2021 Tundra gas tank size?? I’m at 21gallons max!
Discussion in 'General Tundra Discussion' started by WillP, Aug 17, 2023.
  1. Aug 17, 2023 at 3:20 PM
    WillP
    WillP [OP] New Member
    Will
    2021 Tundra SX
    Leveling kit, Ridge Grappler 33’s
    Hello. I just bought my first Tundra about a month ago and this is my first time posting. I just had a question about the size of the gas tank in the ‘21 Tundra. Everything I have read says it’s either a 26.4 gallon or a 38 gallon tank. However, I have not been able to get more than 21 gallons in my truck on a completely empty tank. Anybody have any thoughts on this? Thanks in advance for your help!
  2. Aug 17, 2023 at 3:23 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I’ve only been able to put in 22 gallons max.
    WillP[OP] likes this.
  3. Aug 17, 2023 at 3:24 PM
    WillP
    Will
    2021 Tundra SX
    Ok thanks. Love the truck, not the tank. Haha
  4. Aug 17, 2023 at 3:33 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    The gas light comes on with about 6 gallons left.
  5. Aug 17, 2023 at 3:37 PM
    2mchfun
    Your fuel pump will run cooler and last longer if you cut it down to about 15 gallons or so.:thumbsup:
  6. Aug 17, 2023 at 3:50 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    It’s most likely the 26 gallon tank. The light comes on with about 6 gallons in reserve to keep the fuel pump submerged to prevent it from overheating.
    You can run it lower, but you’ll pay the price in shortened fuel pump life.
    (On a side note, I don’t understand why this comes up pretty much every day. Just about every single newer vehicle is the same way. I also don’t understand why it’s such a burden for people to stop for gas.)
    Taco-Spike and Saltyhero13 like this.
  7. Aug 17, 2023 at 3:59 PM
    Taco-Spike
    Two Trucks
    Yeah, you have the 26 gallon tank.
    I just put 25.6 gallons in mine the other day at about a 1/4 tank reading on the gauge (maybe a little over)
    WillP[OP] and JMB like this.
  8. Aug 17, 2023 at 5:20 PM
    WillP
    Will
    2021 Tundra SX
    Thank you for that information.
    For me, it came up because I was unsure and could not find the information that I have now, found here. I wouldn’t call it a “burden“, but I do fill up three times a week, so it is a change for me.
  9. Aug 17, 2023 at 5:20 PM
    You have the 26 gallon. The 38 gallon will take 30-32 gallons as it's max.
    WillP[QUOTED][OP] likes this.
  10. Aug 17, 2023 at 5:26 PM
    Metro14536
    Metro14536 New Member
    Brandon
    Las Vegas, NV
    2025 Ice Cap SR5 TRD Rally
    :frusty:
  11. Aug 17, 2023 at 5:46 PM
    fyrfytr26
    Eastern PA
    2021 DC SR
    I filled up today at the lowest my truck has been since I bought it 3 years ago. I had 88 miles to empty when I pulled up to the pump. The only reason I let it get that low is because I’ve been laid up with a herniated disk, and it’s only been driven a handful of times the past 3 weeks, mostly to doctor’s appointments. And my closest gas station is 10 miles out of the way. I normally fill up every Friday on my way home from work, but the last time I worked was a Thursday.
  12. Aug 17, 2023 at 6:27 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    Small tank guys grumbling about their small tanks, and in walks Taco-Spike swinging his big tank around.
    :stirthepot:
  13. Aug 17, 2023 at 6:30 PM
    Taco-Spike
    Two Trucks
    And taco spikes heart shrank three sizes this day
  14. Aug 17, 2023 at 6:31 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    There is a 6 gallon buffer when you gas light comes on I have gone 68 miles after light has come one.
