Dashboard removal
Discussion in '1st Gen Tundras (2000-2006)' started by Bmktw2, Aug 11, 2023.
  1. Aug 11, 2023 at 7:01 AM
    Bmktw2
    Bmktw2 [OP] Yard Dog
    Nic
    AC 2001 5spd 4x4 V6
    Does anyone have experience with changing the dashboard on a first gen?
  2. Aug 11, 2023 at 7:09 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I've taken apart the lower dash by the pedals and stuff around the speedo numerous times, that is super easy, but nothing on the upper dash. I believe
    @daveeasa and @Sunnier have experience with this though.
    JasonC. likes this.
  3. Aug 11, 2023 at 7:32 AM
    daveeasa
    I haven’t done this yet. I managed to swap the passenger airbag by just removing the glove box. I’ve done some trim but never the full Monty. I may attempt the wheel at some point but unless I find a black or moon mist dash piece in nice condition, I’ll probably leave my gorilla glued one as is for a while.
  4. Aug 11, 2023 at 7:52 AM
    Sunnier
    Sunny
    San Diego, CA
    Yup. Down to frame and back wall twice. But I don't have any step-by-step go-by. Tips:
    First step, turn your steering wheel far to the side to expose the small Allen fasteners in the column. Do this before you disconnect the battery. You'll have to take the steering wheel off. (Borrow a puller free from Auto Zone, O'Reilly's, whichever is your local auto parts store).
    Begin disassembly by manipulating the air vents in the stereo surround, inside are two fasteners, one each side. Once those are out, you'll be able to gently pull out the surround. Go slowly and pay attention... any time you feel resistance, stop and look for a fastener to remove.
    I think I recall most of the actual weight fastening bolts are 8's (?) and there's only maybe 10 of them(?)
    BIGGEST TIP:
    Place every fastener in one of the cup holders in your center console (or place a small box on each floorboard, same/same)... if you remove a fastener from driver's side of center, put it in that cup holder; passenger side, to that cup holder.
    DASH REASSEMBLY FOR DUMMIES:
    Take photos of each step at disassembly. You'll learn as you go and, for anyone more "visual learner" than I am (99% population), you may not need the pics to remember how it all goes back together again. But if you are challenged in this kind of thinking... or you'll leave the dash disassembled for awhile and forget... pics are a huge help.
    Anyway. I have no idea what your actual question might have been. Lol. I hope something I wrote is the answer. Good luck!
    w666, des2mtn, KNABORES and 4 others like this.
  5. Aug 11, 2023 at 9:07 AM
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Thinking about the cab swap and so want to move the dash and pedals to keep the bluegrey color
  6. Aug 11, 2023 at 10:17 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    While this is a 2000, it's almost exactly the steps I have done with my 04 when removing certain sections. To date I have removed everything but the actual dash board, whereas this guy ends project by removing dash after removal of the other sections.
    FirstGenVol, w666, Bmktw2[OP] and 2 others like this.
  7. Aug 11, 2023 at 10:23 AM
    Every time I take out that kick panel under the steering wheel, I forget you have to pull the top section toward you instead of pulling down. I was playing around with it for 20 minutes last weekend trying to remember how to do it.
  8. Aug 11, 2023 at 3:05 PM
    What are some reasons why the entire dash would have to be pulled in our trucks? Aside from the cab swap BMK is considering.
  9. Aug 11, 2023 at 9:07 PM
    Bmktw2
    Nic
    AC 2001 5spd 4x4 V6
    Color change really only reason
  10. Aug 11, 2023 at 10:07 PM
    To grease those little phallic nubs that cause our dash to squeak like crazy in cold weather.
    jpink, Bmktw2[OP] and bfunke like this.
  11. Aug 12, 2023 at 6:40 AM
    @Sunnier , why did you have to pull your dash out?
  12. Aug 12, 2023 at 7:58 AM
    Sunnier
    Sunny
    San Diego, CA
    Because I determined the housing for the uber-silly drink holder that wouldn't really support a cup, was the perfect place for my comms radio base. But it's not accessible from the front. I got all the way down to the frame, and removed the big dash piece, to discover that a bolt mounted from the back forward is what held the thin metal box frame I sought. And also, that it wasn't actually perfect; the little box frame I wanted to put the radio base into needed some modification.
    So I took that as a template, and my radio base, to Bruce, with a request that he fabricate a radio mount. He agreed to do it, but life happens at its own speed and weeks passed, and I putting the truck back together for a trail run I had previously committed to.
    Very soon after that trail run, Bruce called to tell me my mount was ready. :angrygirl:
    I do think it's the perfect place for a comms radio mount. Super secure when hucking or whooping. And that cup holder was super lame.
  13. Aug 12, 2023 at 8:22 AM
    daveeasa
    I want one of those mounts now.
    using the whole width of ashtray and cupholders would be cool I think. Another option might be Oem small Toyota switch blank slots, lord knows we need them.
    Bmktw2[OP] likes this.
  14. Aug 13, 2023 at 9:12 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    @Bmktw2 Don't skip this if you've already got it apart.
  15. Aug 14, 2023 at 6:38 AM
    Man, I am HUNGRY all of a sudden. :boink::goingcrazy:
    Seriously though, you may wanna lube those bastards. I think someone else wrapped em in Tesa tape and that also worked.
    Just the tip, tho. :rofl:
  16. Aug 15, 2023 at 10:52 AM
    teereqs
    teereqs New Member
    Somebody had fun making those
    Jack McCarthy likes this.
  17. Aug 15, 2023 at 12:55 PM
    Self portrait, no doubt. :rofl:
    Things get really raunchy when you pull the fuzzy tape off the base. "visual inch".
  18. Feb 28, 2025 at 1:42 PM
    Seepick1
    Seepick1 New Member
    VA
    2006 SR5 Double Cab 4.7L
    Idk if I'm reading this correctly or not.
    You removed the whole dash to discover you only needed to remove a bolt from the back?
    Or you had to removed the whole dash to get to the bolt in the back.
    For context, planning what to do with that stupid cup holder drawer. Thinking about using that and the ashtray drawer as a base for some kind of modular face plate to mount accessories, etc.
    daveeasa likes this.
