Adjustable drivers seat?
Discussion in 'General Tundra Discussion' started by Goingbroke, Aug 9, 2023.
  1. Aug 9, 2023 at 6:48 AM
    Goingbroke
    Goingbroke [OP] New Member
    2021 TRD Pro
    I am looking at a 2021 TRD Pro and the drivers seat DOES NOT adjust up and down, (higher seating position or lower seating position). Does this truck have that capability? Or is it broken?
    Thanks..
  2. Aug 9, 2023 at 6:57 AM
    The 21 pro is based on a limited trim version of the truck and should have power adjustable seat with the ability to raise and lower the front or back of the seat independently. Controls are on the lower seat trim side panel. Earlier pros based on the SR5 version may not have had this ability.
  3. Aug 9, 2023 at 7:04 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  4. Aug 10, 2023 at 5:39 PM
    Goingbroke
    2021 TRD Pro
    Thanks for the reply’s. My seat does adjust in all ways except (like I attempted to explain in my original post) raising and lowering the whole seat. I can adjust the front and back to get Andre on the seat but this truck does raise or lower the seat position. I had a 2015 Chevy and I could adjust the front, back AND raise or lower the whole seat position. THEREFORE I was asking if this truck that I bought can do the same thing? If it can, then my seat is broken on raising and lowering the WHOLE SEAT position. Thanks
  5. Aug 10, 2023 at 6:30 PM
    Not sure who Andre is, your first post did not explain what you meant any better than this post did. If you raise the front and back of the seat, does the whole seat not get higher? Are you saying you want the front and back of the lower seat cushion to raise at the same time?
  6. Aug 10, 2023 at 7:04 PM
    Goingbroke
    2021 TRD Pro
    Hmm… well I’ll try again. Yes, I want the whole seat to raise or lower…. When I raise the front it just tilts more towards the back, when I raise the back it tilts more forward. Both front and back will not raise or lower at the same time. Like I said on my 2015 Chevy I could tilt the seat more back and more forward and I could also raise the whole seat up or lower the whole seat down without changing the Andre of the seat.
    is this truck suppose to be able to raise the whole seat or lower the whole seat. Like when a short person drives the truck, they would want to raise the whole seat and Vice verse when a tall person drives it, they would maybe want to sit a little lower then the short person.
  7. Aug 10, 2023 at 7:08 PM
    When you raise the front, it raises the front. When you raise the back, it raises the back. If you raise them both, the whole seat raises up, it’s not just tilting.
    bulldog93 likes this.
  8. Aug 10, 2023 at 11:34 PM
    Goingbroke
    2021 TRD Pro
    That’s what I’m asking, mine doesn’t do that. Raise the whole seat or lower the whole seat. So since it doesn’t, is it broke?
  9. Aug 11, 2023 at 2:27 AM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    It is not functioning correctly
    Goingbroke[OP] likes this.
