rear right abs sensor read different from others after changing all 4
Discussion in '3rd Gen Tundras (2022+)' started by tundrasSssssssss, Aug 8, 2023.
  1. Aug 8, 2023 at 4:25 PM
    tundrasSssssssss
    tundrasSssssssss [OP] New Member
    2007 blue tundra limited
    I have a 2007 tundra that the abs light popped up, i changed all 4 sensor's and the code reader is showing rear rh sensor circuit and as i was driving a was looking at the data reading from all 4 sensor's and the rear right was changing. One monent it would be 55 then dip down to 44 for a second then go back. Im not sure what the problem is.
  2. Aug 9, 2023 at 8:24 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    You may want to search for threads on your generation Tundra. They may have more experience than 3rd gen owners with that kind of problem. I realize there is some overlap but wanted to offer the suggestion in case you haven’t checked other threads. Good luck with your sensor problem.
    pwpblue likes this.
