2023 Tundra Platinum wheels on 1st gen Tundra 2004 Limited Double Cab
Discussion in '1st Gen Tundras (2000-2006)' started by elordude, Aug 8, 2023.
  1. Aug 8, 2023 at 12:24 PM
    elordude
    elordude [OP] New Member
    Harry
    2004 Tundra Limited Double Cab
    I would like to install a set of 2023 Tundra Platinum Rims (stock tires) on my 2004 Tundra, bolt pattern is the same ( 6×5.5″ (6×139.7mm) but hub bore is different. Do i need to make any modifications or need sapcers for them to fit?
    2023 hub bore is 95
    2004 hub bore is 106.1
    regards
    harry
  2. Aug 8, 2023 at 12:26 PM
    elordude[OP] and KNABORES like this.
  3. Aug 8, 2023 at 12:27 PM
    Abort!!!
    Elevatorguy and elordude[OP] like this.
  4. Aug 8, 2023 at 1:07 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    You'll need m12x1.5 nuts for spacers to hub and m14x1.5 for wheels to spacer.
    Hub bore and wheel studs are different.
    flyfisher and shifty` like this.
  5. Aug 8, 2023 at 1:19 PM
    Damn that pricing is a hell of a lot better than what I'd seen previously, which was digging into the triple-digits per wheel.
    Good company to buy from, quality parts?
  6. Aug 8, 2023 at 1:24 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Yes. They're the owner/manufacturer of Bora.
    Pricing may have gone up. They will do spacers on 1mm increments for perfect fitment.
    elordude[OP] and shifty`[QUOTED] like this.
  7. Aug 8, 2023 at 2:40 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    They are legit. I’m running 3/4” steel spacers up front from them.
    shifty` likes this.
  8. Aug 10, 2023 at 9:33 PM
    Pparker0
    Pparker0 New Member
    Philip
    2003 Tundra TRD
    i got a great deal on a set of take offs from a 2023 and ended up in the same spot as i only looked at lug pattern and did not consider hub size or lugs. Had a set of adapters hub centric and lug centric from wheeladapter.com. $365 for 4 adapters shipped up to 2" still ended up being cheaper than a new set of tires for me
  9. Aug 11, 2023 at 3:57 AM
    how’s it look? Pics?
    Pparker0[QUOTED] likes this.
  10. Aug 14, 2023 at 6:11 PM
    Pparker0
    Pparker0 New Member
    Philip
    2003 Tundra TRD
    Just got home from working all weekend, so here's the best pictures I have for now, will take more in the morning.IMG_20230814_210550452.jpg IMG_20230814_200553073.jpg IMG_20230814_200618634.jpg
    KNABORES likes this.
  11. Aug 14, 2023 at 6:12 PM
    Looks like it worked out. I would dig some of the new pros on my 2000 TRD
  12. Aug 14, 2023 at 6:13 PM
    Alloy ... be careful with your torque, and be sure to check them closely for cracks every time you've got the wheels off.
  13. Aug 14, 2023 at 6:17 PM
    Yeah, ask me how I know…
  14. Aug 14, 2023 at 6:35 PM
    Pparker0
    Pparker0 New Member
    Philip
    2003 Tundra TRD
    6061 t6 aluminum
  15. Aug 15, 2023 at 6:03 AM
    6061 aluminium alloy (Wikipedia)
    6061 (Unified Numbering System (UNS) designation A96061) is a precipitation-hardenedaluminium alloy, containing magnesium and silicon as its major alloying elements. Originally called "Alloy 61S", it was developed in 1935.
    If it's not steel, you gotta worry about cracks. Even with steel or cast iron, you need to be worried about cracks, but ... probably not at the level any of us will be torqueing on things.
    Honestly, if you plan on any abuse, you really want to use steel for this stuff. Strut spacers, wheel spacers, lifting/lowering blocks, etc.
  16. Aug 15, 2023 at 6:19 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Those look pretty thick, 2” spacers?
