2022 Tundra vs 2022 F-150 opinion?
Discussion in '3rd Gen Tundras (2022+)' started by john1062, Dec 3, 2021.
  1. Aug 13, 2023 at 9:56 AM
    #3691
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Tundrastruck91 likes this.
  2. Aug 13, 2023 at 10:49 AM
    #3692
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    Do you have the results on long term storage with Ethanol?
    All research I have done on treatments and stabilizers including 360- Stabil Protection show Ethanol gums up all engines if left long term, even if treated.
    The best experiment I have come across online is this one.
    https://www.youtube.com/watch?v=iWL7p0Pnb8Y&t=1640s
    Many brands tested on parallel engines after 19 months.
    They all failed including Sea Foam.
    Only one of the engines ran and did not get gummed up - 93 octane No Ethanol Gas No treatment.
    Tundrastruck91 and Bannerman like this.
  3. Aug 13, 2023 at 2:34 PM
    #3693
    Breathing Borla
    AZ
    ok I misunderstood totally
  4. Aug 13, 2023 at 5:46 PM
    #3694
    frozen_tundra
    frozen_tundra New Member
    2022 Tundra SR Crewmax Black
    I understand about the mileage thing, however since 90% of my driving is 75 on an interstate, the fuel savings really do seem to be 25% I'm seeing. It's substantial, I know that. I am very surprised and happy with it.
    As for the towing - my point of reference was towing on interstate, 95 degrees out and humid as hell, car full of kids and gear too. It was definitely cutting power (3.5 EB). The 3.4 Tundra last summer when it was fairly new, same trip, maybe 90 out but was just as humid, didn't cut power one bit or need to downshift. I think the Tundra cooling is better, when you pop the hood on both, the Tundra sure had a ton more open area for cooling things down. So it makes logical sense to me.
  5. Aug 13, 2023 at 5:54 PM
    #3695
    Bannerman
    Bannerman Tasteful Thickness
    Johnson
    Don’t know man, may have been low on coolant or something. I tow my much bigger boat with truck full off gear in 100 degree heat and NC humidity.
  6. Aug 14, 2023 at 6:08 AM
    #3696
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Cant hide money! Good looking rig. GW 236?
  7. Aug 14, 2023 at 6:12 AM
    #3697
    Bannerman
    Johnson
    :rofl:216
  8. Aug 14, 2023 at 8:01 AM
    #3698
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    The real wealth in that pic is the growing family. Congrats on the new little one, @Bannerman :cheers:
    PomDad, Whitatu19, akmerle and 2 others like this.
  9. Aug 14, 2023 at 8:13 AM
    #3699
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I stored a car with about half a tank of E10 for over 2 years and had no issues with it. Just put some fuel stabilizer in the tank and ran it for 5 minutes or whatever they recommend to help mix it.
  10. Aug 14, 2023 at 8:15 AM
    #3700
    Bannerman
    Johnson
    Thank you Sir, I am blessed for sure.
  11. Aug 14, 2023 at 10:45 AM
    #3701
    borla123
    borla123 The Pits
    Ontario
    How old was the car? What year? Fuel Injected or Carbs?
    Older car fuel systems were not built for Ethanol. It destroys the fuel lines and other fuel system parts.
    You can see in that video that even the motor with Stabil 360 ran good but when he took the carb bowl off their was jelly everywhere.
    The Jelly was also on the column leading up the hole where the gas goes through.
    But hadn't blocked it ...yet.
    One of the biggest problems with boats is when the rubber fuel line starts disintegrating on the inside. Engine starts and runs but when you try to run it full throttle it bucks and wants to die. Not enough gas.
    Blockage from disintegration of the line. Just maybe one problem.
  12. Aug 14, 2023 at 11:14 AM
    #3702
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Fuel injected. Didn't realize the question related to older carbureted vehicles.
    My dad only runs ethanol free in his boat to keep from gumming up the fuel filter.
  13. Aug 14, 2023 at 12:07 PM
    #3703
    borla123
    borla123 The Pits
    Ontario
    It affects all vehicles more so older ones.
    The question was followup on an earlier discussion with Bannerman about boats and the importance of using 93 Octane Ethanol free.
    Well I did not realize he was lucky to run his boat year round. 8^0
    There is no more Ethanol Free gas in Canada or the US not even in the premium gas.
    This is federal decision.
    Not even out west.
    https://www.calgarycoop.com/our-stories/transition-to-e10-ethanol-blended-gasoline/
    So if you have anything that you store over the winter that you used to put premium gas Ethanol free in before. It now contains Ethanol too. This was a surprise to me when I found out a couple months ago.
  14. Aug 14, 2023 at 12:20 PM
    #3704
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Man, what a load of crap. It's been a few years since I worked in a refinery so I'm out of touch with that stuff these days.
  15. Aug 14, 2023 at 12:56 PM
    #3705
    borla123
    borla123 The Pits
    Ontario
  16. Aug 14, 2023 at 1:07 PM
    #3706
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I read that story a few days ago...... Pretty interesting! I have a set of brother and sister in-laws that went all in with 2 Tesla's and their story is very similar. Tesla is better than the rest in the electric world, but still has issues and when they have issues they are expensive!!!!
  17. Aug 14, 2023 at 2:58 PM
    #3707
    mass-hole
    mass-hole New Member
    The tundra cooling system is for sure better. Ecoboosts cooling has always been undersized and was absolutely terrible in the 2011-2014 trucks. They spec the bare minimum to pass SAE J2807
  18. Aug 14, 2023 at 4:19 PM
    #3708
    Jaxyaks
    Jaxyaks New Member
  19. Aug 14, 2023 at 4:27 PM
    #3709
    Breathing Borla
    AZ
  20. Aug 14, 2023 at 5:35 PM
    #3710
    mass-hole
    The tundra does make more low end than the F150. Its 479 at 2400 rpm whereas the F150 was always peaking at ~3000.
    The SR makes its peak torque at 2000 rpm but its the same as the higher trims, they just artificially cap the SR there at 406 and dont let it keep climbing to the full 479.
    its all in the tuning though. My 2014 Ecoboost was making over 500 ft-lbs at 2000 rpm with a tune. I could pull some hills in 6th gear at 2000 rpm
  21. Aug 15, 2023 at 5:04 AM
    #3711
    borla123
    borla123 The Pits
    Ontario
    You know, if the manufacturer and government ever get their acts together on what they sell for and the rebates, and find a sweet spot for the average buyer. I’d probably be an ideal candidate for one of these Electric trucks. The daily runner is a 4Runner and I use my Tundra to haul stuff and travel between my house and cottage. Spring through Fall. I could put a charger at my house and the cottage. The distance between is 1 ½ hrs about 125 kms and I travel when no traffic. So “theoretically” there should be no charging anxiety. The Lightning could be capable with a lift but the prices right now make no sense. I also never buy on the bleeding edge; I am biased as I used to provide consulting to bleeding edge companies. Right now the vehicles and the charging networks if you are going to be using them, are both bleeding edge.
    edit**
    but its going to have to be a hell of a deal.
    I just got back. I consider the engine in my old mule an engineering marvel.
    Imagine if it had like a 8 or 10 speed
    in_the_mud likes this.
  22. Aug 15, 2023 at 1:54 PM
    #3712
    DrZoidberg
    DrZoidberg New Member
    Dave
    Tesla MYP
    Damn, Ford sales are down. Deep discounts coming!
    Kap1, eharri3, MTRock and 2 others like this.
  23. Aug 15, 2023 at 3:11 PM
    #3713
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Can't afford not to buy it at that price.
  24. Aug 15, 2023 at 4:16 PM
    #3714
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    It looks like a monstrosity so I have to assume they put the decimal in the wrong place. Should be $26,792.
  25. Aug 15, 2023 at 9:03 PM
    #3715
    mass-hole
    Imagine trying to park that thing. It’s ridiculously wide and long. parking my 157” wheelbase F150 is enough of a pita.
    Cpl_Punishment likes this.
  26. Aug 16, 2023 at 4:21 AM
    #3716
    borla123
    borla123 The Pits
    Ontario
    Looks like a toy compared to what showed up at the cottage Monday.
    You should of seen the skill in turning it around to go back out.
    A three point turn.
  27. Aug 16, 2023 at 12:30 PM
    #3717
    TRDoffroadPRO
    TRDoffroadPRO New Member
    2023 Hybrid CM Limited TRD OFR
    Post Malone owns one and he said on Rogan that he has to take up two parking spots.
    Polo08816 likes this.
  28. Aug 17, 2023 at 1:17 PM
    #3718
    DrZoidberg
    Dave
    Tesla MYP
    Got about 30 mins into my drive to trade the raptor for a crv. Turned around and came home. Just couldn’t do it. Is it weird to get like I’ll over trading something in? 10+ times in the last 2 years I’ve never had it happen.
    damn you ford
    Kap1 and WinterWarlock21 like this.
  29. Aug 17, 2023 at 1:20 PM
    #3719
    DFS
    DFS New Member
    2022 Capstone Tundra
    Damn that would have been an odd trade.
  30. Aug 17, 2023 at 1:23 PM
    #3720
    Bannerman
    Johnson
