Garage door opener weak signal
Discussion in '2.5 Gen Tundras (2014-2021)' started by The Slingshot Kid, Aug 14, 2023.
  1. Aug 14, 2023 at 3:12 PM
    The Slingshot Kid
    The Slingshot Kid [OP] New Member
    Shane
    Albuquerque NM
    2020 Tundra SR5 Sport
    I recently traded in a 2022 4runner for my 2020 Tundra and I have been happy with just about everything except the garage door opener. In my 4Runner, I could hit the button when I am turning onto my block, ~200-250ft, and it would open. My Tundra won't open the garage until I am almost in the driveway, at most 50ft. Is this common for everyone else and is there a way to strenthen the signal?
  2. Aug 14, 2023 at 3:22 PM
    2mchfun
    Welcome to the forum from OKC! Lived there in Albuquerque for a few years back in the 80's. Anyway, not even sure if my truck has the feature. However, my 2018 4R has got to be really close for it to work. Sorry, not much help! Others will chime in soon.
    Edit: yeah have it, just never had my glasses on while looking at the mirror! Ha! Tiny buttons and bad eyes.
    BeauDacious likes this.
  3. Aug 15, 2023 at 10:03 AM
    yakeng
    yakeng 3URFE Apologist
    I have this same issue, but worse. I have to have the truck right on it to open the door and even then it sometimes doesn't work. I'm not sure if it is the Tundra or the garage door opener, but I feel like it is related to heat some how and boy has it been hot.
  4. Aug 15, 2023 at 10:51 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Mine always works when I use it, typically about 100-150 ft away.
  5. Aug 15, 2023 at 11:09 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    ~100' is my max. I use it to open a gate on my inlaws road and it's annoying because it's a 12' gate that needs to swing all the way open so I have to get up close and then stop and wait for it to open. If it would reach further, i'd be able to activate earlier and not have to stop.
  6. Aug 15, 2023 at 1:45 PM
    Retired...finally
    I've tried mine at around 200' away and it works fine. Aluminum doors and 6" thick solid logs with no windows or walk-in doors on that side. My garage door openers are 22 yrs old and I never thought it would work but on a whim I programmed the Tundra and it turns out it has more range than any of my other openers.
    The Slingshot Kid[OP] likes this.
  7. Aug 15, 2023 at 2:32 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    No garage, but I do have a "Mighty Mule" automatic gate. Same story. The clicker it came with, and the aftermarket ones, all have longer range than the truck. So, I just keep a clicker clipped to the visor like everybody else. The one built into the truck is basically a spare, in case my gate clicker has a dead battery or something.
  8. Aug 15, 2023 at 2:43 PM
    2mchfun
    I wonder if you can try moving the opener antenna into a different orientation and see what happens?
  9. Aug 15, 2023 at 2:50 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    do you have any lighting/electronics upgrades to the truck that may affect signal?
    Retired...finally and 2mchfun like this.
  10. Aug 16, 2023 at 8:35 AM
    The Slingshot Kid
    Shane
    Albuquerque NM
    I do not. The truck has a few mechanical upgrades but no electronics.
  11. Aug 16, 2023 at 8:47 AM
    The Slingshot Kid
    Shane
    Albuquerque NM
    I can't find anything online about the antenna location or orientation. Do you have that info?
  12. Aug 16, 2023 at 9:45 AM
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    Do you have a light bulb on your garage door opener? LED light bulbs may interfere with signal. It is best to stick with halogen on the garage door opener.
    2mchfun likes this.
  13. Aug 16, 2023 at 9:47 AM
    The Slingshot Kid
    Shane
    Albuquerque NM
    I do, but that doesn't explain why my other vehicle and the regular garage door openers work fine at distance. The issue appears to be something with the truck, especially since everyone's reporting very different ranges and capabilities
  14. Aug 16, 2023 at 10:06 AM
    2mchfun
    I'd imagine that it depends on your opener brand. Mine has a thin flexible wire hanging out of the housing and that would be the antenna. Climb up and see.
  15. Aug 16, 2023 at 10:13 AM
    The Slingshot Kid
    Shane
    Albuquerque NM
    I misunderstood, I thought you meant antenna on the truck. I tried messing with the opener antenna with no success
    2mchfun[QUOTED] likes this.
  16. Aug 16, 2023 at 10:44 AM
    2mchfun
    Is this really a huge deal? If so, perhaps you can find an antenna amplifier or remote antenna for the opener. Just a quick thought.
  17. Aug 16, 2023 at 10:50 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    For some, yes it can be a huge deal. Just like when people complain about the chrome around the gear shifter. Some may not think it's a big deal but to others, it is.
  18. Aug 16, 2023 at 11:17 AM
    The Slingshot Kid
    Shane
    Albuquerque NM
    That is a bummer, I was hoping to avoid that and just use the factory equippment and not have to use my normal garage clicker.
  19. Aug 16, 2023 at 11:20 AM
    The Slingshot Kid
    Shane
    Albuquerque NM
    Yeah, let me feel my feelings, bro. Ha ha. It's not an earth shattering issue, but it would be nice to be able to have the garage door fully open when I pull into the driveway.
    Jaypown[QUOTED] likes this.
  20. Aug 16, 2023 at 11:42 AM
    2mchfun
    Precisely why I have attempted to think of a possible solution.
  21. Aug 16, 2023 at 11:48 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Except you kind of did by offering ideas...
  22. Aug 16, 2023 at 11:48 AM
    2mchfun
    There might be an issue with interference in your area and definitely possible since you are right there next to the Air Force base. :alien::alien:
