Hitch cargo carrier
Discussion in '3rd Gen Tundras (2022+)' started by Yota802, Aug 3, 2023.
  1. Aug 3, 2023 at 6:20 PM
    Yota802
    Yota802 [OP] New Member
    2023 Tundra Hybrid Limited CM WP
    Last min purchase for a beach road trip. Any suggestions on a hitch cargo carrier?
    I see Harbor Freight has a couple in stock.
    Folding for $129
    Non folding $69
    I’ve never hauled one before. Any tips or suggestions I would appreciate it!
  2. Aug 3, 2023 at 6:26 PM
    Taco-Spike
    Two Trucks
    I’ve had one for maybe 5 years I got at a garage sale for $40. Still never used it.
    That’s all I got
    ZappBrannigan and Mater like this.
  3. Aug 3, 2023 at 6:26 PM
    2mchfun
    I have three of them. The folding one with fold up sides is a great choice for lighter duty. My custom made big one is almost as big as my truck bed and I love it. Haul my garden tractor on it, great for traveling too. Better than a trailer because of easy storage and no maintenance. Heavy bastard though. Magnetic trailer light set works great. Might want to relocate your license plate.
    Mater and Taco-Spike like this.
  4. Aug 3, 2023 at 6:52 PM
    biebs96
    PA
    My 2010 had a front hitch and I used the non folding harbor freight one more often then I thought I would.
    Used the rear hitch for a bicycle rack. The front had a cooler and other miscellaneous items.
    Sorry, long story… longer…
    If you need quick and seldom cargo storage, hitch rack is great.
    If you are going to be using this system often, I would suggest a roof basket or one that mounts over the bed, or a bed cap that would allow you to pack it to the ceiling.
    Mater and Hbjeff like this.
  5. Aug 3, 2023 at 7:03 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Get aluminum. Saves weight when you have to remove it.. most aluminum holds 500lbs of weight, unless you need more capacity then get steel
  6. Aug 3, 2023 at 7:10 PM
    centex
    centex New Member
    I bought a cheap steel non folding on Amazon and it’s done texas to florida a couple of times and traveled around the state with no issues. It weighs nothing. Get a good cargo bag to stow your gear in on it. I generally use it on the Durango and fully loaded it will let you know it’s there if you have to swerve real hard. Haven’t tried it on the tundra yet.
  7. Aug 3, 2023 at 7:15 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I bought the 69$ one at harbor frieght mid trip last week. Lifesaver i had over packed and was tired of cramming everything under the bed cover. Very solid
    Mater likes this.
  8. Aug 3, 2023 at 7:33 PM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    Just traveled 3100 miles with a cheap $49 Menards one with two coolers full of food and beer. Slick.
    Mater likes this.
  9. Aug 4, 2023 at 4:39 PM
    Yota802
    Maybe it’s me… but a standard 3” 5/8 hitch pin is a very short fit. I couldn’t make the locking pin connection, so I got a cheap standard pin with clip, even that is really too short. I’m going to make it work, but why would Toyota engineers make such a thing.. Maybe it’s just me.
  10. Aug 4, 2023 at 6:00 PM
    biebs96
    PA
    Toyota designed the hitch to have a small amount of play/wiggle room. This was done to avoid hitches/accessories becoming stuck from debris or rusted into the receiver.
  11. Aug 4, 2023 at 6:01 PM
    biebs96
    PA
    to answer your question an “extended” hitch pin will work.
  12. Aug 4, 2023 at 6:01 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The hitch pin only works at a certain angle yeah kinda annoying
  13. Aug 4, 2023 at 7:50 PM
    cybertruck7
    cybertruck7 New Member
    I have the Aluminum one from harbor freight with the ramp. It works great and as expected, but beware it was a pain to assemble. Tons of small fasteners.
  14. Aug 5, 2023 at 9:46 PM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    I can only imagine what the double Yakima system cost?
    2mchfun likes this.
  15. Aug 5, 2023 at 9:49 PM
    PNW Tundra Mike
    Southern Cal
    LOL. Isn’t that four $$$$
  16. Aug 6, 2023 at 4:09 AM
    2mchfun
    I built a DIY box for one of mine using 1 3/8" chainlink fence toprail material for the frame. Then cut up old plastic bedliners to recycle the material for the sides, top, and bottom. Fastened with self drilling and tapping screws. Lastly trimmed the outside corners with sheet metal corner trim and waterproofed the inside seams with spray polyurethane foam. Cost me about $120 and a half of day. I can haul just as much cargo as both of those Yakima boxes inside of it and made a rack to hold my.giant Igloo cooler on top for EZ access to the cooler while traveling. Took it out west on my 4Runner for thousands of miles and it was awesome. I did add a trailer light kit and relocated the license plate as well.
  17. Aug 6, 2023 at 9:28 AM
    pronstar
    pronstar New Member
    Robert
    Not a Tundra :-(
    2015 Silverado: 2.5” Kings front/rear. Icon Delta Joint UCA’s. Deavers. 17” Method 703 BeadGrips. 33” BFF KM3 2018 Suburban: 2.0” Fox front/rear. Dirt King UCA’s. Mall Cruiser.
    Harbor Freight rack and cover, Costco storage bins, ratchet straps.
    Survived 2 trips from Dallas to Kalifornia and back.
    PNW Tundra Mike likes this.
  18. Aug 6, 2023 at 8:49 PM
    PNW Tundra Mike
    Southern Cal
    Like the bin idea a lot. Thx
    pronstar[QUOTED] likes this.
  19. Aug 7, 2023 at 3:54 AM
    Retired...finally
    I picked up a folder at Academy for 60 bucks last November. Used it to haul a wheelchair around. After removing the chair I'd fold it up to get it out of the way. Worked very well for me.
  20. Aug 7, 2023 at 5:43 AM
    BCM
    BCM New Member
    Brendan
    If you want a good one, Pakmule. Tig welded aluminum, light, doesn't rust, doesn't rattle or squeak, holds up to hundreds of pounds of coolers full of ice / meat on hunting trips running washboard & worse forest roads.
    I've had 2-3 cheaper ones from Harbor Freight, Northern Tool, etc. IMO, they're all garbage for anything but occasional light use on pavement. They all eventually start bending, rattling, and falling apart. Buy once cry once.
  21. Aug 7, 2023 at 5:47 AM
    Retired...finally
    It all depends on how often you intend on using it. I'm my situation I was away from home with a wife healing from a broken femur. The carrier served a temporary purpose and after a few months I gave it to a fellow camper to carry a generator on the back if her travel trailer.
  22. Aug 7, 2023 at 5:48 AM
    BCM
    BCM New Member
    Brendan
    Temporary use on pavement is fine. I've just had to throw away 2-3 of them. The cheaper ones are basically disposable.
  23. Aug 7, 2023 at 6:09 AM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Never used one with a pickup truck but have use for family trips in suv for things I didn't want to lift up to roofrack.
    Good for trash or whatever that you don't want inside SUV hatch. Just be aware of exhaust exit location relative to your stuff.
    I tried 2 from store and returned both. Harborfreight and northerntool. No way I would trust it to the 500lb it was rated for. Didnt even like the feel of it with my 200lb standing on it. Built my own with some angle and 2" tubing.
