Window sticker said 32 gallon tank, received 22 gallon tank
Discussion in '3rd Gen Tundras (2022+)' started by johnhermes, Aug 5, 2023.
  1. Aug 5, 2023 at 3:24 PM
    johnhermes
    johnhermes [OP] New Member
    2023 Tundra SR5 TRD 4x4
    So I recently bought a 2023 Tundra SR5 TRD 4x4, and the window sticker says it has a 32 gallon tank, however the tank is only 22 gallons. Window sticker matches the VIN on the truck. Has this happened to anyone before?
  2. Aug 5, 2023 at 3:50 PM
    johnhermes
    Bought it brand new. When the tank is on "E", I fill it and it only takes 20 gallons
  3. Aug 5, 2023 at 4:09 PM
    johnhermes
    That is absurd. Why have a 32 gallon tank if you can only burn 20 of it? Just to carry 72 pounds of fuel that you cannot use around endlessly?
  4. Aug 5, 2023 at 4:18 PM
    2mchfun
    Electric fuel pumps are kept cool sitting in the fuel. Some will argue that they are cooled by fuel flowing through them. However, not as much as if they are literally submerged in a bath of liquid fuel. There is a reason for most things in life.
  5. Aug 5, 2023 at 5:17 PM
    cybertruck7
    cybertruck7 New Member
    I put 27 in mine when it was showing 14 miles remaining
  6. Aug 5, 2023 at 5:35 PM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    I just put 29.7 gallons in my truck 20 miles after the “refuel now” message came up. That’s obviously the big 32 gallon tank.
  7. Aug 5, 2023 at 5:48 PM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    Almost through my first tank of fuel from purchase. Will run it down till the light comes on and throw a 5 gal fuel can in so I'm able to see how far I can go with the light on! :thumbsup:
  8. Aug 5, 2023 at 5:58 PM
    hainesfive
    hainesfive New Member
    MD
    2020 Black TRD Sport Crewmax
    TRD Dual Exhaust Weathertech rear floor liner Black out badging Linex sprayed bed TRD PRO Wheels VLED Interior and exterior Drivers side grab handle Front drivers and passenger window tint Focal speaker upgrade with amp and 10" sub Retrax pro bed cover Falken tires
    Welcome to Toyota, my 38 gallon tank at 0 miles only takes 30 gallons, all toyata's have a big safety buffer
    Eurodriver, Doxiedad and Winning8 like this.
  9. Aug 5, 2023 at 8:11 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
  10. Aug 5, 2023 at 9:34 PM
    SC4333
    SC4333 New Member
    Grant
    2022 Tundra Limited TRD OR 4x4
    Highly unlikely that you received the wrong fuel tank. It's the sending unit location coupled with software programing in the 22 and 23 trucks that makes for a terribly inaccurate / inconstant fuel reading. Some days 20 miles to empty may equal 10 gallons in reserve... other days 20 miles to empty may equal 5 gallons in reserve. At least this has been my experience, and many others report similar experiences. It has been reported that Toyota changed the tank design for future model years (24+ IIRC) and there will be two sending units instead of one.
    With a little luck, someone will offer a long rang tank. I'd gladly ditch the OEM tank for a ~60 gallon aftermarket tank similar to what S&B offers for Ford and RAM. The 32 gallon tank doesn't provide great range when towing.
  11. Aug 6, 2023 at 4:36 AM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Showing 1/8 tank in my 32 gal tank.
    Fuel receipt showed almost 25 gals so mine is pretty good for now.
    Welcome to the forums!
  12. Aug 6, 2023 at 6:42 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    Take a picture of the tank and post it up here.
  13. Aug 6, 2023 at 7:02 AM
    pwpblue
    Greensburg,PA
    Maybe???
  14. Aug 6, 2023 at 7:08 AM
    Markysharky
    Markysharky New Member
    The 22 gallon tank has the low fuel light come on takes just over 18 gallons to fill it up. If you go a few clicks after the pump stops you can get an extra half a gallon. Mine does have the smaller tank being a 2023 base sr 2wd non crew cab model.
  15. Aug 6, 2023 at 7:31 AM
    TakiEvo
    TakiEvo New Member
    Allentown, PA
    2022 SR5 TRD Sport Crewmax White
    You shouldn't go a few clicks after pump stops. Should stop fueling after first click and pump stop. Topping off will cause fuel to get into your vapor canister and damage it. I've done many vapor canister replacement cause people keep trying to round up to next dollar or topping off getting as much as they can into the tank.
  16. Aug 6, 2023 at 10:23 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    38?
  17. Aug 6, 2023 at 10:27 PM
    18" TRD Off Road Wheels
    Yes, 38 gallons. The previous gen Tundra had that option from 2016 onward, and it was standardized in 2020 or 2021. His profile pic shows his 2.5 gen truck.
  18. Aug 7, 2023 at 6:16 AM
    CRFL82
    CRFL82 New Member
    SWFL
    2023 Lunar Rock SR5/TRD Sport
    As others have said, it's just Toyota's super-ultra-mega safe buffer. I have a 32 gal, and when I fill it up from E it will take anywhere between 20-25 gallons.
    Part of it also may be more of a calculation than an actual fuel level reading. When I can fill up +/- 25 gal from E, it's when my full tank's "miles to empty" is closer to 500 miles. That number changes based on prior tank(s) fuel economy. If I've been doing a lot of city driving and my mpg is garbage, it takes closer to 20 gallons to go from E to full.
    If I was to bet, I'd say you do have the 32 gal tank. You can look under the truck to confirm. I believe the 32 gal tank is noticeably longer than the 22 gal tank.
  19. Aug 7, 2023 at 11:43 AM
    violetkibbles22
    violetkibbles22 New Member
    2022 tundra
    look under the right side you will be able to tell if you have the big tank
    Eurodriver likes this.
  20. Aug 7, 2023 at 12:08 PM
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    It is not all that big if you are towing.
    Say your are towing your travel trailer and getting 7.5 mpg. A 10 gallon warning is only 75 miles. This is not much if you are running through some remote areas where stations can be that far apart. I have been there.
    JLS in WA and TundraDan723 like this.
  21. Aug 9, 2023 at 8:26 PM
    TundraDan723
    Well after driving around this week and still not having the low fuel warning come on, I decided to fill up today. It took 25.142 gallons. The gauge was almost to "E", but the low fuel warning did not come on. Apparently, I still had about 7 gallons left.
    That's my report!
    pwpblue likes this.
  22. Aug 9, 2023 at 8:50 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    I had 408 miles on trip odometer, it said I had 21 miles to empty and it took 26.9 gallons to fill up. I never add more than the first stop. I have averaged about 15 mpg since I got the truck. Big city driving, all stop and go.
    pwpblue likes this.
  23. Aug 10, 2023 at 2:29 AM
    pwpblue
    Greensburg,PA
  24. Aug 10, 2023 at 6:04 AM
    bjohnson425
    bjohnson425 New Member
    Brandon
    This.. it is absurd my 38 gallon tank on the tundra would only take 26 gallons well after the gas light came on.. the 26 gallon tank in my Sequoia will only take 18 gallons well after the light comes on. The 14.5 gallon tank on my wifes Rav4 hybrid only takes about 9 gallons.. which there is a big investigation into that one that Toyota is blaming the tank shape on and leaving enough "reserve" capacity. Apparantly they get to vastly overstate their range when they have these large capacities that are unusable.
    https://www.greencarreports.com/new...9-2020-rav4-hybrid-toyota-still-investigating
  25. Aug 10, 2023 at 8:41 AM
    Solo707
    Solo707 New Member
    2022 Mag. Gray Tundra SR5 TRD Off-Road
    Here’s my math…and I’m not a rocket scientist so take this with a grain of salt.
    From my experience, the highest number miles til empty on a full tank I’ve seen is around 480-475. Divide that by approximately 17 mpg and you have around 28 gallons. That leaves 4 gallons in the reserves of a 32 gallon tank.
    Not bad. If thats what it takes to keep my fuel pump submerged then I’m all for it.
  26. Aug 10, 2023 at 8:43 AM
    You can burn all of it. It has a buffer so the pump stays cooled and so morons don't run out of gas and complain that they weren't given enough buffer. Easy problem to solve. Fill up at a half or quarter tank.
    NewImprovedRon and pwpblue like this.
  27. Aug 10, 2023 at 8:50 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    For anyone curious about how accurate the DTE range is and how much "grace" manufacturers build into that estimate...here is a great video. It's a fun video to watch, but a little long at 23 minutes.
    https://youtu.be/iFIfFc_wY-w
    If you want to skip to the answer...this dude went 49.1 miles after his DTE said 0 miles in his 2015 F-150 with the 5.0.
    Mr Badwrench likes this.
  28. Aug 10, 2023 at 9:45 AM
    Xlocdnguyen
    Xlocdnguyen New Member
    Loc
    Houston,TX
    2023 Black Tundra SR5 Off-Road
    TRD Front Grille
    Took mine in for the same reason. Toyota builds in an 8 gallon buffer tank so if you run to E you’ll still have range. 32 gallon tanks you’ll be able to fill to 20-24 while 24 gallon tanks you’ll fill up to 14-16. They lifted the truck and verified it with measurements as well.
  29. Aug 10, 2023 at 9:57 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Most modern fuel pumps sit in a reservoir of fuel for cooling. You don't need X amount of gallons in the tank to cool it. Unless you run it bone dry, it has fuel around it.
    Hitch up 10,000 lbs to your truck, then drive until it runs out of fuel. 6 or 7 gallons of fuel won't get you far when you're getting 8 MPG.
  30. Aug 13, 2023 at 8:04 AM
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    It doesn't seem like the aftermarket is inclined to make very many replacement tanks for gas powered vehicles. I wouldn't mind a 40+ gallon fuel tank in a 1/2 ton.
