Trans question for 2021 SR5
Discussion in '2.5 Gen Tundras (2014-2021)' started by eagleguy, Aug 11, 2023.
  1. Aug 11, 2023 at 11:48 AM
    eagleguy
    eagleguy [OP] New Member
    What does the "S" mean on the shifter next to drive? Is this sport mode or is it like the tow mode switch?
  2. Aug 11, 2023 at 12:01 PM
    pursuit2550
    pursuit2550 New Member
    Sport. You can manually shift the truck. But there is nothing sport about it.
  3. Aug 11, 2023 at 12:03 PM
    pursuit2550
    That trick I know about. :thumbsup:
    IsaiahCanada and Sierradevil like this.
  4. Aug 12, 2023 at 8:57 AM
    2mchfun
    I call it "sity" cuz I roll around town locked out of OD.
  5. Aug 12, 2023 at 9:06 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    S does not stand for Sport. So you can stop being disappointed, lol.
    It stands for Sequential. It is the Sequential shift mode. You can choose to lock out higher gears (like OD gears when you're towing, for example). That's it.
    JDR76, nobodyintexas, WILLINH and 7 others like this.
  6. Aug 12, 2023 at 5:15 PM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Sequential
    2mchfun and GODZILLA like this.
  7. Aug 12, 2023 at 8:09 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Sequential like the last few said. It just limits you to a gear. Move into S and 4th gear and your truck will drive normal in gears 1-4. Won’t shift to 5th or 6th.
    2mchfun, Tripleconpanna and GODZILLA like this.
  8. Aug 12, 2023 at 9:15 PM
    EmergencyMaximum
    I call mine snail mode. When I climb out of steep driveways, I go slowly, but she would shift into second, then first, then second again, then first again.
    The reason for that is 4.6L is powerful engine and I ease off a little when in second, so that's why she goes back to first, but it's very close to second because I have tow package and it comes with 4.10 final drive, so first and second are actually pretty close.
    I mean, there is plenty of power to blast out of there into space, but if there are cars ahead, you cant see very well once you climb out from the driveway. The whole situation is pretty tricky, so I just snail into first gear on the shifter and slowly crawl up. Like a crab.
  9. Aug 12, 2023 at 11:18 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Someone recently taught me on here that the S mode will make your trans shift way better . Like a machine, not a thinking computer
    2mchfun likes this.
  10. Aug 14, 2023 at 4:26 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Not sure how it would. It only limits the gears. It'll still downshift like normal.
    EmergencyMaximum likes this.
  11. Aug 14, 2023 at 4:54 AM
    EmergencyMaximum
    It also disables learning in snail mode.
