Screw found after repair
Discussion in '2nd Gen Tundras (2007-2013)' started by EmergencyMaximum, Aug 8, 2023.
  1. Aug 8, 2023 at 8:31 AM
    EmergencyMaximum
    EmergencyMaximum [OP] Synthetic member
    Hi gang, I recently had my wiring harness replaced at the dealer and I found this screw in my driver door pocket. I'm assuming it's supposed to be somewhere.
    Has anyone come across one of these, so I can get some pointers where to look? Thanks gang!
  2. Aug 8, 2023 at 8:38 AM
    RobertD
    Robert
    DFW, Texas
    Which wiring harness?
    If for headlights, check the top of the grille and see if all screws were put back.
  3. Aug 8, 2023 at 8:42 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    That looks like a seat track bolt?
    WILLINH and EmergencyMaximum[OP] like this.
  4. Aug 8, 2023 at 8:50 AM
    That bolt is used all over the truck. It most likely is for a clamp somewhere along the harness.
  5. Aug 8, 2023 at 8:53 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Toss it out…could improve MPGs
    Retired...finally and WILLINH like this.
  6. Aug 8, 2023 at 9:05 AM
    EmergencyMaximum
    Tundra234 likes this.
  7. Aug 8, 2023 at 9:47 AM
    EmergencyMaximum
    I'll check out those places. Let's hope this and the loose manifold clamp were the only things they forgot to tighten.
  8. Aug 8, 2023 at 10:54 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    exactly what i thought too. I've seen that bolt 50 times removing all kinds of panels
    Tundra234[QUOTED] likes this.
  9. Aug 9, 2023 at 3:28 AM
    tmac58star
    tmac58star New Member
    Black 1st generation Tundra SR5 Access Cab
    You need to ask the dealer and tech who did the work...they put it there.
