How much further out will 18x9 with +18mm offset wheels be?
Discussion in 'Wheels & Tires' started by timsp8, Jan 1, 2019.
  1. Jan 1, 2019 at 8:22 AM
    timsp8
    timsp8 [OP] Former Tundra owner for 13 years
    NY
    Looking for help with new wheels. Ive searched and read alot of posts, but cant find my particular question.
    I have the TRD Off Road wheel 18x8 with +60mm offset. I am looking at new wheels that are 18x9 with +18mm offset. Tires went from Michelin 275/65r18 to 285/70r18 Nitto. According to the calculator on tiresize, the new inner sidewall will be 1.69" farther out from the suspension and the outer sidewall will be 2.09" farther out. But it doesnt ask wheel size or width.
    My question - will the new wheel be about 1.65" (60mm - 18mm = 42mm) farther out, or do I also need to add 1" for width (8 vs 9)? I dont want to go farther out than about 2.25".
  2. Jan 1, 2019 at 9:43 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I'm running Methods with a + 18. The tires are roughly 34.5" x 11.5".IMG_20180125_122210730 (1).jpg
    joonbug likes this.
  3. Jan 1, 2019 at 9:55 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Much better pic than mine. :thumbsup:
    TRD15559 and joonbug like this.
  4. Jan 1, 2019 at 9:56 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    You have to add 1/2 of 1 inch difference in wheel width since 1/2 of it will push the inner rim edge toward the suspension and the other 1/2 will push the outer rim edge out.
    Here's mine. My tires are slightly wider than the one you are thinking about. 295/70/18 on 18x9 18 mm offset wheels.
    AZBoatHauler and TexMedic like this.
  5. Jan 1, 2019 at 9:57 AM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    They sit around an inch past the fender. Check my sig and pics I have quite a few pics with almost that same size wheel but with 35’s
  6. Jan 1, 2019 at 9:58 AM
    mac10tuna
    mac10tuna New Member
    Marc
    19 cement limited CM
    I have the method 18x9 +18 with 275/70r18 Toyos.
  7. Jan 1, 2019 at 11:19 AM
    timsp8
    NY
    Thanks for all the pictures. That’s the stance I am looking for. Looks so much better. I have fender flares so it looks like it’ll be right at or just under them. Going with methods.
  8. Jan 1, 2019 at 11:34 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  9. Jan 1, 2019 at 11:46 AM
    timsp8
    NY
    According to that wheel width doesn’t matter. So it should be 42mm further out and stick out 34.5mm past the fender. That’s about 1.35”. My fender flares are 2”, so if there’s a law here that the tires have to be covered I’m still good.
    Had fender flares on the old truck and it looked ok. But I’m about to take them off now for a better stance. Plus the new wheels. Wishing I had gone bigger than 6112 at 1.9”.
  10. Jan 1, 2019 at 11:58 AM
    timsp8
    NY
    Here’s what it looks like now. Looks even worse straight on, but I can’t get a good straight pic from inside the garage.
  11. Jan 1, 2019 at 12:17 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    18x9, +18, 295/70R18 NRG with flares, had to get them, rocks were flying up the side.
    Ango_Cw and TexMedic like this.
  12. Aug 11, 2023 at 3:43 PM
    TexMedic
    TexMedic I ask a lot of questions…
    2017 Dark Gray DC Tundra 4x4
    What size lift are you running? Any trimming or BMC? I’m thinking about running this setup with my leveled tundra (2 inches up front).
  13. Aug 13, 2023 at 6:27 PM
    VadersTundy
    VadersTundy New Member
    2019 black sr5 crewmax
    +18 Methods with bushwacker oe flares and 275-70r18 tires. Sticks out ever so slightly past the flares
    Ango_Cw likes this.
  14. Aug 14, 2023 at 7:01 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Been a while, Bilsteins on 2nd setting and a Coachbuilder shim is a bit over 2” iirc. No trimming, but I did use a heat gun and pushed back some plastic. Not sure if same today, 6112’s were recommended back then.
    In the back I have 1.5” Toytec shackles.
  15. Aug 14, 2023 at 8:54 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    This website is a hidden gem of tire and wheel offset calculation and visualization:
    TexMedic likes this.
  16. Aug 14, 2023 at 7:40 PM
    TexMedic
    Interesting. My shop said I would need a BMC. Idk if I should risk it or not. It’s $350 to get it done.
  17. Aug 17, 2023 at 6:23 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Depends after the suspension upgrade settles, wheel size/offset and actual dimensions of the tire. I’d imagine even if you have the same everything as mine, there might be a small variance either way. However I researched here a few people who had the same Methods and NRG’s not needing to BMC which is what I wanted to avoid. Played the odds, worked.
    Check when level, and on a grade you often encounter both facing up and down, turn the steering fully each way to check rubbing. The shop is probably taking the guesswork out and over ensuring clearance. It’s not often I make tight radius turns but it’s never contacted doing it.
    GL
  18. Aug 17, 2023 at 6:28 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    25 mm is 1 inch. stock wheels are 60, so 60-18 is 42mm delta, So all things being equal, that offset will poke out each wheel 1.75 inch.
    AggiePhil likes this.
  19. Aug 17, 2023 at 2:48 PM
    TexMedic
    I might just test fit the front wheels to see if there’s any rubbing, and if so then I’ll drop my truck off for a BMC. If there’s no rubbing, I’ll just tell the shop something came up. Not like they’ll suffer from me skipping an appointment. They’ve definitely made plenty of profit from me lol.
    Do you have any pictures of your truck with this specific setup? I can’t seem to find any on your profile.
  20. Aug 18, 2023 at 11:18 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I could have sworn I had a pic, searching here “lift and heat gun” has a few threads and jogged my memory, I first unbolted the plastic, made new bolt holes and pushed it in further before the heat gun and rolling with a bat. There’s plenty clearance without the plastic cover.
    At work and leaving for a trip, I’ll try to get a pic later.
  21. Aug 19, 2023 at 6:05 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Full turn:
  22. Aug 21, 2023 at 10:42 AM
    TexMedic
    Shit man, that’s the cleanest Tundra I’ve ever seen. Love, and I mean LOVE the all black. What size suspension are you on? 3/1?
    JoshuaA[QUOTED] likes this.
  23. Aug 21, 2023 at 1:09 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Thanks! I think it’s 2.2”/1.5” based on what I said above.
    Someone said 3/1 makes it level when measured, but looks front high because of the truck’s visual angles. Also, I did want a slight rake because I used to tow an RV.
