Oil Change before 3000 mile road trip?
Discussion in '3rd Gen Tundras (2022+)' started by danstark, Aug 7, 2023.
  1. Aug 7, 2023 at 8:43 AM
    danstark
    danstark [OP] New Member
    My 2023 Tundra SR5 4x4 CrewMax 6.5 was purchased with 10 miles on it on April 29th. It now has 2900 miles.
    I am leaving for a 3000 mile road trip in a couple weeks. Should I change the oil at the dealer before the road trip even though I'm well below the recommended milage and time thresholds?
    What would you do? I'm leaning toward getting it changed.
    Y0TA PR0 likes this.
  2. Aug 7, 2023 at 8:44 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I would.
    TXBrit and danstark[OP] like this.
  3. Aug 7, 2023 at 8:46 AM
    bfunke
    bfunke Tundra Curmudgeon
    Yes change it before trip. Oil changes are easy DIYs.
  4. Aug 7, 2023 at 10:02 AM
    On a new engine...yep. I would also change it out when you get back.
  5. Aug 7, 2023 at 10:04 AM
    CTundraForMe
    CTundraForMe New Member
    I'd do it regardless of engine.
    danstark[OP], Y0TA PR0 and ryanwgregg like this.
  6. Aug 7, 2023 at 10:39 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    No. Don’t bring it to the dealer. Do it yourself if possible.
  7. Aug 7, 2023 at 10:49 AM
    danstark
    Dealer maintenance is included in purchase price. No cost. I'd just be moving the initial change forward. Might come off the back end in 3 years.
    ryanwgregg likes this.
  8. Aug 7, 2023 at 10:54 AM
    Chuy!
    Chuy! New Member
    Lakeside, CA
    2007 Tacoma 4X4
    I would have changed the original oil and filter by now.
  9. Aug 7, 2023 at 10:55 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Yes, I would get it changed now.
    I'm in a similar situation. My new Tundra will have less than 500 miles on it when we leave for a 1100 mile (one-way) trip on Wednesday. I just scheduled to have the oil changed at a Toyota dealership at our destination on Friday. It'll have around 1500 miles by then.
    I know there are different opinions on whether, or not, to do the first oil change earlier than Toyota recommends. It's my opinion that Toyota isn't really too concerned about maximizing the life of your engine. That would be bad for sales, after all.
    The last I checked, these engines still have metal parts that shed material during break-in. If you've ever rebuilt an engine, it's pretty remarkable how much metal they shed in the first 1000 miles. I do not want that material potentially circulating in my Tundra's engine for 10K miles.
    Soupbean77, TXBrit and danstark[OP] like this.
  10. Aug 7, 2023 at 11:13 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Yes.
    I’m doing same amount of miles on a road trip soon also, I’m not due for oil change yet but I’m changing oil before I leave and then after I get back.
    danstark[OP] likes this.
  11. Aug 7, 2023 at 11:54 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp/sub, rear seat del, cat shield, AMP power boards
    I would, but only because you haven't done your first change yet. Yikes. Otherwise, it would be OK to go 6000 miles on a change. I prefer 5000, but going 6000 with mostly highway miles once or twice won't be a problem.
  12. Aug 7, 2023 at 12:07 PM
    Rb123
    Rb123 New Member
    Washington
    22 trd off-road crewmax mgm
    Bfg at 275/70r18 Lowmax Bumpershellz grill
    No
    danstark[OP] and Leo's first like this.
  13. Aug 7, 2023 at 3:18 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I still wouldn’t bring it to them. It’s not worth the savings. But, that’s my opinion. To your question. Yes, get it changed. Have a safe road trip.
    danstark[QUOTED][OP] likes this.
  14. Aug 7, 2023 at 3:27 PM
    racer01
    racer01 New Member
    Geoff
    Aiken South Carolina
    23' TRD Pro
    295/70-18 Nitto Recon Grappler, RB 20 running boards
    Would I recommend? Sure. Would I personally have a dealer do it, heck no. Definitely well within my personal comfort zone of mileage on a well running (new!) vehicle and modern oil. What I don't trust is a $15/hr new mechanic to do the change properly, use the right oil, fill it properly, not over/under tighten oil filter, not install under panel correctly, etc. right before a big trip where I don't have time to fix all the crap they mess up.
    I'd do it myself *maybe* if I was retired or underemployed and had extra time. Would go Mobil One and OEM filter and make sure it was right. I did mine at 5k and spilled oil from filter into the frame rail and was worried for a week that it was leaking a bit as it slowly dripped out. Don't need that drama before a big trip.
    pwpblue likes this.
  15. Aug 7, 2023 at 4:25 PM
    EmergencyMaximum
    First ever oil change happens at 1000miles. Yes that's a little bit overdue.
  16. Aug 7, 2023 at 4:29 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    2600 miles and my dipstick has some grey on it from the break in. Look at my pic and I have checked the oil before but this is the first time wiping the dipstick off. No glitter in oil so I'm seeing this as normal. I'll be changing my oil soon, already have the oil, just need to get a filter. Yes change you oil before your trip!
    Past F150 was already too dark by comparison and unable to see the grey.
  17. Aug 7, 2023 at 8:00 PM
    Aku77
    Aku77 New Member
    Washington State
    2023 Gray Tundra Limited
    I have a 2023 Limited. I changed the oil myself at 3,200 miles. It's pretty easy.
    Anyway, the fact that you're concerned is reason enough to do it. Better safe than sorry. Do it and not worry about it on your road trip.
    My plan is to take it in to the dealership at 8K to get my first free change. I'll then change it myself at 13K then dealership at 18K.
    pwpblue and danstark[OP] like this.
  18. Aug 8, 2023 at 5:11 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Not to hijack this thread, but what oil filter wrench are you DIY oil changers using?
    And do you use a hose to divert the oil that spills out of the filter?
  19. Aug 8, 2023 at 5:38 AM
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks! Nice idea on the garden hose.
    By "regular oil filter wrench", are you talking about the band style, end cap wrench, or the pliers?
  20. Aug 8, 2023 at 7:10 AM
    EmergencyMaximum
    Are those wire harnesses? Oh man that is such a bad design. I wonder if they are oil-resistant because it appears to be easily spilled on if one is not careful.
    Not sure if soy-based organic insulation will withstand oil.
  21. Aug 8, 2023 at 7:10 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    I think it's worth buying the proper cap size.
  22. Aug 8, 2023 at 7:12 AM
    raylo
    Frederick, MD
    I like the spring loaded type that you operate with a 3/8" ratchet. Works great in a tight space and will get any filter off, even ones for which cap wrenches slip. But you can get these Tundra off with pretty much any type you like.
  23. Aug 8, 2023 at 7:25 AM
    BoulderGT3
    Glen
    Agree on this. I just bought one to use for the next change. The filter is recessed just enough that getting a band type or pliers on it has you at a bit of an angle although they work.
  24. Aug 8, 2023 at 8:37 AM
    CTundraForMe
    Do yourself a favor and get a fumota valve or something similar. No mess. No fuss. It just works.
    22whatwedo likes this.
  25. Aug 8, 2023 at 1:47 PM
    raylo
    Frederick, MD
    I put one on at my last oil change. I almost want to change it early just so I can use the Fumoto!
  26. Aug 8, 2023 at 2:06 PM
    pwpblue
    Greensburg,PA
    Getting ready to change mine.
    Oil filter comparison: 10010 was just purchased from the dealership, yzzf1 is from work (toyota forklifts). We will see what's on mine shortly.
  27. Aug 8, 2023 at 2:42 PM
    EmergencyMaximum
    it's not the drain plug that creates a mess usually(for me), but rather the cartridge removal. My nijna skills have improved though. Few days ago, I changed oil and didnt drop a single boop of oil on the ground. Masterclass skill.
    Mattedfred and Leo's first like this.
  28. Aug 8, 2023 at 3:58 PM
    raylo
    Frederick, MD
    But even if you don't spill from draining you end up with a big messy oil drain pan. With the Fumoto I plan to drain right into my disposal container which is a repurposed 2 1/2 gallon plastic gasoline container.
  29. Aug 8, 2023 at 4:00 PM
    raylo
    Frederick, MD
    Just a data point... I have used both. I noticed no differences in oil pressure or anything else.
    pwpblue[QUOTED] likes this.
  30. Aug 8, 2023 at 4:09 PM
    pwpblue
    Greensburg,PA
    I took off the same as the dealer gave me, but I understand the Ti dra were coming with the yzzf1 originally.
