Amazing 1st Gen Headlamp Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Neo, Jul 12, 2023.
  1. Aug 18, 2023 at 5:59 AM
    #61
    tl;dr version: Your light fixtures should a little bump (pimple) on the lens. Measure from the ground to that pimple with truck on flat ground. Put a long horizontal piece of painters tape at that height on whatever wall you'll test at. Pull your truck up to the wall so it's perpendicular, lights equidistant from the tape. Tape a cross straight out from the pimple for each light. Center of the tape crosses should measure same as the distance between the pimples. Back straight backwards, and use the crosses to center things.
    Videos may help, these pretty much cover it, although either of these methods fully, dude in the 1st one goes overkill IMO. And I don't like how ChrisFix ignores the pimple - it's there for a reason. Actually, @Headlight Revolution has a good video, skip to the 3m04s mark if it doesn't jump there already, he points out the pimple also.
  2. Aug 18, 2023 at 8:22 AM
    #62
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    Ha, for me the hardest part is find a nice wide wall with a flat surface you can backup 25ft from...I just rigged a landscape tarp under the house and it worked ok! The bulb itself has the horizontal level adjustment and there is not a side to side adjustment, thankfully they centered perfectly, a long thin phillips easily adjusts the vertical. LightWerkz also a good video, but the procedure is basically the same in all of them.
    Also, since the Sequoia is lifted, I dropped 2.5" from the center mark on the assembly and they are a bit low. Going to raise it up an inch or so to get it dialed in.
    @shifty` The fogs are going to need the same/similar bulbs...the oem's now look terrible by comparison.
  3. Aug 18, 2023 at 8:35 AM
    #63
    I still need to align my fogs. It's the one thing I didn't do when I swapped out my factory fixtures for yellow-lens fixtures.
    cran2[QUOTED] likes this.
  4. Aug 19, 2023 at 2:11 PM
    #64
    Neo
    Neo [OP] New Member
    Alabama
    @shifty` our bulbs do not have the fans and they required the resistors.
  5. Aug 19, 2023 at 2:38 PM
    #65
    Hmmm, bad guess on my part then. Back to the drawing board!
  6. Aug 19, 2023 at 5:00 PM
    #66
    daveeasa
    Super tricky to find a good spot to aim vehicle headlights. Definitely the hardest part.
    I see a lot of photos in here which look to me like excessive foreground light. Which is common with many cheaper led products.
    I hear mention of “20 year old tech”. By comparison, my wife has a vintage halogen desk lamp. I’ve tried all sorts of led bulbs in it and I’ve also purchased a $50 led desk lamp. Nothing comes close to matching the halogen bulb output. It’s crazy better. Just hot and kinda ugly and rusted. blows everything else I’ve tried out of the water.
    Honestly, one thing I love about these older trucks is the halogen reflectors. They are freaking awesome. Pair 100w bulbs with a harness and agm battery with voltage booster and it’s crazy good output and tons of heat to shed rain and snow. I would not want it any way other than that for road driving.
    I’m not trying to piss in anyone’s Cheerios at all. I may try an led bar for fun sometime. And I’m definitely doing some LED DRL’s once I get a chance, probably in the corner assemblies w switchback.
    But I just wanted to contribute an alternative angle for those reading this and assuming everyone things the same way about these headlights.
    Rich L. and gsdlvr like this.
  7. Aug 19, 2023 at 5:06 PM
    #67
    atomicnugget
    atomicnugget My bones hurt
    New Jersey
    2001 V8 Limited Access Cab 4x4 w. TRD package
    That’s awesome, just to be clear are you running just normal halogen bulbs in the OEM housing? Happen to have any pics lol
  8. Aug 19, 2023 at 5:14 PM
    #68
    daveeasa
    I am running osram 100w bulbs in new Oem housings. Housings were around $100 each? I bought 3 cause the first set allowed a tiny bit of moisture inside the passenger one. That pissed me off.
    Harness from Headlight Services but I bought the wrong one, I’m power switched because DRL, so I swapped out the relays for something I built myself. But buying the proper harness would work. I have his power switched harness on my ‘05 Tacoma.
    then an HKB voltage booster and x2 27F agm battery from batteries plus.
    still need to do the big 3, parts sitting for years now. Haven’t aimed yet either. They are way down, on purpose, cause I never get to go anywhere. It’s definitely overdue for aiming.
    I love the output.
    I run OEM LED in my ‘16, it’s superior to a halogen projector. But old school halogen reflectors outperform halogen projectors by a significant amount because of the size of the reflector. Good optics work well, heck, the James Webb telescope is old school reflector tech, so is EV, just a matter of quality.
    to me it’s a small bummer to stuff mini projectors in a large reflector, but I will say there are many who swear by led projectors so I’m not here to say they are wrong. Just saying I think the Oem headlights can be great with some work and mods.
    HBTundra likes this.
  9. Nov 10, 2023 at 8:46 AM
    #69
    dirtnsmores
    dirtnsmores New Member
    Southern CA
    2006 DC 4WD TRD OFFROAD
    Bilstein 6112/5100s, JBA UCAs
    Do you guys still recommend these bulbs? I eventually going to upgrade my housing or just get new OEM housing, they are fogged up. But for now I think I'm going to run a cleaning kit on the lenses and get new bulbs.
  10. Nov 10, 2023 at 8:59 AM
    #70
    You're in a great position. Your housings are fogged. With a $10-20 kit (either 3M or Cerakote) you can get them shiny again, but it's going to be a repeated exercise, refreshing every other year now they've oxidized (most likely).
    That said, why not seize the opportunity, since you need to permanently modify your housing in order to use these bulbs? This way, if you don't like them, you needed to replace the housings anyway, so you can get some new CAPA-certified housings, which will come fully-loaded with bulbs if you buy from any of the better brands. And at worst, if you love them, by the time you burn these out, there will probably be a better H4 mini projector available.
    Just sayin'.
    dirtnsmores[QUOTED] likes this.
  11. Nov 10, 2023 at 9:08 AM
    #71
    dirtnsmores
    Southern CA
    I like that idea if I'm following along correctly. Clean the housing, modify it for these bulbs, and run it.
  12. Nov 10, 2023 at 9:15 AM
    #72
    Hell yeah. What've you got to lose? You're looking at less than $80 probably for the housing kit and bulbs. And if you gotta buy new housings because you don't like it, you were already gonna be out $50-80/ea on those.
    If you've never polished headlight housings before, the key is to take your time, and the critical piece is the clearcoat process after. That's what decides how long they'll be good for.
  13. Nov 10, 2023 at 9:22 AM
    #73
    dirtnsmores
    Southern CA
    Cool that's what I was thinking. Yeah I've cleaned my share of headlights. Have a kit in the garage I forget which brand it is. I'll check when I get home later. Thanks for the help!
    shifty`[QUOTED] likes this.
  14. Nov 10, 2023 at 9:27 AM
    #74
    dirtnsmores
    Southern CA
    The one linked in the original post seems to be out of stock. Any recommendations from Amazon?
  15. Nov 10, 2023 at 9:48 AM
    #75
    Ha! I called it dammit! I knew they were about to sell off stock! CO Light and Braveway's version of that bulb are both gone. So typical.
    I don't see a replacement ... yet. You can still buy directly from CO Light's store the 'new' variation:
    Fanless: https://www.led-colight.com/product...flector-headlight?_pos=1&_psq=H4&_ss=e&_v=1.0
    Fan: https://www.led-colight.com/product...-blub-h4-9003-hb2?_pos=3&_psq=H4&_ss=e&_v=1.0
    I personally prefer fanless; I want something that doesn't need a fan to survive, if the fan dies, your shit's on fire. Plus all the complaints about radio interference from the fan'd bulbs is offputting.
  16. Nov 10, 2023 at 10:25 AM
    #76
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    My last headlight upgrade was only slightly better than stock.
  17. Nov 10, 2023 at 6:55 PM
    #77
    bfunke
    bfunke Tundra Curmudgeon
    Do the Y7s have the blue chromatic abberation?
  18. Nov 10, 2023 at 7:12 PM
    #78
    I mean, even OEM projectors have a slight purplish blue line at the cutoff.
  19. Nov 10, 2023 at 7:18 PM
    #79
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Yep. Pretty much all projectors have some. Just the nature of the beast.
  20. Nov 16, 2023 at 11:56 AM
    #80
    cran2
    cran2 New Member
    Folly Beach, SC
    This is a great performance/value mod, but really wish they made these in a 5000K, my son keeps telling me everyone says his headlights are purple!
    We may converts to H1 Bi-Xeons over his Christmas break.
  21. Nov 16, 2023 at 12:03 PM
    #81
    dirtnsmores
    Southern CA
    The most distinctive feature of this bulb is the three-color light, which is 6500K white light, 4300K yellow-white light, and 3000K yellow light. for the Y7S. just ordered.
  22. Nov 16, 2023 at 12:35 PM
    #82
    Yeah, but it looks like it defaults back to 6500K each time you start the vehicle, and you have to turn the headlights on/off to toggle to 4300K, and on/off again to toggle to 3000K? It's the only reason I'm not biting. I love the cutoff, though. Looks clean, if accurate.
  23. Nov 16, 2023 at 12:58 PM
    #83
    cran2
    cran2 New Member
    Folly Beach, SC
    Wait what? You can change the color?
    Edit- Oh I see its a different bulb than the Co Light I installed. Please post up your results as they would be much easier and cheaper than the H1 conversion.
  24. Nov 16, 2023 at 1:07 PM
    #84
    dirtnsmores
    Southern CA
    Yeah I know. Just gonna deal with it. 6500 is the only option on the other light so I figure with this, worst case scenario I forget to switch it to 4300. I don't drive a lot at night anyways
  25. Nov 16, 2023 at 7:24 PM
    #85
    artsr2002
    'Yonder
    https://a.aliexpress.com/_mOWhpo0
  26. Nov 16, 2023 at 8:37 PM
    #86
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Word of warning on these. If you can see the led it will most likely bounce in the reflector and could create some narly hotspots that are out of place. Had to do some minor surgery on the bulbs I put in my own truck for that reason.
    cran2 likes this.
  27. Nov 16, 2023 at 8:38 PM
    #87
    APalmTree
    Brandon
    SW Washington
    Picture wouldn’t attach….
  28. Nov 17, 2023 at 5:31 AM
    #88
    LED is exposed on mine (BraveWAY); I haven't found what you're saying to be true, but those ones on Ali look cheap af, not sure I'd be willing to buy them.
    Is the problem just with that specific bulb? I notice they're screwing in the LED chip pretty crudely, in a way that it appears to just be sitting there. I'm not surprised to hear about it bouncing.
  29. Nov 17, 2023 at 7:19 AM
    #89
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I'm surprised that you missed the fact that PalmTree has a 12 and you are comparing it to an 06. 2 completely different housings to lead to 2 completely different experiences.
  30. Nov 17, 2023 at 7:32 AM
    #90
    APalmTree
    Brandon
    SW Washington
    The high beam is... The low beam is tucked into the top part with the full shield on the bulbs that started this thread and the bulbs that went into my brother's truck. My truck only has one COB light on the bulb (its an h11) and it was throwing a high beam pattern because it was in the top of the reflector. Not sure it would do the same thing on a 1st gen it was just a heads up.
    The Black Mamba likes this.
