Fuel Tank Broken While At Dealership
Discussion in '2.5 Gen Tundras (2014-2021)' started by trucktundra, Aug 14, 2023.
  1. Aug 14, 2023 at 7:11 PM
    trucktundra
    trucktundra [OP] New Member
    Have a 2016 Tundra. Took it in to dealership for an oil change. Upsold into a brake flush and internal cleaning of the throttle valve body.
    Car was returned with a fuel tank that could no longer take gas in. Returned it to dealership. Told I need a new fuel tank. The truck is a 2016 with only 25 thousand miles on it. Doesn't sit. It's driven regularly around town.
    No fuel tanks anywhere in the U.S.
    Now what, dealership says it's not their fault.
  2. Aug 14, 2023 at 7:27 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Have an independent shop check it out
    To clarify, the truck won't take gas? IE: You're at the gas station and you can only fill up a gallon or so at a time before the pump clicks off?
    Or, you can fill up but the tank has a hole in it and it all leaks out?
    trucktundra[OP] and 2mchfun like this.
  3. Aug 14, 2023 at 7:29 PM
    2mchfun
    Welcome to the forum from OKC! What exactly is broken? Slow or no fill? That can be corrected and if you use the search bar here on the site you can read what others did to resolve it. Basically according to some, the check valve gets stuck from overfilling. I think they used a borescope and stiff wire or similar to fix it, but can't really remember. I just don't fill it completely full so I can simply avoid it altogether.
  4. Aug 14, 2023 at 7:33 PM
    2mchfun
    Time for a 46gal aftermarket upgrade tank. Yes, costly!
    kingpin3919 likes this.
  5. Aug 14, 2023 at 7:33 PM
    trucktundra
    It won't take gas. Got half of a gallon in barely. It was fine before I took it in to dealership. Now it's back at dealership out of gas and they say valve is flipped as in a truck roll over. Truck never had accident, no roll over.
  6. Aug 14, 2023 at 7:34 PM
    2mchfun
    That can be worked out. Search the site here.
  7. Aug 14, 2023 at 7:35 PM
    trucktundra
    The dealership said they tried to pull the valve back but it wouldn't move. Now they state it has to have new fuel tank. Toyota has all tundra 2016 fuel tanks on backorder none available anywhere
  8. Aug 14, 2023 at 7:41 PM
    joseph_womack
    Joe
    Louisiana
    Take it to an independent shop and have them make their own recommendations; i obviously can’t trouble shoot the truck over the forum but the first thing that comes to mind would be the charcoal canister is clogged if you can’t take gas… if that’s been tested and deemed working, then on to the next part.
  9. Aug 14, 2023 at 7:41 PM
    trucktundra
    What happens if dealership causes this damage and then no part to fix it?
  10. Aug 14, 2023 at 7:46 PM
    They need to give you a loaner vehicle.
    I would contact Toyota corporate and open up a claim.
  11. Aug 14, 2023 at 7:49 PM
    trucktundra
    I contacted corporate. Dealership declined to offer loaner. Would not accept fault. I'm waiting to see what Corporate says. Only 25k on engine but out of warranty because it is 7 years old.
  12. Aug 14, 2023 at 7:50 PM
  13. Aug 14, 2023 at 7:52 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Valve flipped the last time you filled up, just coincidence that you needed to fill up again after the dealership.
    If you overfilled the tank by topping off or the gas station pump kept leaking out (which happened to me and I thought I was getting free gas), the valve will flip.
    Tundrastruck91 and 2mchfun like this.
  14. Aug 14, 2023 at 7:54 PM
    18" TRD Off Road Wheels
    This happens on the trucks sometimes, especially if the tank is "topped off" when fuelling. It may not have been the dealers fault or yours, because the rollover valves do stick sometimes.
  15. Aug 14, 2023 at 8:00 PM
    2mchfun
    The "they" can't is BS and all depends on who "they" is. Others have corrected it. Is it corrected or simply being forced open? That might be up for debate. However, at least they can get fuel into the damn thing.
    trucktundra[OP] likes this.
  16. Aug 14, 2023 at 8:15 PM
    trucktundra
    What is better for repair for others? Independent or dealership? I'm waiting to hear from Corporate to see if they will offer solution. Dealer has not offered loaner, or any repair solution other then replace the whole fuel tank. The next step if Toyota won't help is to tow it out.
  17. Aug 14, 2023 at 8:44 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Try this as a last resort .. was having same problem with filling and this stuff helped in my case. The previous owner overfilled and dealer had put a new charcoal canister but was still a slow fill at pumps until I used the stuff in the video. BOL !
    https://www.youtube.com/watch?v=H6TBPeiJAOI
  18. Aug 14, 2023 at 8:54 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    Bammer likes this.
  19. Aug 14, 2023 at 9:16 PM
    @Ruggybuggy can you shed any light on the parts for the rollover valve? Is it possible to replace without replacing the whole tank?
    Bammer likes this.
  20. Aug 14, 2023 at 10:01 PM
    yakeng
    yakeng 3URFE Apologist
    Dealerships have absolutely no interest or motivation to preserve your investment. They are a training ground for new “techs.” I’m sure there are some honest and decent mechanics out there, but I’ve found the way they are structured, from top/down, you are much better off finding a reputable independent shop, or fixing it yourself.
  21. Aug 15, 2023 at 7:53 PM
    ToyotaBeast
    ToyotaBeast New Member
    I have seen this before once. It can be fixed easily, remove the large rubber filler neck by removing the 10mm hose clamps. Then use a long flat head and tap the flapper valve open. The roll over valve is located right below the fuel tank inlet.
  22. Aug 16, 2023 at 5:32 PM
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    Take a 4 foot long ziptie and run it down the filler neck. You'll feel it bump something, then push through. It'll flip that flap open and you'll be good to go.
    Henry1jg and KNABORES like this.
