Transmission fluid leak
Discussion in '2nd Gen Tundras (2007-2013)' started by Dirk, Aug 10, 2023.
  1. Aug 10, 2023 at 6:01 AM
    Dirk
    Dirk [OP] New Member
    Hello, I hope anybody can help me. My Tundra 2007 5.7 4x4 wit 113k miles has an issue, there is leaking transmission fluid. 6 weeks ago I have changed the transmission fluid (was leaking a little bit at the pan) and they put in a new seal. All the time everything was fine but this morning I saw that it is leaking (didn't use the truck for one week, even didn't start it).
    It seems to leak through the small hole. The engine oil pan also is a little bit wet.
    Maybe they overfilled the trans fluid, they told me that they used the whole canister (OEM WS).
    Any thoughts?
    Thanks in advance!
  2. Aug 11, 2023 at 6:01 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    Check the fluid level...if it's off, take it back.
  3. Aug 12, 2023 at 2:14 AM
    Dirk
    It’s a little bit curious: I cleaned it and it was leaking again. Then I started the engine and immediately stopped leaking. Like I said, I didn’t use the truck for more than one week and it’s parked a little bit downhill.
    I washed the truck the day before yesterday and there was nothing. Therefore it began leaking after washing it without using it.
    I found this (exactly what I have) but it’s for 2021 models
    https://www.toyoheadquarters.com/.../2021-toyota-tundra.../
  4. Aug 12, 2023 at 2:57 AM
    tmac58star
    Interesting, report it to the dealer.
  5. Aug 13, 2023 at 2:13 AM
    Dirk
    That is the problem. It's very hard to find a mechanic you can trust. You can't imagine what I have seen here... And the Toyota Dealership is not allowed to touch vehicles imported. Therefore I have to find out what exactly is/maybe the problem because I have to order all the parts in the US and every time it takes 2-3 weeks to receive them.
  6. Nov 2, 2023 at 1:28 PM
    mbecker
    mbecker New Member
    I have the same leak on my 2015 Tundra.
    Has anyone seen any new information on this??
    I have an appt at the dealership next week.
