Boost Pressure, Transmission Oil & Engine Oil Temp Monitoring
Discussion in '3rd Gen Tundras (2022+)' started by rideandfly, Aug 17, 2023.
  1. Aug 17, 2023 at 7:47 AM
    rideandfly
    rideandfly [OP] New Member
    Been searching the forum and probably missed the "how to" post, but is anyone using the Right Side Gauges, "Tow gauges" found on page 91 of the operators manual? Tow gauges display boost pressure, oil temperature, and transmission fluid temperature. I'm having trouble setting this up.
    Thanks,
  2. Aug 17, 2023 at 8:07 AM
    rlc177
    rlc177 Data Logger
    Northeast PA
    pwpblue and rideandfly[OP] like this.
  3. Aug 17, 2023 at 8:22 AM
    rideandfly
  4. Aug 17, 2023 at 10:13 AM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    Can probably get that info with a scan gauge. The new one looks nice, someone here has one mounted to the left of the wheel.
    rideandfly[OP] likes this.
  5. Aug 17, 2023 at 2:08 PM
    rideandfly
  6. Aug 17, 2023 at 2:20 PM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I have trans temp and oil temp displayed on my ScanGauge 2. I think I tried to get boost but couldn't, but it's been awhile so I don't remember about that exactly. BTW, there seems to be only 1 trans temp, not separate fluid and converter temps like on past gen Tundras.
