Another my mileage dropped recently post.
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Aug 16, 2023.
  1. Aug 16, 2023 at 7:58 AM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    2019 SR5 and I was previously seeing ~14mpg town (3 mi. short trip to work) and ~17.5 on longer hwy trips. I am now seeing around 11.3 mpg in town and 14.5 hwy on the lying computer screen. About a 3 mpg average drop.
    I have 275/70/18's with a front level. I changed the plugs about 4 months ago and I am due for an oil change. Oh and I put on a Bakflip hard roll-up tonneau cover (heavier?) and I ran a can of Seafoam through the gas tank and a new air filter at the last oil change and tire pressure is just on the high side @ 35psi. Brakes and rotors are new in the past 5 months too.
    Summer here in AZ has been brutally hot here with <105 days for the past month. It has also been really humid. I also use ethanol-free "blue gas" from the local convenience store.
    Is this normal, I put in a new battery last week too so perhaps the computer either has or hasn't caught up to learning. I also think the hot weather is a factor as my truck seems to like the cooler air in the winter. I replaced the plugs myself and gapped them correctly and it was also doing fine after that. I am also thinking some fresh oil might help but I dont think it would make that much of a difference.
  2. Aug 16, 2023 at 8:27 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    So are you going off of the dash calculation or hand calculation?
    gnatehack likes this.
  3. Aug 16, 2023 at 8:28 AM
    seydou
    seydou Distinguished Member
    Why are you relying on the truck computer for the mileage calculation? They are notoriously inaccurate.
    How many miles on the truck? Why did you replace the plugs?
    More weight will always lead to less fuel efficiency.
    "Fresh" oil is not going to change anything.
    Jaypown likes this.
  4. Aug 16, 2023 at 8:30 AM
    IowaGuy
    In Process
    Dash PC calculations
    The truck has 74K miles on it.
    I preemptively replaced the plugs before a 4K long trip.
  5. Aug 16, 2023 at 8:32 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Don't do that.
    Do a proper calculation. A new battery will mess with the dash for a couple fillups.
  6. Aug 16, 2023 at 8:41 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    My guess would be a computer learning issue from the new battery. Maybe calculate it by hand and see if the numbers match.
    The AZ blast furnace certainly doesn't help, but I wouldn't think it'd be a 3 mpg difference
  7. Aug 16, 2023 at 8:41 AM
    gnatehack
    gnatehack New Member
    Middle of Minnesota
    13 SR5 5.7 4x4 Bench
    Up to date maintenance
    Or if math isn’t your friend you can try something like fuelly.com
  8. Aug 16, 2023 at 8:42 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Did you use Toyota spark plugs for exactly this engine? Gaping seems suspicious, OE plugs don't need that.
  9. Aug 16, 2023 at 8:43 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    This is what I use. Keeps it very simple but just typing in numbers on each fillup. Then I have a log to see how it trends.
    Almost every single tank my dash calculation is within .5 mpg of fuelly.
  10. Aug 16, 2023 at 8:49 AM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
    One thing you might want to check is your alinement, a few potholes and maybe curbs will affect MPG.
  11. Aug 16, 2023 at 9:15 AM
    seydou
    Except, he will be comparing the old truck computer numbers with the new hand calculated numbers. They will be of limited use to make an accurate comparison.
  12. Aug 16, 2023 at 9:16 AM
    seydou
    Aren't the OEM plugs good for 120,000 miles?
    And what plugs did you use and as another poster asked, why did you gap them?
  13. Aug 16, 2023 at 9:18 AM
    IowaGuy
    In Process
    Hey, I can do math and I am no dummy because I went to high school for 5 years!
    The plugs didnt need gapped, I checked the gap would be more accurate.
    I used NGK Iridium plugs
    Black Wolf and sask3m like this.
  14. Aug 16, 2023 at 9:22 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You got an extra year to do shop and ag? Lucky bastard.
    Black Wolf and Jaypown like this.
  15. Aug 16, 2023 at 10:06 AM
    Rdrcr
    Rdrcr New Member
    2019 Toyota Tundra TRD Sport
    I'm averaging a solid 17 MPG mixed city/hwy in my truck, hand calculated. My dash computer is inaccurate. However, it can be plus .3 or minus .3. It doesn't always read high. It sometimes reads low in my observations.
  16. Aug 16, 2023 at 12:04 PM
    AZBoatHauler
    So.Arizona
    Assuming you went to LT tires when you bumped up in size, 35psi would be on the lower side of inflation, not the higher side. My only other comment is don’t use a regular spark plug gap tool when handling iridium plugs, they can damage the tip. (twss)
    g6t9ed and TRDFerguson like this.
  17. Aug 23, 2023 at 6:31 AM
    IowaGuy
    In Process
    Small update. I stopped this morning to fill up with gas to be able to do a hand calculation of mpgs. After I pulled into work I checked the dash computer and it read 12.5 mpg. I know it lies but that is more along the lines of what it was. This is also my first fill-up since changing the battery so maybe the truck reset or recalculated itself?
  18. Aug 23, 2023 at 6:39 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    What was your hand calculation?
  19. Aug 23, 2023 at 7:01 AM
    IowaGuy
    In Process
    Haven't done it yet, this was the initial fill-up to be able to do that. I have to drive about 100 miles today so I will fill up again when I get back and see how it compares.
  20. Aug 23, 2023 at 7:03 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    If that 100 miles is all city or all highway, I would wait until you run through at least half the tank before you actually fill up and calculate. If not, your calculation will be biased.
  21. Aug 23, 2023 at 7:46 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Use Fuelly.com and track it...I have been since owned and it is consistent (truck efficiency-wise)...just a suggestion but I'm manic on tracking now since using it...
  22. Aug 23, 2023 at 7:47 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    How do you link it to your signature?
  23. Aug 23, 2023 at 7:52 AM
    HulkSmurf14
    2014 Tundra Limited
    Within the web page there's a couple options on formats to use for linking...at the very bottom of the data it has a button "Share your MPG"
    Jaypown likes this.
  24. Aug 23, 2023 at 8:15 AM
    IowaGuy
    In Process
    I just joined Fuelly and my vehicle name is "I Suck Gas"
    Black Wolf, Jaypown and HulkSmurf14 like this.
  25. Aug 23, 2023 at 10:33 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I must be blind. I've never logged into the actual website before but I'm in and have everything updated. Just cant figure out the linking part.
    EDIT: Disregard
    HulkSmurf14[QUOTED] likes this.
  26. Aug 23, 2023 at 12:57 PM
    XR5dude
    XR5dude New Member
    2021 Tundra
    So you upsized your tires and get about 12 mpg? Not sure why so many people use Fuely who get bigger tires? Are you trying to get the worst mpg possible? 12 mpg is too good, so maybe get even bigger tires?
  27. Aug 23, 2023 at 1:17 PM
    HulkSmurf14
    2014 Tundra Limited
    Lots of reasons to track...in northern states, winter fuels change, temperatures change mpg, fuel stations all have different blends (where I'm at) and it's a good indicator on style of driving...most importantly us fuel type, grade and time of year...easier to budget for trips
  28. Aug 24, 2023 at 4:32 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I got slightly bigger tires (275/60/20) and I've been tracking since 2014. Four vehicles ago. I track because I like to see how my driving is. I know that I lost maybe .5 mpg on average with the new tires so I take that into account. By tracking, I know when my driving habits are more aggressive or when winter blend fuel arrives and with winter/4wd, I lose another 2 mpg.
    I don't use it as the holy grail or anything but it's just nice to see how things are going.
    HulkSmurf14 likes this.
  29. Aug 24, 2023 at 7:49 AM
    XR5dude
    XR5dude New Member
    2021 Tundra
    That makes prefect sense. Sorry I assumed the tires you got were larger than that. But only a little over one inch taller. That may still be more than 1 mpg for one inch. I also keep track of mpg. Probably too obsessed with it as I only drive 12k miles a year so justtified the lower mpg compared to my previous F150 5.0 that got 19mpg using Fueley.
    I'm getting 16.8 with mixed driving with 2wd and Ridge Grapplers that are stock 275/55/20. They get about 1 mpg worse than P road tires. The 4wd will also be 1 mpg.
    The thing is we only get snow maybe once every 10-20 years that even sticks to the road so would have a far greater chance of mechanical failure with 4wd than actually needing it.
    Also see lot of people on Fuely who get terrible mpg because of larger tires. Sorry I thought you were one of them but that's very reasonable. I'll likely go with Michelin Defenders for next tires as they are 10 pounds lighter and 1 mpg better. Although see how the Grapplers do. I worry about them on wet pavement. I've tested them some and will lose traction.
    I don't care about what tires someone whants to use, or what mpg they get, but do actually dislike loud trucks or vehicles because it's inconsiderate to everyone else. Sorry that's a little off topic but usually bigger tires, low mpg, and loud trucks go hand in hand. Sorry if that offends someone, maybe that's all they want anyway. Life moves on. I'm not on a busy road either.
  30. Aug 24, 2023 at 11:07 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    No worries! It's actually the OP that has the other tires and a front lift with really bad MPG on the dash. I was just defending the use of Fuelly lol
    But I agree with you, getting larger/heavier tires with a lift and then complaining about mpg's (not saying anyone on this thread is doing that) is always crazy to me.
    HulkSmurf14 and XR5dude[QUOTED] like this.
