04-06 Steering Knuckle Swap on 2001
Discussion in '1st Gen Tundras (2000-2006)' started by metalpete, Jul 3, 2023.
  1. Jul 3, 2023 at 8:49 AM
    metalpete
    metalpete [OP] New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    All this talk on the Solo LCAs has me looking into swapping my steering knuckles to a 2006, in order to accommodate the larger LBJ's.
    On the surface, it seems like it should be a plug'n'play scenario...if I can find a nice(r) set at one of the junkyards, that is. Is my thinking correct, or are there other caveats to this? Could I also use Sequoia knuckles from the same years? Might be more of those than Tundras at the JY.
  2. Jul 3, 2023 at 10:39 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Sub'd
  3. Jul 3, 2023 at 12:20 PM
    metalpete
    ID
    Dang, what to do with all these replies!
    Looks like I may just trial and error this thing. There's a 2006 and 2004 about 30 minutes away at a pick-a-part, so maybe I'll get some free time (some day) and take a look. Would be awesome if the knuckles and hub assembly/bearing are in good shape, too...
  4. Jul 3, 2023 at 2:23 PM
    metalpete
    ID
  5. Jul 3, 2023 at 3:53 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    2004 knuckle (LH) 4320235070
    2005 (LH) - 4320234030
    (No pic...sorry)
    It appears that the knuckle change is for trucks built after 08/2004.
  6. Jul 4, 2023 at 8:09 AM
    @w666 you've got two left hands there...
  7. Jul 7, 2023 at 8:56 AM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    2004 RH - 43201-34030
    2004 LH - 43202-34030
    I'd check out Heavy_friction_works on instagram. He sells Rebuilt OE spindles with total chaos spindle gussets installed. He quoted me $950 +tax and shipping for a pair last year.
    metalpete[OP] likes this.
  8. Jul 7, 2023 at 9:02 AM
    metalpete
    ID
    Thanks for the help, fellas, but I'm not looking to buy bare spindles from Toyota. I would still have to buy the hub, bearings, and get them pressed in. At that point I can buy the brand new spindles with assembled hub & bearings from that 209yota1 website posted above.
    I'll check out that Heavy Friction Works, though! Appreciated.
    JasonC. likes this.
  9. Jul 7, 2023 at 2:37 PM
    Does that include new bearings too?
    Edit- based on the picture it looks like it does.
    TX-TRD1stGEN and metalpete[OP] like this.
  10. Jul 7, 2023 at 2:44 PM
    metalpete
    ID
    Sweet! I'll have to reach out to him asap and see what his price is w/ the hub assembly.
  11. Jul 8, 2023 at 8:10 AM
    I'm gonna ballpark $1,200/ea, which is probably about half the actual cost.
  12. Jul 8, 2023 at 8:49 AM
    metalpete
    ID
    Most likely. The others I'm looking at are $1340, but that's with adding the removable dust shield. The hubs allow the bearings to be easily replaced, too. No more pressing.
  13. Jul 8, 2023 at 4:37 PM
    digitalferg
    digitalferg New Member
    Wandering the Wild West
    2006 Tundra DC TRD 4x4
    Say what now??? There's some place selling a 1G Tundra replacement spindle/knuckle that has some sort of conversion that allows for "easy", non pressed in bearings? Are they using some hybrid 2G tacoma style spindle/knuckle or something? Do you have a link? I'd love to see this.
  14. Jul 8, 2023 at 5:22 PM
    metalpete
    ID
    Yeah man.
    Ya mon. I posted the link above but here it is again.
    https://209yota1.com/products/pre-assembled-steering-knuckles-add-hubs-pair-tundra-and-sequoia/
    Maybe I'm reading it wrong, but it sure sounds like the way we're describing.
    FirstGenVol and des2mtn like this.
  15. Jul 8, 2023 at 5:24 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I'd check if they'll accept the smaller spindles as a core unless you're going to eat the $400 core charge. Probably will, but you never know. Cool they offer an option to have them ready to go with gussets too.
    metalpete[QUOTED][OP] likes this.
  16. Jul 8, 2023 at 6:05 PM
    nickrick78
    nickrick78 New Member
    Pittsburgh PA
    2004 DC
    The 209yota1 knuckles have factory style pressed bearings and hubs. What they're saying is you can replace your wheel bearings without needing to press anything by using their knuckle assembly and replacing the whole unit.
    digitalferg likes this.
  17. Jul 8, 2023 at 7:24 PM
    metalpete
    ID
    See, I've read that same sentence a hundred times and it feels like it could go either way. Plus it seems a little ridiculous to swap a knuckle every time... of course, it's not like we're replacing wheel bearings in our trucks all the time, so it could make sense for a "once in a truck life" job.
    If only they would respond to my emails, lol, I'd have the answers to my questions.
  18. Jul 8, 2023 at 10:33 PM
    digitalferg
    This is the way I'm reading it as well. Plus the fact that the pics show just standard 1G knuckles with pressed in hubs/bearings (although, interestingly, they seem to use the same pics for all their offerings and they've got manual wheel hubs in them).
  19. Jul 9, 2023 at 6:05 AM
    nickrick78
    Pittsburgh PA
    2004 DC
    It definitely could be worded better. But since they say
    "You can drive with confidence knowing that the wheel-bearing was properly supported during installation"
    and
    "new KOYO wheel bearings, Genuine seals, new wheel studs, and remanufactured wheel hubs"
    This tells me they're pressed together just like factory. They just do the "hard part" for you to make it an easier DIY.
  20. Jul 9, 2023 at 6:13 AM
    But have they changed something that will allow me to swap the bearing myself if it goes out in the future? I keep reading the link trying to figure it out.
    These bearings seem to last a long time thankfully. We've only had a few people have to replace theirs.
  21. Jul 9, 2023 at 6:23 AM
    nickrick78
    Pittsburgh PA
    2004 DC
    No they aren't doing anything revolutionary.
    "Turn a troublesome wheel-bearing maintenance job into a quick knuckle swap."
    They're doing what Moog and Dorman do with lots of other vehicles. Selling a knuckle assembly so the average DIYer can easily do the job.
  22. Jul 9, 2023 at 7:43 AM
    metalpete
    ID
    Well, I've convinced myself to do the damn thing regardless, but my new concern is making sure my camburg ucas will work with the later model knuckle.
    Seems like it would because the uca model goes 00-06, but I'm also seeing that 07's might have a similar knuckle and camburg has a different size uca for 07's. As long as the opening on knuckle isn't too big, the post for the uniball will be fine...
    FirstGenVol likes this.
  23. Aug 15, 2023 at 4:07 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    @metalpete did you ever get any answers from the vendor or end up pulling the trigger on these “easy button” knuckles/spindles?
  24. Aug 15, 2023 at 6:34 AM
    metalpete
    ID
    I did get a response, but they only answered part of my question lol. I've had to put this on the back burner for a bit, but I'm hoping I can at least get everything ordered by the end of the year.
    JasonC.[QUOTED] likes this.
