Fumoto Valve
Discussion in '2.5 Gen Tundras (2014-2021)' started by therealjonwick, Aug 18, 2023.
  1. Aug 18, 2023 at 9:32 AM
    therealjonwick
    therealjonwick [OP] New Member
    JR
    2019 OR
    Patch999 and Leo's first like this.
  2. Aug 18, 2023 at 9:36 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Lots of people using them on this site. I have the similar MotivX on mine and love it. If it weren't for the filter replacement being so messy, I wouldn't even need gloves to change the oil.
  3. Aug 18, 2023 at 9:38 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Absolutely 100 percent put one on. They are fantastic.
    ATV25 and coldcanuk like this.
  4. Aug 18, 2023 at 9:38 AM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    They are verry popular around here Get one for the filter also
    Makes for a easy mess free oil change
  5. Aug 18, 2023 at 9:46 AM
    therealjonwick
    JR
    2019 OR
    Thanks everyone. I will be ordering! What’s the one for the filter? Has the tube on it?
  6. Aug 18, 2023 at 9:58 AM
    Leo's first
    Groton ma
  7. Aug 18, 2023 at 10:04 AM
    Ghost Rider
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
  8. Aug 18, 2023 at 10:08 AM
    TXTundra2722
    2015 Black Tundra
  9. Aug 18, 2023 at 10:10 AM
    2mchfun
    Jowett performance makes a valved filter housing
    GODZILLA, bulldog93, WILLINH and 2 others like this.
  10. Aug 18, 2023 at 10:14 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Love mine, but definitely need to note that you have to buy the tool from them at the same time. There's a lot of hit-and-miss around actual tool dimensions out there, and cheaper/Amazon/eBay ones don't all work. (Most don't.)
    ATV25, bulldog93 and 2mchfun[QUOTED] like this.
  11. Aug 18, 2023 at 10:27 AM
    therealjonwick
    JR
    2019 OR
  12. Aug 18, 2023 at 10:27 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    No thx I'll keep my messy oil changes. Makes me paranoid with the wheeling I do.
  13. Aug 18, 2023 at 10:32 AM
    The Fumoto doesn't hang down low.
    GODZILLA, ATV25 and WILLINH like this.
  14. Aug 18, 2023 at 10:47 AM
    2mchfun
    My gripe with the Fumoto is the small port size. Takes a little time to drain even with warm oil. That said, I know Toyota doesn't have the best quality weld on the nut inside the pan, so for that reason Fumoto it is. Does anyone know of an aftermarket cast aluminum one piece pan with a drilled and threaded hole?
    ATV25 likes this.
  15. Aug 18, 2023 at 11:05 AM
    Ghost Rider
    Ian
    Cypress, Texas
    Do you have plates? I mean the whole thing is maybe three inches longer/hanging out than the regular bolt, so unless you off-road a lot and/or don't have plates (I have full set front skid and cat plates) they shouldn't be too much of an issue.
    Tundra234 likes this.
  16. Aug 18, 2023 at 11:29 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I don't personally use one, never felt comfortable with the flip of a valve being able to cause catastrophic engine failure. That said many people use them and they have a loyal fan base. I've done 9 oil changes to date and use the motivx kit which makes it easy enough. The longest part about an oil change is the skid plate removal and install.
  17. Aug 18, 2023 at 11:33 AM
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    The Fumoto valve is tucked under a skid plate/cat guard plate if you go that route.
    GODZILLA and ATV25 like this.
  18. Aug 18, 2023 at 12:05 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    The lever was the biggest sticking point for me. I opted for one similar that doesn't have a lever. It's a ball valve that opens as you screw on the drain hose.
    https://www.amazon.com/ValvoMax-Oil-Drain-Valve-M12-1-25/dp/B077ZGZ39V?th=1
  19. Aug 18, 2023 at 12:07 PM
    therealjonwick
    JR
    2019 OR
    Ah ok. Thank you. Just got my tundra and haven’t done a change yet.
  20. Aug 18, 2023 at 12:12 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    The lever engages in a notch when closed, which blocks it from flipping open.
    GODZILLA, ATV25 and AZBoatHauler like this.
  21. Aug 18, 2023 at 12:13 PM
    2mchfun
    Mine has a lock on the lever, but I think you have a better solution with this. Since I don't see any decent aftermarket pans, I shall order this guy. Thanks for the quick link.
    CaptainGrumpus likes this.
  22. Aug 18, 2023 at 12:14 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Exactly
    Joe333x[QUOTED] likes this.
  23. Aug 18, 2023 at 12:27 PM
    fyrfytr26
    Eastern PA
    2021 DC SR
    When the valve is closed the lever engages in the notch, as seen in the picture. There is a fairly heavy spring that keeps the lever from easily being lifted out of the notch. And for added peace of mind, they come with a plastic clip that physically blocks the lever from lifting out of the notch.
    I haven’t exactly gone looking for examples, but I’ve never heard of one coming open unintentionally. And I used to wheel in a lot more challenging terrain than anybody’s running in a Tundra.
    coldcanuk likes this.
  24. Aug 18, 2023 at 12:31 PM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    Had one for 2 years now on my Tundra and Highlander. I have them clocked so the lever is upright rather than down near the bottom of the pan. I like that it slows the oil flow down because it would come out so fast that it splashed off the oil pan and onto passenger side wheel before.
    I would think that if it failed, you would notice the oil puddle first if the truck was sitting. If it happened in motion the low oil light would come on and you could get pulled over and stopped before oil starvation and ever occurred. I’m just guessing though.
  25. Aug 18, 2023 at 12:33 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Than anyone in a tundra? Bold statement right @Cruzer
  26. Aug 18, 2023 at 12:40 PM
    AZBoatHauler
    So.Arizona
    Also has a lock that clips in place. I wheel hard and don’t think about it.
  27. Aug 18, 2023 at 12:41 PM
    AZBoatHauler
    So.Arizona
    Oh dang - those are fightin words.
    GODZILLA, bulldog93 and reywcms like this.
  28. Aug 18, 2023 at 12:42 PM
    AZBoatHauler
    So.Arizona
    Tunrod, GODZILLA, ATV25 and 3 others like this.
  29. Aug 18, 2023 at 12:53 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea, I still have trust issues lol
  30. Aug 18, 2023 at 1:11 PM
    fyrfytr26
    Eastern PA
    2021 DC SR
    OK, maybe I should have said 99.8% of guys wheeling Tundras. (I should have known better because I used to wheel with a guy with a stock height 3/4 ton Chevy that the only mods were a welded rear, front locker and good tires. He absolutely didn’t give a crap what happened to that truck.)
