Vibration (Shaking) while Braking - 2016 Limited CrewMax 4x4
Discussion in '2.5 Gen Tundras (2014-2021)' started by kilobravo, Aug 10, 2023.
  1. Aug 10, 2023 at 6:58 AM
    kilobravo
    kilobravo [OP] New Member
    Kirk
    2016 Tundra Crewmax 4x4 (Silver)
    All stock for now ...
    2016 Limited CrewMax 4x4, purchased used (26k miles) in 2017.
    Not long after purchase, I noticed a pronounced vibration when braking. The dealership would only replace the brake rotors / pads (outside of warranty) as they were convinced this was the only problem. I've replaced rotors and pads multiple times, to no avail.
    I'm nearing 200k miles and while recently servicing the truck, I noticed the UCA bushings are all but destroyed. I'm suspect that part of this ongoing and worsening shake (or at least the worsening) is related to worn bushings. If I replace the UCAs, should I do the ball joints, rotors, brakes, bearings, all at the same time?
    Any other guidance on what my problem might be?
  2. Aug 10, 2023 at 8:18 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    I would assess the ball joints and bearings for any play and use that to determine if they need to be replaced. While its possible they could be a source of vibration, its relatively uncommon. I personally wouldn't just prophylactically change them, especially the bearings because that's a more labor intensive/$ job. Pads and rotors are a common source of vibration on these trucks, especially if you tow heavy. That combined with your UCA's may just be the issue.
  3. Aug 10, 2023 at 9:17 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    I have check you tire balance?
  4. Aug 10, 2023 at 9:27 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I would definitely mirror this and add an alignment to your game plan. I had a similar issue on my truck last year and ended up doing pads, rotors and an alignment. If you do new UCA's then obviously you'll already do one, but I'm always amazed at how much better my truck drives after getting an alignment done. I doubt a bad alignment would be the source of your issue, but it certainly wouldn't help.
  5. Aug 10, 2023 at 10:17 AM
    kilobravo
    Kirk
    Thanks! I don't tow very often - and nothing terribly heavy. I've been through multiple pads and rotors. ANything else that could be showing excessive play?
  6. Aug 10, 2023 at 10:18 AM
    kilobravo
    Kirk
    About every 7500 miles. Have been through multiple sets of Michelins. Lug nut torque values are at spec, too.
  7. Aug 10, 2023 at 10:19 AM
    kilobravo
    Kirk
    Thanks! Had an alignment about 10k miles ago and to no avail. After the UCA's, definitely back to the alignment shop.
    WRT UCAs, is there an aftermarket brand that's good to go with for a stock 4x4?
  8. Aug 10, 2023 at 10:30 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Bet you could get someone's stock UCA free or cheap. Plenty of people have swapped uca as part of lifting.
    That would let you rule it out at minimum cost.
  9. Aug 10, 2023 at 12:14 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Oh yeah there's tons of brands, Icon, Camburg, Total Chaos, Dirt King, take your pick. Take a look at SDHQ.com, the have a ton of options.
    kilobravo[QUOTED][OP] likes this.
  10. Aug 10, 2023 at 1:18 PM
    Totmacher
    Daniel
    West TN
    Some
    Since you've done brakes, other softer parts may be worth checking if they are all high milage parts now.
    If you're able to see wear in UCA bushings, i wonder what LCA bushings look like. Especially rearward bushing. I know that that one had a lot of movement on one of my past trucks enough that it would cause tire to rub if braking while in a slight turn.
    I've noticed vibration while braking if a tire was slightly out of balance or out of round. Like if a tire flatspots from being parked for a long time i might get a vibration only around 60mph driving but then if i brake hard it'll shake all the way down from 60-10mph sometimes until i've gone enough miles for the tire to round itself back out better.
  11. Aug 10, 2023 at 6:48 PM
    kilobravo
    Kirk
    I'll take a look at the LCA. This vibration has been happening regardless of which tire, new, old, freshly balanced, etc.
  12. Aug 15, 2023 at 1:04 PM
    PCBTundra
    PCBTundra New Member
    Tried everything…its a flaw….. last shop was honest said just do rotors. Lasted just as long as pads and rotors.
    Someone at said shop said “ welcome to Tundra land”
    I’m
