  1. Aug 11, 2023 at 3:29 PM
    centex
    centex New Member
    Truck stuff. Bought a trailer for the rzr. 5.29’s delivered today. Gonna be a long two weeks staring at those until the shop can get to them.
  2. Aug 11, 2023 at 3:36 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Daggonit if I didn't get to do the $109.99 27F battery deal at Costco today! Thanks guys for posting that here. Original battery was DEAD.
    Thankful that it died in my driveway and wasn't stranded. AND I got to test out my Noco GB50! Started the truck without trouble.
    Edit to add: this may cost me one of those pretty battery tie-downs you guys have. :rolleyes:
  3. Aug 11, 2023 at 4:15 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Yup same wheels. My buddy has the polished dakars on his mgm Tacoma and it looks badass.
  4. Aug 11, 2023 at 4:21 PM
    CaptRussia253
    Ruslan
    Replaced the front rotors and pads.
  5. Aug 11, 2023 at 9:42 PM
    endagon
    endagon New Member
    16 Tundra SR5 5.7
  6. Aug 11, 2023 at 9:48 PM
    skniper
    skniper New Member
    Where did you get the Limited fake wood trim? My '16 Ltd has the super glossy really bad fake wood trim, it's bad. I don't mind the fake wood look, it helps break up all the black/silver/gray a bit. Just need less fake gloss look.
  7. Aug 12, 2023 at 2:24 AM
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Found it on EBay through a parts recycler.
    skniper[QUOTED] and bulldog93 like this.
  8. Aug 12, 2023 at 3:31 AM
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    What did you use as replacements?
  9. Aug 12, 2023 at 4:43 AM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    I installed my Kenwood DMX709S in my 2021 SR on Wednesday. It took me longer than it should have because I’m dealing with a herniated disk that makes it very hard to do much of anything. But a somewhat leisurely afternoon in the garage was good for me.
    I was able to flash the Maestro with custom functions for the steering wheel controls - something as simple as a quick press of the hold button to pause makes a big difference to me. Each button can be programmed with up to 2 functions - one for a short press, and a different function for a long press.
    As far as wiring, everything was plug and play, except I had to connect wires for the antenna amplifier, reverse trigger for the backup camera, and I had to ground the parking brake trigger wire to the head unit chassis.
    I was a little disappointed that I wasn’t able to keep the factory USB port. To be fair, Crutchfield said it may or may not work. Since I use it every time I’m in the truck, I just pulled the head unit’s USB cables out through a switch blank and connected my lightning cable to it. Wireless CarPlay would have been useless to me as my dash cam connects to my phone through Wi-Fi.
    I also gained some features - on-screen display of individual tire pressures and temperatures, as well as 2 customizable screens of gauges that can be displayed. For those that tow, one of the gauge options is trans temp.
    Overall I’m happy with the system. I’m not an audiophile, and I don’t need a big screen. I just needed functioning CarPlay since all physical controls (steering wheel as well as the volume knob on the head unit) stopped working with CarPlay after updating my phone to iOS 16.5 and neither Apple nor Toyota was willing or able to come up with a fix.
    Sorry for the weird color of the pictures - they were taken in my garage with the fluorescent lights on.
  10. Aug 12, 2023 at 4:55 AM
    Looks good. I replied to your other post about the USB. There is a cable that allows it to work.
    bulldog93 likes this.
  11. Aug 12, 2023 at 5:08 AM
    centex
    centex New Member
    I know what’s going on my Christmas list.
  12. Aug 12, 2023 at 5:45 AM
    Tripleconpanna and bulldog93 like this.
  13. Aug 12, 2023 at 9:42 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Dropped the truck off at the dealer AGAIN. My car alarm issue was resolved with the battery, but now I have a small leak coming from behind the parking brake when it rains. The dealership called me and said they think it's the windshield's seal, but they'll need to do some more testing over the weekend to verify.
    Really hoping this is just a stream of bad luck that will be over soon because I'm really down right now.
    willy and bulldog93 like this.
  14. Aug 12, 2023 at 9:54 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Chin up, Conrad! It will get better!
  15. Aug 12, 2023 at 10:10 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Please update us when you can. I’ve been chasing a water leak from this general area for years now with no resolution.
  16. Aug 12, 2023 at 10:35 AM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Will do! I originally thought it was the sunroof drain (I figured they might have popped off the a pillar trim when chasing my car alarm issue since I have a dash cam), but both them and I have poured a ton down the driver side drain and no water came through. If it's worth much, the leak is right behind the parking brake near the nut for the kick plate.
  17. Aug 12, 2023 at 10:43 AM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    gave her a quick bath.
  18. Aug 12, 2023 at 11:08 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Wow, that's a new one for me... My '21 has a weird condensation issue w/the windshield. I figured it's just from being here on the coast and having some changes to the HVAC over the years. My '08 does not behave like the '21 in that regard, so who knows maybe something isn't right w/the seal around the windshield on mine. I do recall seeing something about the QC on windshield installs from the '20s - early '21s, but mine is late '21 so I kinda just blew it off...
    Keep us posted, and I'll probably have the dealer peek at that on my last 2yr-24k service.
    Hope yours gets resolved!
  19. Aug 12, 2023 at 11:14 AM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Interesting! I purchased my tundra the day it was delivered in Oct '21, so it was an early '21 model. I don't think they're going to fix it today and they're closed Sunday, but I should have an update on Monday.
  20. Aug 12, 2023 at 11:34 AM
    VadersTundy
    VadersTundy New Member
    2019 black sr5 crewmax
    Had 275/70r18 Cooper at3 xlt tires put on. Also not pictured I put powerstop front rotors and pads on.
  21. Aug 12, 2023 at 1:41 PM
    SAGE63
    San Diego County
    Gave her a bath...started as just a spray down...then saw a buch of pollen dots ended up washing it by hand half panel by half panel... damn there went two hours today. edit just check the time 3 hors not 2...lol
    Those 37s do look good....
  22. Aug 12, 2023 at 2:07 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Looks great! What fender flares are you running?
  23. Aug 12, 2023 at 2:22 PM
    kbark
    kbark New Member
    Kevin
    2020 Tundra Cement 4x4
    TSS
    Just ordered. Install date in September
    300BLK, Velocity72, Jaypown and 22 others like this.
  24. Aug 12, 2023 at 3:05 PM
    CaptRussia253
    Ruslan
    R1 concepts. I had them on my gx460 and they worked great.
    rdiddy5 likes this.
  25. Aug 12, 2023 at 3:12 PM
    skniper
    skniper New Member
    FINALLY got around to dechroming some things. This is a Silver Sky Limited that came with LOTS of shiny pieces, hard to look at sometimes.
    Black mirror caps, color matched door handles, plastidipped all the emblems...except the iForce 5.7 badges, I like the black detail already in those. Dipping the the Limited badge was tricky!
    I'm not completely anti-chrome, especially with the Silver Sky where the chrome tends to "blend" a little, just needed to be toned down a lot.
    These are next on the list...I want to upgrade to smoked LEDs (these headlights just suck!) and tone down this grill. Think I'm going with the honeycomb with chrome surround.
    Anyone have a honeycomb grill with chrome surround laying around??:)
  26. Aug 12, 2023 at 3:21 PM
    VadersTundy
    Thanks! They are the bushwacker oe style flares.
    DZ_ and RustyShackle323[QUOTED] like this.
  27. Aug 12, 2023 at 5:30 PM
    pkeawe809
    pkeawe809 New Member
    PK
    Westside, Oahu
    2018 Super White TRD 4x4 CrewMax
    ~Chrome Delete interior AJT/Tuff skins ~Driver side Grab handle OEM ~Revesol Leather Steering Wheel ~Front Console upgraded to Limited Leather Trim ~Switched Center Instrument panel from silver to black ~Switched black molding trim pieces to Wood grain ~Wood grain Shift Knob ~LED interior lights- meso customs ~Husky X-act Front Driver and Passenger Floor-mats ~Clazzio Seat covers ~Pedal Commander ~Front Windshield heat protection clear film ~VLEDS Footwell LED light kit-driver and passenger sides ~ESP Under Rear Seat storage bins ~4- Door Speakers- JL C1-650 component speakers ~Front Dash Hertz Speakers ~Zapco ST-4X DSP III 100Watt Component Speaker Amp ~Zapco ST-500XM II 500Watt Subwoofer Bass Amp ~1-Rear 10” Subwoofer and Box enclosure ~Sail panel speakers-Hertz tweeters ~Noico 80 mil Sound deadener on all 4 door panels ~Morimoto Headlights-amber DRL ~Diode Dynamics SS3 Pro Foglights ~OEM Tail lights Hot Tails” option A upgrade by Hot Shot Offroad ~Anytime Front and Rear Camera-Trail Grid Pro ~Precision LED lights-rear bed light, lic plate light ~Retrax Pro XR Bed cover ~Auto Rear tailgate lock OEM ~Repaired rust spot and Repainted Roof 7/22 ~De-badged and removed Stickers ~TRD Dual Exhaust w/black chrome tips ~Valhalla Cat Security Shields-Black powder coated ~Black powder coated TRD skid plate ~Red powder coated front Tow Hooks ~Coachbuilder +2 Shackles 1.25” lift ~TRD Pro Grille ~TRD Pro Skid plate ~TRD front/rear Sway Bars ~Bilstein 6112 front shocks ~Bilstein 5160 rear w/resi ~Nitto Ridge Grapplers 35x12.50R17 ~Icon Alloys Rebound Rims 17x8.5 ~Window Tint
    I have the same cat plates. You're supposed to remove it because you'll have better protection with the plate.
    wiltech[QUOTED] and HulkSmurf14 like this.
  28. Aug 12, 2023 at 7:44 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Damn, that's great to know and makes perfect sense! Ha! I guess I'll remove the cut up leather glove I had sitting inbetween the two skids...ha! Weight reduction, right?!
    pkeawe809 likes this.
  29. Aug 13, 2023 at 7:33 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Took off RCI and Valhalla's skids. Both didn't stand against Boston winters well (which we largely don't have, but the roads are still salt-covered). A lot of powder coated paint flaked off under power washer. Rust everywhere. RCI skid is bent. May need to upgrade it in the future, it seems to be a bit too thin for my use case ;)
    Need to do a lot of prep work and spray in Raptor. Raptor seems to withstand weather odds quite a bit better. I wish I bought them unpainted, would save a day of hard work.
  30. Aug 13, 2023 at 8:17 AM
    OldNo7BoozeBag
    OldNo7BoozeBag New Member
    Jay
    Western Slope, CO
    got the hell out of NY and moved to CO...2100 miles, 48 hrs, stopped twice for 2 or 3 hour naps, and averaged an astounding 12.5 mpg20230804_163111.jpg 20230804_174243.jpg
