Bed Mat for 2023 Limited Crewmax 5.7 bed
Discussion in '3rd Gen Tundras (2022+)' started by nworker, Aug 9, 2023.
  1. Aug 9, 2023 at 9:25 AM
    nworker
    nworker [OP] New Member
    Was hoping to order a Toyota bed mat for my new 2023 but I just learned there is a hard sales stop on them due to an issue where they bubble or something in the heat. Anyone hear of this? Looking for a good alternative.
  2. Aug 9, 2023 at 9:27 AM
    Henfield
    Henfield New Member
    waynescaggs and nworker[OP] like this.
  3. Aug 9, 2023 at 9:33 AM
    nworker
    Do you use the Adhesion kit? I have the factory spray in liner. Wondering if it moves around much.
  4. Aug 9, 2023 at 2:06 PM
    Woodyman
    Woodyman New Member
    2023 Tundra Capstone Supersonic Red
    AVS, Bed Extender, Bed Liner. Cat Shield
    Yes, I have the Bedrug with factory spray in liner and it slides around a little.
  5. Aug 9, 2023 at 2:21 PM
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    You could buy a horse mat from tractor supply or any farm and home store
    Soupbean77 likes this.
  6. Aug 9, 2023 at 2:22 PM
    charrito
    charrito New Member
    2023 Magnetic Gray Metallic 1794 Edition
  7. Aug 9, 2023 at 11:53 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Interesting! Took delivery on 7/7 and my OEM bed mat had a hump in the middle. Not sure if that’s the issue but I figured it just hadn’t been flat in the sun yet. It went down though in a week and is gone. My bed is covered now so It may not return. I hope!!
  8. Aug 10, 2023 at 5:07 AM
    ThomperBeThompin
    ThomperBeThompin New Member
    I bought a bed mat for my short bed back in early spring 2023. It has been sitting outside in the sun all day, every day since then. No issues with the mat so far.
  9. Aug 10, 2023 at 7:37 AM
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    BeastOfBourbon7 and Jorts like this.
  10. Aug 10, 2023 at 11:32 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
  11. Aug 10, 2023 at 3:09 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Love that about the Bedrug!! Truck had the plastic drop-in when I bought it (Hate those things) You barely tap the brakes and EVERYTHING is up against the cab.
    Groceries sliding around like a baby deer on a frozen pond! I get home from Costco now and everything is exactly where I put it.
    Plus it's nice and cushy on the knees when you gotta' crawl around in the bed.
    drewpweinerMD[QUOTED] likes this.
  12. Aug 10, 2023 at 8:21 PM
    Chugbug
    Chugbug New Member
    2023 Platinum, Midnight Black
    100% Bed Rug, I'll never own another truck without one.
  13. Aug 11, 2023 at 4:47 AM
    arkhomer
    arkhomer New Member
    Tyler
    2024 Limited
  14. Aug 11, 2023 at 8:21 AM
    ZackH
    ZackH New Member
    I did as well. We will see.
  15. Aug 11, 2023 at 8:26 AM
    BeastOfBourbon7
    BeastOfBourbon7 New Member
    2022 Grey SR5 TRD Sport
