GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Aug 3, 2023 at 11:51 PM
    #3571
    PapaDave418
    PapaDave418 A Dude who knows a Dude
    Dave
    North Idaho
    3rd Gen Limited TRD
    37’s—PullKitchen--KB Voodoo Rack & Full Ext Cargo Tray
    Method 703’s +35 with 1” spacers. Just put on Toyo R/T Trail tires size 37/12.5/17
    7B3C9504-B748-4F98-876C-89A6CA882ABD.jpg 3C1A2206-4B2C-4CB1-9DD0-6925A1FBC515.jpg
  2. Aug 4, 2023 at 8:45 AM
    #3572
    KSUTundra
    KSUTundra New Member
    2022 Tundra TRD OR
    Love the truck. I saw you used to have the 315/70s on. Did you need the 1" spacers for that set up also?
    I'm planning on doing the same setup (17" Method 705s +35 and the westcott level) only with 35x12.5.
    PapaDave418[QUOTED] likes this.
  3. Aug 4, 2023 at 6:30 PM
    #3573
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I just liked the little extra poke with the spacers. It places the offset about a +10 or +12
    Yaboy and KSUTundra[QUOTED] like this.
  4. Aug 7, 2023 at 9:25 AM
    #3574
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I am a big fan of the Cooper AT3 tires. The XLT comes in 275/65r20 (34"), which will probably be my next tire (OEM Falkens have about 5,000 miles left on them). The XLT has the same tread pattern as the 4S, but different ply rating, so they will ride a bit harder than the 4S.
  5. Aug 9, 2023 at 6:40 PM
    #3575
    Breathing Borla
    Northern Illinois
    keep what you have , it’s the best combo for looks and light weight performance
  6. Aug 9, 2023 at 6:45 PM
    #3576
    Breathing Borla
    Northern Illinois
    leave it man, i have to the same ones , they are perfect
  7. Aug 10, 2023 at 7:35 PM
    #3577
    cruisernate
    cruisernate New Member
    2022 Tundra TRD Off Road (Army Green)
    Anyone here have the Black Rhino Abrams (18x9.5) with 12mm Offset? Looking to swap the stock TRD Off Roads off my 22 SR5 Off Road and mount the 275/70r18 Ko2 on em! 350422856_6027107154078510_8974113421059723113_n.jpg
    BigEd and iiawah808 like this.
  8. Aug 10, 2023 at 7:50 PM
    #3578
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    These are nice…they look really heavy. Whats the weight on these?
    DexterL likes this.
  9. Aug 10, 2023 at 9:16 PM
    #3579
    cruisernate
    32.6lbs
    iiawah808[QUOTED] likes this.
  10. Aug 11, 2023 at 1:53 AM
    #3580
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    Does the 1” spacer keep you from rubbing your sway bar?
  11. Aug 11, 2023 at 7:52 AM
    #3581
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    It might, it mostly keeps me from wishing I bought +12 offset instead of +35.
    Yaboy likes this.
  12. Aug 12, 2023 at 9:56 PM
    #3582
    GrillmanBg
    GrillmanBg New Member
    Central Coast
    23 SR5 TRD Premium
    Icon stage 7 lift with 1”dobinson rear springs 35 in Toyo Rt trail 17 inch Method 703 bead grip Gfc camper
    Icon stage 7 with UCA
    35’s Toyo RT Trail with method 703 with 0 offset
  13. Aug 14, 2023 at 7:39 PM
    #3583
    eklaharn
    eklaharn New Member
    2023 Tundra Platinum
    Those 17s or 18s? Looks great!
  14. Aug 15, 2023 at 8:24 AM
    #3584
    iiawah808
    Oahu, HI
    Looks really good. I was hesitant on bronze wheels with the lunar rock. Kick myself every time I see it.
    I saw the new RRW Monoforged wheels and man they look good and light too. Can’t afford TE37’s so the RRW’s might end up being the new wheels.
  15. Aug 15, 2023 at 9:30 AM
    #3585
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    37/12.5/17 Toyo R/T Trail nice and dirty!
  16. Aug 16, 2023 at 6:08 AM
    #3586
    22NETundra
    22NETundra New Member
    22 tundra TRD Off road
    TRD OEM 3 inch lift
    Good morning! I am getting my TRD OEM 3 inch lift installed today by my dealer so i am extremely excited to get going on my overland build and will be starting a youtube channel for tall of the work i am going to be doing to it along with how too's for the work i will be doing myself for other beginners.
    I am looking for new tires though and i have been down the rabbit hole on 5 different tire options currently and hoping i can get help for you guys!
    285/75-18 Goodyear Wrangler DuraTrac
    295/70-18 Mickey Tompson baja boss
    295/70-18 or 35/12.5/18 TOYO OPEN COUNTRY A/T III
    35/12.5-18 BF KO2
    285-75-18 YOKOHAMA GEOLANDAR A/T XD
    PapaDave418 likes this.
  17. Aug 16, 2023 at 6:51 AM
    #3587
    Ransom122
    Ransom122 New Member
    22 Tundra SR5
    What’s the biggest tire you can have without a lift? 34 or 35?
  18. Aug 16, 2023 at 6:56 AM
    #3588
    Joshuak175
    Joshuak175 New Member
    How’s the on road ride quality compared to stock?
  19. Aug 16, 2023 at 8:57 AM
    #3589
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    If you would, post a photo of your upper control arms they install. I want to see how they look, thanks
  20. Aug 16, 2023 at 9:15 AM
    #3590
    EveryDayEnthusiast
    EveryDayEnthusiast New Member
    Someone needs to let me know a shop that has these in stock!
    iiawah808 likes this.
  21. Aug 16, 2023 at 6:13 PM
    #3591
    alaska_bou
    alaska_bou New Member
    Dobinsons IMS suspension upgrade with Toyo Open Country AT3 in 285/65-20, 20" Toyota TRD wheels and Spidertrax 1" spacers. Rides BETTER than stock, even with the new 10-ply rated tires! Two inches of lift was perfect for what I wanted and avoided the need to replace axles, upper control arms, add diff drop, extend break lines, etc. Turned out great, just need to add a tonneau and its done.
    Lebo, Brian422, jacquesc and 11 others like this.
  22. Aug 18, 2023 at 3:01 PM
    #3592
    wmsvol88
    wmsvol88 New Member
    North FL
    2023 Tundra Crewmax Platinum Hybrid 4X4
    TRD Lift kit, BFG KO 35's, window tint, spray-in bed liner, Undercover Flex
    NEW owner here. After much, much reading (thanks to many on this Forum), went with TRD Lift Kit, 18" TRD Pro wheels and 35" BFG KO2's. The stance, ride and handling are FANTASTIC! Night & Day difference vs. stock…no rubbing. Now I need a dang step-ladder to get in!
    Cheers - everyone have a good weekend!
    White3actual, dan81, ytank1 and 14 others like this.
  23. Aug 18, 2023 at 3:02 PM
    #3593
    Breathing Borla
    Northern Illinois
    well done !!
    color match those flares and your wheel and tire combo will really pop!
  24. Aug 18, 2023 at 3:03 PM
    #3594
    Wood-Dro
    Wood-Dro New Member
    That is sexy!
    wmsvol88 likes this.
  25. Aug 18, 2023 at 3:06 PM
    #3595
    wmsvol88
    wmsvol88 New Member
    North FL
    I agree! What is a good recommendation to have these done…take it to a professional auto body shop? TY
    Breathing Borla likes this.
  26. Aug 18, 2023 at 3:30 PM
    #3596
    Breathing Borla
    Northern Illinois
    yes , just go to a good reputable local auto body shop and they can remove, prep, and color match the ones you have, no need for new parts. They can even remove them and work on them while you still drive around then reinstall once cured so there isn’t much down time
    here is my platinum with that done, see how the wheel and tires look bigger than they are and pop, those are only p rated 33”s , your 35s will look enormous
    Yaboy likes this.
  27. Aug 18, 2023 at 5:36 PM
    #3597
    PapaDave418
    Dave
    North Idaho
    3rd Gen Limited TRD
    I like it! Thanks for the pictures of the UCA’s. What is Toyota charging for the lift? 3”?
    Do they do rear?
  28. Aug 18, 2023 at 6:39 PM
    #3598
    wmsvol88
    wmsvol88 New Member
    North FL
    Thanks, I really enjoy cars & trucks in general…not to mention parts, etc.
    Parts: I used a 15% off coupon on parts with my local dealership and they matched the ordering online price from Sparks - approx. $2,6k
    Good luck!
  29. Aug 18, 2023 at 7:47 PM
    #3599
    frostymeds
    frostymeds New Member
    Do you have any more pics of this setup?
    I’m thinking about getting the same wheels on 37s
  30. Aug 19, 2023 at 6:24 AM
    #3600
    wmsvol88
    wmsvol88 New Member
    North FL
    Really like the set up you have!
