Welcome to Tundras.com!
Quick Links:Cut, replace fuel filter with rusted ends on lines on 2003 tundra
Pulleys and play - how much is normal?
4.7 Leaking Head?
A few questions. Diff seal replacement with CV's? UBJ assembly vs Front UBJ assembly?
Front Differential Fluid/Transfer Case Fluid
1st gen worse MPG. What could be the Problem?
1st gen v6 manual transmission swap
Discussion in '1st Gen Tundras (2000-2006)' started by da9guy, Aug 20, 2023.
