Activate acc mode without neutral & start stop?
Discussion in '3rd Gen Tundras (2022+)' started by Bry2023, Aug 14, 2023.
  1. Aug 14, 2023 at 3:18 PM
    Bry2023
    Bry2023 [OP] New Member
    2023 Limited TRD Off-Road
    Anyone know how to activate an accessory (acc) mode without: putting it into neutral, then, pushing the engine start stop , which brings up “ignition on” / “turn power off” messages on the screen??
    Thanks , new member bryan
  2. Aug 15, 2023 at 5:26 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Not sure if I understand the question correctly but why are you putting it in neutral? Keep your foot off the brake pedal and try it.
  3. Aug 15, 2023 at 6:01 AM
    18" TRD Off Road Wheels
    You should be able to do it in park. Just hit the engine start button without touching your brake. First press will partially wake it up, and second press should be ACC mode. This info is all in your owner's manual.
    NATE4SURF and toyotaobsessed like this.
  4. Aug 15, 2023 at 7:16 AM
    nodak67
    nodak67 New Member
    JR
    are we talking about putting it into acc mode while the engine is running prior to putting it into park and shutting off?
    if so, then neutral and pushing SS will put it into acc mode with the engine off prior to putting it into park. just a side note, once you want to start the engine again, you have to push the SS button twice to shut off acc mode and put the truck into off mode, then start the engine as normal while pressing the brake.
    if the engine is already off and in park, just push the SS button once to go into acc mode without pushing the brake.
    this whole process is detailed in the owner manual.
    Sixty9Four20 likes this.
  5. Aug 15, 2023 at 11:37 PM
    Bry2023
    Yes…i am a n idiot. Thanks much for your help
