  1. Aug 5, 2023 at 7:56 PM
    French Avocado
    Utah / Wyo
  2. Aug 5, 2023 at 8:04 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
  3. Aug 5, 2023 at 8:08 PM
    French Avocado
    Utah / Wyo
  4. Aug 6, 2023 at 8:55 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Oil and filter change, not as many miles as I thought since the last one. Just over 18.1k miles since the last OCI, 0w-20 on 257k miles... :rofl:
    omgboost, Blang805, PhotoNerd and 2 others like this.
  5. Aug 7, 2023 at 10:55 AM
    Yotaholic
    Yotaholic Amateur Professional
    Lone Star Republic
    2011 TRD DC 4.6
    Is 9 hours of shop time reasonable for a transfer case swap? That seems excessive to me but just want to ask the group
  6. Aug 7, 2023 at 11:22 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    As an estimate it seems on the safe side. Maybe they will only charge for actual time spent?
  7. Aug 7, 2023 at 3:15 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    the book time for it calls 8.8 hours to replace it, just looked it up
    that doesn't include new gaskets and fluid
    Randy Morton and Wynnded like this.
  8. Aug 7, 2023 at 3:16 PM
    joseph_womack
    Joe
    Louisiana
  9. Aug 7, 2023 at 5:24 PM
    Yotaholic
    Lone Star Republic
    2011 TRD DC 4.6
    That’s what I hope
    Oh, nice thanks I don’t have that document
  10. Aug 7, 2023 at 8:12 PM
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    Mines is the plastic bumper so I had no issues cutting close to the fog lights. The viper cut was what I was going for but not as aggressive so I ended up with this.
    joseph_womack likes this.
  11. Aug 7, 2023 at 8:15 PM
    joseph_womack
    Joe
    Louisiana
    its alldata, our shop account, allows us to see basically a repair manual for every car along with "book time" and estimated part cost
    Yotaholic[QUOTED] likes this.
  12. Aug 8, 2023 at 6:12 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    dp0031, D4x4TRD, ACDC2ZZTop and 11 others like this.
  13. Aug 8, 2023 at 6:17 PM
    EmergencyMaximum
    I so very much doubt that.:playball:
    joseph_womack and French Avocado like this.
  14. Aug 8, 2023 at 6:21 PM
    EmergencyMaximum
    That looks very masculine, but why go astray from OEM when it should be perfectly adequate in holding down the battery? It's also hidden under the hood. Who would ever know?
  15. Aug 8, 2023 at 6:44 PM
    Retroboy1989
    Northern Utah
    Did you even read his post? He says he knows what the ladies like.
  16. Aug 8, 2023 at 8:12 PM
    EmergencyMaximum
    Funny.
    Ladies never complained about my oem.
  17. Aug 9, 2023 at 4:16 AM
    PhotoNerd
    Tony
    Waterford, CT
    I know, right? They never tell you what they're upset about. Now you know the problem when they won't make eye contact but, "Everything's fine."
  18. Aug 9, 2023 at 4:23 AM
    Shanet421
    San Diego,CA
    Indeed!
    Like > never complained
  19. Aug 9, 2023 at 5:05 AM
    Tenny
    Tenny New Member
    2012 Silver Tundra
    Just hit 100,000 miles on mine over the weekend.. time for oil change!
    Upgraded to the metal oil housing (mainly because the oil filter drain plug / screw / bolt (whatever it's called)) was over-tightened and frozen in the plastic housing by the dealer before I bought it. Swapped the inner straining tubes was super simple. Also added a fumoto valve for the oil drain. [​IMG]
    I'm not going to say it was the cleanest oil change I've ever done... but it certainly wasn't the worst. It was going great until the container started to overfill ( :facepalm:)... I was too concerned about the wind and not about capacity. Anyways thanks to cardboard it wasn't nearly as bad as it should have been.
    Hopefully next time it'll be cleaner... lol
  20. Aug 9, 2023 at 6:19 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I ticked over 100,000 miles as well on Monday. :thumbsup:
    PhotoNerd and PickupMan2008 like this.
  21. Aug 10, 2023 at 8:57 PM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Started making a Ty-down bar for the dirtbike in the back of the bed, almost there, waiting for some eye-nuts to arrive
  22. Aug 12, 2023 at 11:43 AM
    PhotoNerd
    Tony
    Waterford, CT
    Some totally unnecessary changes. New Mishimoto oil filler cap to match my red battery hold down:
    I also black wrapped the B pillars and the bottom of the grille to try and visually hide the Sequoia-grill gap.
    Not sure if I'll keep the grille wrap. I'll live with it and see if it actually looks better.
    dp0031, D4x4TRD, Mountun Goat and 9 others like this.
  23. Aug 13, 2023 at 10:42 AM
    PhotoNerd
    Tony
    Waterford, CT
    I have automatic bed and hood lights and I've been worried they would drain the battery. So I installed a low voltage disconnect between the battery and my accessory fuse block. It shuts off power at 12.1V (enough to start the truck but just barely) and turns power back on when it hits 12.8V (basically after I start the truck and the alternator starts spinning).
    And I installed automatic hood lights that I can manually turn off using the above switch.
    This is where I positioned the plunger switch (above driver's headlight). I wish it could have been more out of the way but I couldn't find a good spot with sufficient clearance behind it. I had to lengthen the negative cable by about a foot.
  24. Aug 13, 2023 at 4:37 PM
    EmergencyMaximum
    One more time quilting you. Thanks for inspiration, gang!:hattip:
    **genuine** new terminals from ebay:crapstorm:
    If she starts tomorrow, I'll be :yay:
  25. Aug 13, 2023 at 6:06 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Don't be alarmed if your truck starts and stalls immediately after on the first start. For some reason mine has always done that when started after a battery change or whenever I unhook the battery. Always starts fine the second try and runs great but dies immediately after the first turn of the key.
  26. Aug 13, 2023 at 6:08 PM
    Retroboy1989
    Northern Utah
    X2. It's very predictable. Makes me think it is some kind of systems check.
  27. Aug 13, 2023 at 6:10 PM
    EmergencyMaximum
    Thank you and I know about the stall thing. After hooking up battery, I always let ignition sit in the ON position for about a minute or two. It starts fine without stalling.
    One of the members here mentioned it happens due to ECM initializing or something of that nature. If it doesn't finish before start, engine stalls out immediately.
    Mountun Goat and surffj62 like this.
  28. Aug 14, 2023 at 6:06 AM
    joseph_womack
    Joe
    Louisiana
    It is a system check from my understanding
  29. Aug 14, 2023 at 9:27 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    Finally! Going to spray a clear coat on everything but couldn't resist installing as soon as they arrived. eBay had a bundled kit for everything. I'm a huge fan of watching items on eBay and waiting for them to send you an offer code. Saved 8% over advertised price.
  30. Aug 14, 2023 at 11:35 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    looks great! The difference a nice pair of headlights makes to the front end is crazy!
    French Avocado likes this.
