Cruzer's Re-Build for the Rubicon
Discussion in '2.5 Gen Builds (2014-2021)' started by Cruzer, Dec 8, 2020.
  1. Aug 7, 2023 at 10:49 PM
    #1351
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Red anodizing turns pink from the sun. I’d got with option 1.
    2mchfun, SAGE63, reywcms and 4 others like this.
  2. Aug 7, 2023 at 10:57 PM
    #1352
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I don't worry about the legality too much but the maintenance is a real chore if you go by the book and properly retorque the bolts every 500 mi.
  3. Aug 8, 2023 at 5:52 AM
    #1353
    Cruzer
    Cruzer [OP] Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Do you go by the book?
    rockmup and 831Tun[QUOTED] like this.
  4. Aug 8, 2023 at 5:56 AM
    #1354
    Sunnier
    Sunny
    San Diego, CA
    I dunno. If I'd known this, I'd maybe have voted the other way. Cruz is comfortable. He could rock pink wheels on his monster truck. :p
  5. Aug 8, 2023 at 5:59 AM
    #1355
    Cruzer
    Cruz
    Sunnyvale, CA
    Plus those are just the rings, which can be replaced at any time. Now I’m leaning towards pink I mean red :D
  6. Aug 8, 2023 at 6:23 AM
    #1356
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    If you don't like the color EZ Off oven cleaner and steel wool will get rid of the anodizing. Rattle cans do wonders also:rofl:
  7. Aug 8, 2023 at 7:04 AM
    #1357
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    For what it's worth I've never found any legality issues running beadlocks (let alone anyone who knows the difference if that matters). As for maintenance I used to check torque on them once a month, but there was maybe two bolts that got slightly loose in all my checks so nowadays it's rare I check them. Hell I don't even remember the last time I checked the torque on any of mine, not to say that's good practice but that it's overplayed them coming loose imo. The only issue I ever had was some tire shops wouldn't balance them, but in Cruzers case that's not an issue anyways.
  8. Aug 8, 2023 at 7:21 AM
    #1358
    Cruzer
    Cruz
    Sunnyvale, CA
    Trigger pulled. Now I have to wait 6-8 weeks.
  9. Aug 8, 2023 at 7:51 AM
    #1359
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Jealousy level maximized
  10. Aug 8, 2023 at 10:20 AM
    #1360
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    No way. I do it before every trip and about every 1,500 miles. The spec is 20 ftlbs and there are always a few loose ones when I remove to retorque them. They're supposed to be done in a crisscross pattern 3 times at 10 then 15 and finally 20.
    Also, I thought I'd be easily able to swap my own tires...... I was wrong. It's easy enough to pop the bead on the outside but I couldn't, for the life of me, pop the inner bead. I tried using a Hi lift jack pushing down on the bead with my truck bumper as opposing force,,,, denied. Ended up having to take 'em to the tire shop to pop the bead. I was at least able to mount my own tires.
  11. Aug 8, 2023 at 10:30 AM
    #1361
    Cruzer
    Cruz
    Sunnyvale, CA
    I'm going to try to pop the bead on the bead grip wheels this weekend so that I can install the stubby valve stems. Since my tire de-beaded (both beads) on the trail I figure I can replicate it. Place the wheel you want to de-bead on the rear axle and on dirt/grass, then let all of the air out. Then back up the truck full lock in the opposite direction of where the wheel is placed. So if the wheel is on rear driver, then turn the steering wheel full passenger and go in reverse. Might have to reverse in the other direction to pop the inner bead - will find out.
  12. Aug 8, 2023 at 12:01 PM
    #1362
    Cruzer
    Cruz
    Sunnyvale, CA
    https://www.youtube.com/watch?v=xBpj95MUiSI
    CaptRussia253 likes this.
  13. Aug 10, 2023 at 10:07 AM
    #1363
    Cruzer
    Cruz
    Sunnyvale, CA
    My last wheeling trip was the final straw that is making me ween my essential functions off of digital. My stupid wireless winch wouldn't work and neither did my air compressor. My air compressor is controlled by an ARB Linx system, which was nice at the beginning when I could specify an air pressure and it would air up or down my tires while I walked away. Nowadays it just brain farts and doesn't know what to do. Many things digital just can't handle the punishment of rough trails and eventually start doing weird shit. So I'm going analog.
    I made a compact version of the Wifey air up system so that I don't have to mount the manifold somewhere else - it's an all in one unit.
    I know I said analog but I got a digital pressure gauge cuz my eyes can't see shit. But of course when I tested it out the pressure gauge automatically turned on, when it detected air pressure, and wouldn't turn off until I released the pressure. Laaaame! So I ordered an analog pressure gauge instead.
  14. Aug 10, 2023 at 10:22 AM
    #1364
    snivilous
    SW UT
    I like your new profile picture and your commitment to the master race of wheels :D
    CaptRussia253 and Cruzer[OP] like this.
  15. Aug 10, 2023 at 10:40 AM
    #1365
    Sunnier
    Sunny
    San Diego, CA
    When you make one that works :rolleyes:, please make another for me.
    SAGE63 and Cruzer[QUOTED][OP] like this.
  16. Aug 10, 2023 at 10:42 AM
    #1366
    Cruzer
    Cruz
    Sunnyvale, CA
    Do you have a single or twin compressor?
  17. Aug 10, 2023 at 10:43 AM
    #1367
    Sunnier
    Sunny
    San Diego, CA
    Twin ARB.
  18. Aug 10, 2023 at 2:03 PM
    #1368
    Cruzer
    Cruz
    Sunnyvale, CA
    :bananadance::bananadance:Ohhhhhhhhhh shiiiiiiitttt! :bananadance::bananadance: Financing on DC approved :spending:
    Just need a (remote) visual inspection and test drive to seal the deal:fingerscrossed:
  19. Aug 10, 2023 at 2:31 PM
    #1369
    SAGE63
    San Diego County
    Is that a rock warrior? like the rims.
  20. Aug 10, 2023 at 2:34 PM
    #1370
    Cruzer
    Cruz
    Sunnyvale, CA
    They are wheels from a rock warrior.
  21. Aug 10, 2023 at 2:36 PM
    #1371
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Rock Warrior package ended in 2013. They never made it in the 2.5 gen
    SAGE63[QUOTED] likes this.
  22. Aug 10, 2023 at 2:47 PM
    #1372
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    :welder:
  23. Aug 10, 2023 at 4:22 PM
    #1373
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Keeping this one stock? :rofl:
    2mchfun, BreyTundy and Tripleconpanna like this.
  24. Aug 10, 2023 at 4:56 PM
    #1374
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Did they get the price down enough for you??
  25. Aug 10, 2023 at 5:45 PM
    #1375
    Cruzer
    Cruz
    Sunnyvale, CA
    Yeah, they went down to where I thought they could go.
  26. Aug 10, 2023 at 7:14 PM
    #1376
    Tripleconpanna
    Congrats, that's awesome!!!! Hope it works out for you...
    2mchfun likes this.
  27. Aug 11, 2023 at 1:28 PM
    #1377
    Cruzer
    Cruz
    Sunnyvale, CA
    I am a new owner of a DC!!! Thanks to @V10Ace for boots on the ground validation - I owe you a bunch of drinks brotha!
  28. Aug 11, 2023 at 2:29 PM
    #1378
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Glad I could help!
    nb_nielsen, 2mchfun, reywcms and 2 others like this.
  29. Aug 11, 2023 at 2:40 PM
    #1379
    daveeasa
    Quick summary for those not following close enough to know the scoop? Trashed a wheel and swapped to a new rig or something else broke or this is the nice truck and the old one is for hammering on the trails or your kid just got a license or ????
    snivilous and SAGE63 like this.
  30. Aug 11, 2023 at 2:46 PM
    #1380
    Cruzer
    Cruz
    Sunnyvale, CA
    This is the new toy. Swapping out parts between the DC and CM. CM returns to full stock. DC frame will get chopped shorter so I can put my current 5.5’ bed on it.
