Sprinkler System
Discussion in 'Home Improvement' started by texasrho83, Aug 6, 2023.
  1. Aug 6, 2023 at 1:12 PM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Our grass is all but extinct and I'm tired of having to drag out the hose and sprinkler then move it around every morning and evening. Enter the Orbit dual zone sprinkler system. Problem is it's hot AF outside right now....
    Screenshot_20230806_095009_Lowe's.jpg 20230806_120612.jpg 20230806_143529.jpg 20230806_144619.jpg
    More to come....
    MS22, Tundra234, RobertD and 3 others like this.
  2. Aug 6, 2023 at 1:20 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2022 GMC Sierra AT4 L5P - 2017 4runner SR5P - 2023 Tesla Model 3 LR
    I hope the water pressure and volume at your source is REALLY good..
    You can rent a trenching tool at Diamond Tool Rental or similar for probably $100 for the day. Digging in the heat blows. Good luck!
  3. Aug 6, 2023 at 1:28 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    60 PSI and almost 9 gpm. I tested everything before digging.
    Also laid it out to ensure the spray patterns are good to go.
    The Ditch Witch sounds good about now lol
    RobertD and Black@Blue19 like this.
  4. Aug 6, 2023 at 1:40 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Can you rent pipe pullers you still have to backfill a trench with a puller you only have to dig and backfill at head locations
    Backslider[QUOTED] likes this.
  5. Aug 6, 2023 at 1:47 PM
    Backslider
    Tooele, UT
    I'm unsure, but probably. I've installed exactly two sprinkler systems both in homes I was building, and both as a first step in completing the landscaping.. the first time I used a trenching machine and the second time a mini excavator.
    The pipe puller option is intriguing..
    texasrho83[OP] likes this.
  6. Aug 6, 2023 at 1:55 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    To make things worse, my neighbor fired up his pit and it's making me HUNGRY
    RobertD and Leo's first like this.
  7. Aug 6, 2023 at 2:14 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Get a backflow prevention valve on that system. You can find all different flavors for varying prices. Well worth not having to worrying what's potentially coming back up in the system and is code in most areas.
    I've only designed and installed one system and I'll never do it myself again. So much work and it just wasn't worth it in the end. Good luck!
  8. Aug 6, 2023 at 2:52 PM
    Wouldn’t one of the simple hose bib checks be sufficient?
  9. Aug 6, 2023 at 3:11 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Dont believe that is code, but certainly better than nothing, IMO. After reading up on it,, it was an easy $100 purchase for a dedicated unit, especially how I was tied into my house supply, had pets, and applied fertilizers.
  10. Aug 6, 2023 at 3:29 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Would this suffice?
    Leo's first likes this.
  11. Aug 6, 2023 at 3:30 PM
    That’s the one I was talking about
  12. Aug 6, 2023 at 4:10 PM
    Leo's first
    Groton ma
  13. Aug 6, 2023 at 4:26 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Only completed one zone. I'm tuckered out. The other zone will have to wait. I'll still run it above ground though....
    T-Rex266 and RobertD like this.
  14. Aug 6, 2023 at 4:30 PM
    Leo's first
    Groton ma
    Looking good. How many heads per zone?
  15. Aug 6, 2023 at 4:36 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    3 per zone. I calculated 22 ft spray pattern at 360°
    Leo's first[QUOTED] likes this.
  16. Aug 6, 2023 at 4:41 PM
    centex
    centex New Member
    We’ve been on stage three for a month and no irrigation allowed. I’m currently filling up a cooler to wheel it around and water some small trees we got growing. My front yard is baked but it’s St Augustine. First rain and it’ll bounce back.
    texasrho83[OP] and Leo's first like this.
  17. Aug 6, 2023 at 4:59 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What county are you in?
  18. Aug 6, 2023 at 5:14 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    Swing checks are not a legal, at least in Cal, backflow device. You need a "dump" also refered to as a positive air gap or an anti-siphon to be legal.
  19. Aug 6, 2023 at 5:21 PM
    centex
    centex New Member
    Williamson.
    And of course, I’ve got a valve in my system that’s leaking. Can’t even use the dang thing and it’s leaking.
  20. Aug 6, 2023 at 5:31 PM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
    … You do plan on re-sodding right? Water all you want but all I see is nutsedges weeds and some wild onion and no actual grass.
    You should check out “Texas lawn care nuts” FB page group if you want to learn more.
  21. Aug 6, 2023 at 5:41 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah, when it cools off. The previous owners obviously didn't give a crap about what the yard looked like but there was way more grass than what's there now. I'm no lawn nut and the last guy to get on hands and knees to pull a weed.
  22. Aug 6, 2023 at 6:10 PM
    Leo's first
    Groton ma
    Is it a zone valve?
    Most zone valves are easy to take apart and clean or even replace the diaphragm
    sorry op not trying to jack thread
  23. Aug 6, 2023 at 6:28 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You're good bud. It's all related.
  24. Aug 6, 2023 at 7:17 PM
    centex
    centex New Member
    Uncertain and not worried. I pay an annual maintenance contract with a company to maintain this system. It’s 27 years old. That and I grew up fixing this crap with my dad and I swore then that if I ever had a sprinkler system, I’d pay someone to fix it. 10 zones and I think 40 heads? I’ve replaced at least a 1/4 of the heads myself. New control box first year we moved in. Had a valve bust this winter and one zone was on for 12hrs straight (I run my stuff at night). I know for sure we’ve replaced 30 heads and 3 valves so far. Dad drove over a line and busted that and we uncovered yet another valve in the system. PO didn’t keep the valves boxes cleaned up so grass has grown over them. Makes it that much more fun. I’m about ready to rip this non natural grass out and let the natural stuff grow in. My backyard has no sprinklers and is all natural grass. Grows in the fall and spring and is dead the rest of the year. Way easier. I keep threatening to rip the entire front flower beds out and go zero scape save for one or two plants my wife wants to keep. I hate yard maintenance.
