FS Diode dynamics 42 inch light bar. SOLD
Discussion in '2.5 Gen Tundra Parts Marketplace (2014-2021)' started by RusPro21, Aug 9, 2023.
Thread Status:
Not open for further replies.
  1. Aug 9, 2023 at 12:20 PM
    RusPro21
    RusPro21 [OP] Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    26CA0565-5B69-4773-96EC-1A6C1D6373FA.jpg I have my 42 inch diode combo light bar for sale. Barely used. Was not in my tundra long. I will try and meet up with someone before shipping. But will also ship it.
    Asking $450.00
  2. Aug 13, 2023 at 7:55 PM
    RusPro21
    Don
    Pa.
  3. Aug 15, 2023 at 3:51 AM
    Bammer
    Monroe, CT
    Picture of it mounted on the truck?
  4. Aug 15, 2023 at 4:38 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
  5. Aug 15, 2023 at 5:20 AM
    RusPro21
    Don
    Pa.
    Hear it is John.
    Bammer[QUOTED] likes this.
  6. Aug 15, 2023 at 5:22 AM
    RusPro21
    Don
    Pa.
    I also left the push button wired on for one of the blank spots to use in your tundra.
    Bammer likes this.
  7. Aug 15, 2023 at 5:45 AM
    Bammer
    Monroe, CT
    Drilling required or plug and play? Any removal of bumper/Body panels? I tried looking at the website for install instructions, but found none.
  8. Aug 15, 2023 at 6:30 AM
    RusPro21
    Don
    Pa.
    Hey John, No drilling. The bolts you loosen where the front bumper is. Has the three holes on each side of the mount you see in the pic. What I did to make it easy remove your tow hooks and then it’s easy to loosen the front bumper bolts and then you remove the grid part in the bumper and you slide the light bar mounts in first and the light bar will sit perfectly. I attached the wire underneath and ran it up the side thru the fire wall. You can disconnect the wire to fish it thru and the push button disconnects also and I used my blank spot under my radio dash. You might have one closer to your steering wheel. I hope this helps with the explaining. Very easy install. Then your positive and negative goes on the battery and just push the button on to light it.
  9. Aug 15, 2023 at 6:31 AM
    RusPro21
    Don
    Pa.
    CC9CCB45-1991-469F-9814-2AF283574C73.jpg Hope this pic helps for anyone.
    Bammer likes this.
  10. Aug 15, 2023 at 6:31 AM
    RusPro21
    Don
    Pa.
    Bammer likes this.
  11. Aug 15, 2023 at 7:02 AM
    Bammer
    Monroe, CT
    Thank you for that, I want to slide under my truck and get the lay of the land so to speak, just to see what I am getting into.
  12. Aug 15, 2023 at 7:15 AM
    RusPro21
    Don
    Pa.
    No problem. I tried to explain it the best way. I think you will know what I’m talking about when you look. Removing the grid out of the bumper is probably the hardest part but not so much. I put it back in no problem. Colton from Hotshot off road made these mounts perfect to fit the light bar. Hats off to him.
  13. Aug 15, 2023 at 8:37 AM
    Bammer
    Monroe, CT
    You explained it perfectly. I over analyze , so this is just an OCD thing with me.
  14. Aug 15, 2023 at 9:05 AM
    RusPro21
    Don
    Pa.
    Oh I know what you mean John, I have done so much research from starting years ago with the Tacoma and the light bar. And also a lot of other mods over the years.
  15. Aug 17, 2023 at 6:10 AM
    heavyjay425
    heavyjay425 New Member
    Jayson
    2018 White Tundra 1794
    Is it white or yellow?
  16. Aug 17, 2023 at 6:24 AM
    Bammer
    Monroe, CT
    Looks like it's white , see post 5
  17. Aug 17, 2023 at 8:58 AM
    RusPro21
    Don
    Pa.
    Yes it’s white.
  18. Aug 18, 2023 at 8:24 AM
    emagine
    emagine New Member
    Columbia, SC
    2008 DC 4x4 5.7 and 2015 Sequoia 4x4 Ltd
    What part of PA are you located? I will be near Pittsburgh next weekend and may be interested.
  19. Aug 18, 2023 at 8:25 AM
    RusPro21
    Don
    Pa.
    Message sent
  20. Aug 18, 2023 at 9:13 AM
    MikeyRedFL
    MikeyRedFL New Member
    SWFL
    2021 Limited Crew Max 4x4
    Why are you selling it? It looked great
  21. Aug 18, 2023 at 9:18 AM
    RusPro21
    Don
    Pa.
    It’s does look great but I removed it because my truck is for sale. Really bright. Awesome for our back roads where I live.
  22. Aug 18, 2023 at 12:11 PM
    RusPro21
    Don
    Pa.
    Sold.
    PomDad likes this.
Thread Status:
