Is there a wire on a 7 pin that is hot all the time?
Discussion in 'Towing & Hauling' started by IowaGuy, Aug 17, 2023.
  1. Aug 17, 2023 at 5:56 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am wanting to wire a rear camera on my trailer and have it powered all the time. I am wondering where would be the best place to tap power for it. It will use a 2 plug RCA connection with a standard two wire power tap on one to supply power.
  2. Aug 17, 2023 at 7:02 AM
    2mchfun
    Normally yes with key on. Find your ground with a multimeter set for continuity, then set it to voltage dc and with the key on you should find a 12v +.
  3. Aug 17, 2023 at 7:03 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Most of the people on the Lance owners forum I belong to tap into one of the running lights on the back of the trailer.
  4. Aug 17, 2023 at 7:06 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    I thought trailer plug wires were switched power, need key on.
    Is one hot all time, non-switched?
  5. Aug 17, 2023 at 7:11 AM
    2mchfun
    No, key on is required
  6. Aug 17, 2023 at 7:31 AM
    IowaGuy
    In Process
    This might be easier but I would need the running lights on to power the camera. Although I do like this better than running a power wire the length of the trailer.
  7. Aug 17, 2023 at 7:40 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ this
    2mchfun[QUOTED] likes this.
  8. Aug 17, 2023 at 8:01 AM
    SD Surfer
    Bruce
    So Cal
    True, but I always turn mine on when towing anyway.
    Onetrack97 likes this.
  9. Oct 19, 2023 at 8:31 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    My trailer backup camera is a Voyager brand wireless unit. Nothing required at the 7 pin connection.
    The camera is mounted at the back of the trailer near the center marker light so the running lights need to be on to power the camera. The screen plugs into a 12 volt cigarette light outlet in the truck cab and that's it. Pretty easy and no need for extra wires at the 7 pin connector.
    There are a few brands that work the same and I think you can get an app on your smartphone which would eliminate the need for the extra screen in the cab.
