2023 at 7:17 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Yall should have seen all the spilt sweet tea and whatnot inside the bottom of this bitch.
  27. Aug 21, 2023 at 7:53 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Put some LED's in it.
    NUDRAT[OP] and Tundra2 like this.
  28. Aug 21, 2023 at 8:09 PM
    DJenerated
    Dija
    The Lone Star State
    Throw some D's on that b*tch
    https://youtu.be/vpWoenI7wRs
    txagg and Tundra2[QUOTED] like this.
  29. Aug 21, 2023 at 8:13 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It already HAS LEDS in it. LOL
    There's two little cool white LEDs in the small circles and a long horizontal one in the big circle
  30. Aug 21, 2023 at 8:28 PM
    DJenerated
    Dija
    The Lone Star State
    Throw some cheese in that b*tch
