Has anyone noticed a difference with different serpentine belts?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1Tundra5, Aug 18, 2023.
  1. Aug 18, 2023 at 8:29 AM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    I keep reading about gator back, Dayco and gates.
    Has anyone noticed any of those brands last longer, make less noise, help reduce engine noise, increased MPG :)D) anything?
    I am planning on changing the tensioner and pulley, and might as well get a new belt. I just need some insight into the 3 belt brands mentioned above
  2. Aug 18, 2023 at 8:44 AM
    How many miles you got? I typically replace the belts around 100k or if symptoms arrive. If the factory belt gets me to 100k, going right back with that. I’ve used the gates in my 2000. No complaints or failures in the last 50k miles with it.
  3. Aug 18, 2023 at 8:45 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If you live in an area that's humid or get a lot of rain, a Gatorback belt will allow condensation to escape evading the initial turn on squeal, fan roar will remain the same. The others are similar to each other but will not allow for condensation to escape, until it evaporates. I've gone through a few belts, since my truck kept shredding them, so it's personal preference.
  4. Aug 18, 2023 at 9:48 AM
    1Tundra5
    Junior
    2015 White SR5
    135k with some noise
  5. Aug 18, 2023 at 9:49 AM
    1Tundra5
    Junior
    2015 White SR5
    Do any do better with the fan noise?
  6. Aug 18, 2023 at 10:00 AM
    blackdemon_tt
    No, LOL....
  7. Aug 18, 2023 at 10:16 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Belts have nothing to do with fan noise
  8. Aug 18, 2023 at 5:04 PM
    kittyhawk
    kittyhawk New Member
    Dave
    Houston/Buffalo Texas!!!!
    2015 Tundra Crewmax SR5 4x4
    6112/5160. Ranchhand rear bumper and Valhallas Shields.
    I've been using Dayco belts on my 15 Crewmax, first one was at 100,xxx miles. Then I had to replace the original idler pully when it started squealing. So I had all new Dayco parts installed, belt, idler and tensioner pully. When comparing the Dayco to gates I think the Dayco was just a little higher quality.
  9. Aug 18, 2023 at 5:17 PM
    AZBoatHauler
    So.Arizona
    I recently bought an OEM replacement from Toyota and it says Bando on it.
  10. Aug 18, 2023 at 5:29 PM
    1Tundra5
    Junior
    2015 White SR5
    IMG_2287.jpg Does this look like it needs to be replaced?
  11. Aug 19, 2023 at 4:04 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I'd replace it and check the idler pulleys...I replaced mine with a Continental belt a year ago, 80,000 miles and have 94,000 now. No issues.... Used to be able to tell by cracks, but not any more. Gates does make a belt wear gauge that checks wear in the grooves, but they are hard to find.
    1Tundra5[OP] likes this.
  12. Aug 19, 2023 at 9:24 AM
    yakeng
    yakeng 3URFE Apologist
    Dayco was OEM on our Sequoia. Haven’t looked at the Tundras. I replaced our Sequoias at ~80K because I had to replace the tensioner anyway. The belt looked to have a decent amount of life still.
  13. Aug 19, 2023 at 9:34 AM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    Following.
    I bought a new belt at Auto Zone a couple years ago. I don't recall the brand, but it was their most expensive one. All I know is that sumbitch squealed like a pig whenever the weather got below about 50 degrees.
  14. Aug 19, 2023 at 2:45 PM
    1Tundra5
    Junior
    2015 White SR5
    What was wrong with the tensioner? What symptoms did it have?
  15. Aug 19, 2023 at 4:11 PM
    yakeng
    Bearing went out and loud squeaking, replaced it with an OEM tensioner and problem solved.
