New method wheels
Discussion in '1st Gen Tundras (2000-2006)' started by 302 Tundra, May 15, 2023.
  1. May 15, 2023 at 8:02 PM
    302 Tundra
    302 Tundra [OP] New Member
    2003 Access Cab TRD 4x4 4.7
    Hey guys I’m about to put on my methods mr315 they are 17x8.5 0 offset I want a flush wheel I have TRD flares as well I am lifted and putting on 285/70r17 with a level in the front I want to know if I need spacers to achieve this and if I will rub I have 4.75 BS
  2. May 15, 2023 at 8:55 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Put them on. You may rub the frame a bit but then you will know if it’s enough to care.
  3. May 15, 2023 at 11:18 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    0 offset 285/70/17 on method nv305
    before no spacer after with spider spacer 1.25.
    I did not end up running the spacer because it push the wheel out to far and required more cutting that I wasn’t comfortable doing myself. Spacer we’re on the truck for about 5min
    bmf4069 likes this.
  4. Aug 18, 2023 at 9:44 PM
    302 Tundra
    what exactly needed to be trimmed
  5. Aug 19, 2023 at 9:09 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Looked good with the spacers Jerry. What did it rub on?
  6. Aug 19, 2023 at 9:55 AM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Rubbed the fender flares off the clips and inside supports
    you can see how much I’ve cut away already. Right up to the bolt. Iv since cleaned it up, you can also see the frame rub. Iv learned to live with the frame only rubbing at full lock to the left.
    Love the look with spacers it was just to wide and rubbed a lot.
    I noticed double cabs 05-06 and smaller wheel, wells and other years and AC
  7. Aug 19, 2023 at 11:42 AM
    Elevatorguy
    James
    It rubbed the frame with the spacers?
  8. Aug 19, 2023 at 11:46 AM
    It wouldn't surprise me. Not having an adjustable UCA like SPC's offering gives you a bit less flexibility in how you can triangulate things. My guess is that could be tuned out to avoid rubbing with an adjustable upper, but it's just that: Guessing.
    No issue with using spacers, as long as you understand what NOT to do after install, and making sure everyone else who touches the wheels knows they're on there and what NOT to do with them installed.
  9. Aug 19, 2023 at 11:47 AM
    Elevatorguy
    James
    Doesn’t make sense to me if that’s the case. Pushing the wheel out would give more clearance to the frame I would think.
  10. Aug 19, 2023 at 12:53 PM
    jerryallday
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    The frame rub is with no spacers. With spacers on you eliminate the frame rub but push the wheel out that you rip the fender flares off and rub around the body mount
    Elevatorguy[QUOTED] likes this.
  11. Aug 19, 2023 at 6:42 PM
    Cummins3500
    Logan
    Similar specs to what your looking for
    16x8 method 304 double standards
    4.5 backspace, 0 offset
    1.25 wheel spacers
    Pinch welds are cut and flattened out
