Status of ball joints
Discussion in '1st Gen Tundras (2000-2006)' started by Hartwell, Aug 11, 2023.
  1. Aug 11, 2023 at 5:56 PM
    Hartwell
    Hartwell [OP] New Member
    2004 Double Cab 4x4 SR5
    Does the dark spot here indicate ball joint leaking grease? How concerned should I be? '04 DC 4X4 w/ 170,000. Original LBJs replaced in recall around 20,000 miles with OEM Toyota parts
  2. Aug 11, 2023 at 6:14 PM
    You're overdue. They should be replaced every 100k.
    Just buy new ones. $200 for peace of mind.
    208Tyler likes this.
  3. Aug 11, 2023 at 6:29 PM
    Yep, leaky BJ; time for new ones. Replace in pairs.
  4. Aug 11, 2023 at 7:34 PM
    Tundra1986
    Tundra1986 New Member
    2003 Tundra SR5 4x4
    I’d change them …. I’m currently in the process of changing mine. A little advice , give them a good spraying of PB Blaster. I broke a bolt inside the steering knuckle and now $600 poorer lol to have it fixed. Had to order a new knuckle bearings seals and have it all pressed in. Good luck !
    JasonC. likes this.
  5. Aug 11, 2023 at 8:17 PM
    Mr Badwrench
    Mr Badwrench New Member
    They destroy a lot of stuff when they fail. A lot of stuff. You can check the play in them with a pry bar. If there is any, just swap them and while you're at it, change out your sway bar bushings. Sway bar bushings are pretty cheap. Thankfully you don't have too much rust!
  6. Aug 13, 2023 at 2:51 PM
    Hartwell
    Thank you. Think i'll get 'em done.
