2nd gen with 3rd gen wheels
Discussion in 'Wheels & Tires' started by bthompson12, Jun 4, 2018.
  1. Jun 4, 2018 at 8:41 PM
    bthompson12
    bthompson12 [OP] New Member
    Bruce
    GA
    22’ Blueprint SR5 4x4
    I wanted to see if anyone had any images of a 2nd gen with 3rd gen trd wheels (grey and black). I have been looking for a set for awhile and I’m ready to pull the trigger. I just installed 5100’s last week so it’s time for new rims and a set of 295/70 r18’sFD5105CE-B120-41B4-8DD6-4EFADB74B468.jpg
    Mountun Goat, Scpringle and Y0TA PR0 like this.
  2. Jun 4, 2018 at 9:12 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Images? There’s more than you could want on the interwebs
  3. Jun 4, 2018 at 9:15 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Like this?
  4. Jun 4, 2018 at 9:19 PM
    bthompson12
    Bruce
    GA
    Yes those rims. Thanks for posting. Hoping for someone with those rims that has a similar setup to mine so I can get a good idea of what it would look like
  5. Jun 4, 2018 at 9:21 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Looks good!
    landphil[QUOTED] likes this.
  6. Jun 4, 2018 at 9:29 PM
    bthompson12
    Bruce
    GA
    Not sure where you’re looking because I can’t seem to find anyone. Seems like 90% of the images are aftermarket wheels
  7. Jun 5, 2018 at 12:12 AM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    I
    I just googled “tundra trd package wheels” and got tons of results... but okay
  8. Jun 5, 2018 at 4:41 AM
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    I went with the reverse my 2015 SR had the stock steel wheels and I picked up a set of 08 SR5 rims for free. Looks better than the stock SR rims , I may get some Black TRD rims .
    Mountun Goat, landphil and Y0TA PR0 like this.
  9. Jun 6, 2018 at 6:51 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I think they will look good. I wanted a set of those black and silver TRD wheels for mine, but never could find any at a reasonable price. I like the "clean" look with the leveled truck and factory rims, but I was also having to buy new sensors as well, which was adding to my cost. The best deal I found would have put me at spending roughly $900 on those factory wheels with new sensors, and I just wasn't going to do that.
    It worked out though, because I got the Vision Warriors that I think turned out better because of the offset, making them stick out just a hair. Ended up getting those wheels and new sensors from Discount Tire for like $600.
  10. Jun 6, 2018 at 7:49 PM
    bthompson12
    Bruce
    GA
    I’ve found some on eBay for around 700 that I’m looking at buying. Probably go with an atturo mt or Yokohama mt similar to the toyo’s. I currently have yo-yo at’s now and they are pretty basic. Not to sound dumb but what sensors are you referring to? These have to be replaced?
  11. Jun 6, 2018 at 7:53 PM
    bthompson12
    Bruce
    GA
    Looks clean. I just like the trd rims because they look more aggressive
    Scpringle[QUOTED] likes this.
  12. Jun 6, 2018 at 8:58 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    TPMS (Tire pressure monitoring system) sensors. Since you already have alloy wheels, your existing sensors could be swapped to the new wheels, but since they are 6 years old, I’d recommend putting your money toward 4 new sensors rather than paying labour to pull them from your existing wheels.
  13. Jun 6, 2018 at 9:15 PM
    bthompson12
    Bruce
    GA
    Oh yeah tire pressure sensors! Yeah I just looked real quick online and found a set of 4 for pretty cheap so I will just order those when I order my wheels
  14. Jun 6, 2018 at 10:00 PM
    Rica25
    Ricardo
    Tulare
    Just yesterday in my home town I seen CM 2011 Limited with TRD wheels and levels out with some Ats
  15. Jul 9, 2018 at 8:48 PM
    bthompson12
    Bruce
    GA
    So I purchased a set of these wheels ($350 brand new) and now I’m trying to decide on a tire size. I posted again in wheels and tires but received 0 responses. Could I fit 295/70 18 cooper discoverer stt pro’s with the 5100’s at top setting? Really hoping someone can help me with this so I can get these ordered
    Rica25 likes this.
  16. Jul 9, 2018 at 8:51 PM
    Rica25
    Ricardo
    Tulare
    I have 5100 at highest setting and just last week installed 295 70 18 Nitto Ridge Grapplers all I had to do was some heating up of the fenders
  17. Jul 9, 2018 at 8:59 PM
    bthompson12
    Bruce
    GA
    Man thanks for the quick reply! I hear people talking about heating it up but have no idea what you mean. Got any photos or what exactly needs to be done
    Rica25[QUOTED] likes this.
  18. Jul 9, 2018 at 9:01 PM
    Rica25
    Ricardo
    Tulare
    The fender behind your fogg light heat it up with a heat gun just make sure you don't melt it just let it get hot enough where you can grab a small wooden stick that's at least 2 feet long and push against the fender while heating it up
  19. Jul 9, 2018 at 9:03 PM
    Rica25
    Ricardo
    Tulare
  20. Jul 9, 2018 at 9:09 PM
    bthompson12
    Bruce
    GA
    That looks good dude! Spacers at all? I’m gonna go with the coopers and stock rims. I’ll post some pic’s once it’s all installed
  21. Jul 9, 2018 at 9:11 PM
    Rica25
    Ricardo
    Tulare
    No spacers but I did order to shims 1/2 inch more lift for the front should be installed this weekend.......my wheels +12 offset I've heard rubbing issues with that tire size on the UCA the lift is just for looks now not needed
  22. Apr 28, 2020 at 8:08 PM
    SalsaTheTundra
    SalsaTheTundra New Member
    jd
    Birmingham, Alabama
    2008 Salsa Tundra Double Cab SR5 5.7
    Ubar led headlights K&N filter +50HP
    will post more once installed
    Y0TA PR0 likes this.
  23. Apr 29, 2020 at 7:19 AM
    bthompson12
    Bruce
    GA
    I ended up getting some myself. Paid 350 for the rims and added some nitto ridge grapplers 295 70 r 18 with 5100’s on top setting. No spacers and no rubbing at all. I’ve been running these for close to two years now and great experience with these tires
  24. May 30, 2020 at 1:22 PM
    KCTundra07
    KCTundra07 New Member
    2007 Red Salsa Pearl Tundra DC TRD
    2020 Tundra wheels, Smoke Spyder headlights and tail lights, Alpine NAV, Kenwood backup camera, Husky liners, etc...
    Hey guys. New to the forum. Just put the 2020 TRD wheels on my ‘07 thanks to your post. This truck looks night and day from when I bought it in November. Thanks for the inspiration. 11180CC7-DC74-4B25-809C-4581D23D6364.jpg
  25. Oct 30, 2021 at 8:10 PM
    Guitarman73
    Guitarman73 New Member
    Casey
    2013 Tundra
  26. Aug 11, 2023 at 10:59 AM
    Silverdollar2011
    Silverdollar2011 New Member
    2011 dc silver
    Stock old man style
    What size tires on the stock 2020 rims?
