  1. Aug 17, 2023 at 2:37 PM
    rphass17
    rphass17 New Member
    Just noticed this? Anyone have a clue what the reason could be?
  2. Aug 17, 2023 at 2:38 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Yeah heater will have the difference, leave the radiator cap open, truck on, heat on full blast but no defroster, let it run and all the air in the system will bubble out, if you get a coolant bleeder it’ll help a ton, they’re only like $20, we use them at the shop almost everyday
    https://a.co/d/cz8axZu
  3. Aug 17, 2023 at 2:39 PM
    EmergencyMaximum
    EmergencyMaximum New Member
    Probably dealer added feature like all weather mats or whatever..
    @joseph_womack , thank you gang! I kept cap off while truck was running with heat before going for a ride and some bubbles came out. When I ran out of coolant to add, i closed cap and went to ride around town for errands.
  4. Aug 17, 2023 at 2:42 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Could be anything as simple as gluing in a bedliner. Mine has one of those stickers too, it reads 0lbs/kgs, my guess is that it was put on by whoever repaired the back end after she had a big bang.
    rphass17[QUOTED] likes this.
  5. Aug 17, 2023 at 2:54 PM
    Retroboy1989
    Northern Utah
    You would think there would be an element of materiality. Anything under 25lbs should be ignored.
    French Avocado and TheBrit like this.
  6. Aug 17, 2023 at 2:57 PM
    TheBrit
    Mark
    You just got all the accountants, data crunchers and legal eagles grinding their teeth. :rofl:
    French Avocado likes this.
  7. Aug 17, 2023 at 3:16 PM
    EmergencyMaximum
    Not if you are OCD about overloading your pickup and wondering if you should take that box of floss with you or make a second trip.
  8. Aug 17, 2023 at 4:53 PM
    EmergencyMaximum
    Well, this sucks...
    (Pun?)
    She is cooling and sucking all my precious coolant away. I knew it would get a little low when cooled, but not this low! Picking up another jug tomorrow. I guess that explains my capacity/fill discrepancy.(and no, it's not on the ground underneath the truck)
  9. Aug 17, 2023 at 5:09 PM
    Retroboy1989
    Northern Utah
    Do you think they factor in the weight of the sticker when they calculate the amount to put on the sticker?
  10. Aug 17, 2023 at 5:13 PM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  11. Aug 17, 2023 at 6:29 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    327456 miles a new starter
  12. Aug 17, 2023 at 7:35 PM
    EmergencyMaximum
    That's incredible! Gang, I have sort of related question. If I don't start very often, does it mean my started will last longer?
    Ricos likes this.
  13. Aug 17, 2023 at 7:46 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
    What’s the link for that?
  14. Aug 17, 2023 at 8:35 PM
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    Making the leap to 37’s?
  15. Aug 17, 2023 at 9:45 PM
    Retroboy1989
    Northern Utah
    Setting aside any damage caused by the elements, yes 100%.
  16. Aug 18, 2023 at 4:03 AM
    Shanet421
    San Diego,CA
  17. Aug 18, 2023 at 6:30 AM
    joseph_womack
    Joe
    Louisiana
    You could just add water instead
  18. Aug 18, 2023 at 6:55 AM
    Retroboy1989
    Northern Utah
    Distilled, de-ionized water isn't real easy to find.
    Toyota super long life isn't available as a concentrate, supposedly it's really picky about impurities.
    That said, I added distilled water to my sienna a few years ago. It has not exploded into flames.
  19. Aug 18, 2023 at 6:57 AM
    Retroboy1989
    Northern Utah
    Is that damage from wheeling?
  20. Aug 18, 2023 at 7:05 AM
    TimS458
    TimS458 New Member
    2012 Barcelona Red TRD Off-road
  21. Aug 18, 2023 at 7:11 AM
    joseph_womack
    Joe
    Louisiana
    We do it all the time at the shop for every make and model car, it’ll be perfectly fine
    Retroboy1989[QUOTED] likes this.
  22. Aug 18, 2023 at 1:06 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    It's too clean; has to be from a machine...
    joseph_womack and TheBrit like this.
  23. Aug 18, 2023 at 3:59 PM
    Yotaholic
    Yotaholic Amateur Professional
    Lone Star Republic
    2011 TRD DC 4.6
    Awesome. I used to want to do this until I realized how much gas I could buy for the cost of a new tank.
  24. Aug 18, 2023 at 4:19 PM
    Retroboy1989
    Northern Utah
    Is that irony?
    07 Tundie and EmergencyMaximum like this.
  25. Aug 18, 2023 at 4:48 PM
    MookTastic
    MookTastic Because I was inverted!
    Trice
    Rapid City, SD
    2013 5.7L White D/C TSS Offroad Icon Stage 8
    Icon Stage 8 AlphaRex Headlights
  26. Aug 18, 2023 at 5:14 PM
    EmergencyMaximum
    Black plastic bag in the truck bed:crapstorm:or this..
    Please don't do that, gang.
  27. Aug 18, 2023 at 5:17 PM
    Shanet421
    San Diego,CA
    Correct this is damage from the tire changing machine at pep boys…carelessness really
    Kinda digging the steelies now. I’m gonna clean them up and repaint them while the methods are out for repair.
  28. Aug 18, 2023 at 5:20 PM
    Tripleconpanna
    The way the machines work these days folks almost have to go out of their way to damage wheels.... Kinda ridiculous!!
  29. Aug 18, 2023 at 5:22 PM
    EmergencyMaximum
    My steel wheels look unholy after changing tires twice during its life. Sam's club also torqued the nuts so hard I had to jump on the wrench like a rabbit to loosen them up.
  30. Aug 18, 2023 at 7:13 PM
    Tripleconpanna
    :facepalm:
    ... but typical these days!!!
