Best route to run RCAs from headunit to center console area?
Discussion in 'Audio & Video' started by Black, Aug 13, 2023.
  1. Aug 13, 2023 at 2:02 PM
    Black
    Black [OP] Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Eventually, I’ll get the amp, speakers and subs installed.
    Had to replace my Sony head unit today with a factory replacement and figured I’d run my RCAs down to the center console so I don’t have to pull the stereo again.
    Well it is about 110* in the garage and I could not find an easy route down. With just the head unit installed. I was soaked in sweat and did not feel like fooling with it too much.
    where is the best pass through on a 2014.
    There are a couple holes on each side of that plastic box just under the headunit that light would pass through but not big enough for the RCA heads to pass through.
  2. Aug 13, 2023 at 2:23 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    The best way is to pull the silver surround out, but that requires this.....
    I didn't go that route.
    It took some time to 3 pair back, behind, and around the climate control years ago, but it can be done..
    There isn't much room though.
    Another way, if they are long enough, is to run them down around the heater vents and tuck them up under the console..
    You'll find a 3' HVAC duct tie-down it is perfect for fishing cable though the dash..
    [​IMG][​IMG]
  3. Aug 13, 2023 at 4:24 PM
    Black
    Great googly moogly!
  4. Aug 13, 2023 at 5:27 PM
    Pull the trim piece above the glove box and you can reach in there and fish them down towards the passenger side floorboard.
  5. Aug 13, 2023 at 5:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I originally ran mine passenger side tracks. I always had a high frequency hum. Then I read a post on here about the harness in there that caused it. Ran the rca's down center console to back and hum is gone.
  6. Aug 13, 2023 at 5:42 PM
    Black
    Tips to removing that trim piece?
  7. Aug 13, 2023 at 6:26 PM
    It just pops out. It's held in with clips.
  8. Aug 13, 2023 at 6:32 PM
    Black
    Perfect. Was not sure if any other pieces need to be removed to let it pop out
  9. Aug 13, 2023 at 6:53 PM
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    I see your question but taco tunes makes a pnp kit…..
  10. Aug 14, 2023 at 8:35 AM
    Black
    Not for JBL systems that I can find
