Where to put new head unit microphone?
Discussion in 'Audio & Video' started by legiz, Jul 11, 2023.
  1. Jul 11, 2023 at 4:58 AM
    legiz
    legiz [OP] New Member
    I’m going to buy the Alpine headunit package from Trail Grid pro. Where is a good place to put the replacement microphone? Do I have to have a wire fish to feed it to put on top of the steering wheel cluster? Any pictures would be appreciated. Thanks.
    I have already searched the forum as well.
  2. Jul 11, 2023 at 5:03 AM
    Top of A-pillar and windshield area.
    bulldog93 and legiz[OP] like this.
  3. Jul 11, 2023 at 5:11 AM
    Mine is mounted in one of the switch blanks under the center of the console below the AC controls.
    bulldog93 and legiz[QUOTED][OP] like this.
  4. Jul 11, 2023 at 5:13 AM
    I’ve only ever seen the factory mic for a hands free system installed in the headliner above you, not below.
    619Tundra likes this.
  5. Jul 11, 2023 at 5:16 AM
    legiz
    Good idea. I’ll check that out
  6. Jul 11, 2023 at 5:17 AM
    legiz
    Do you need to pop off the trim or can you just feed the wire and squeeze behind trim without removing
  7. Jul 11, 2023 at 5:17 AM
    I posted a pic. Just drill the hole and use JB weld on the back side.
  8. Jul 11, 2023 at 5:27 AM
    legiz
    Perfect. Thank you !
    Tundra234[QUOTED] likes this.
  9. Jul 11, 2023 at 8:04 AM
    JRS
    JRS New Member
    2012 DCLB
  10. Jul 13, 2023 at 3:15 PM
    Leatherhead237
    Leatherhead237 New Member
    Massachusetts
    2023 1794 TRD Off-Road
    FWIW, many of the microphones and mic sensitivity in the head units are tuned for a particular area.
    Generally, higher is better. I have always installed hands-free mics at the edge of the headliner above the rear view mirror. Installing them in the "corner" created by the top of the A-pillar and the windshield can sometimes cause audio issues and echoing for people on the other side of the phone. It may be something you want to try out multiple locations with someone on the phone to see where you sound the best and where it will pick up most effectively in your normal driving position.
    legiz[OP] likes this.
  11. Jul 14, 2023 at 5:23 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Removing the A-pillar trim is silly easy. Use a piece or butyl, bubble gum, or just a bit of duct tape to grip and pull the small bolt cover a bit below the headliner. Says “SRS or Air Bag” on it. It’s just a bolt cover, I promise!!! One bolt under there and it’s out.
    My mic is just to the left of the rear view mirror with the wire tucked above headliner. Once the A-piller trim is out of the way, it’s very easy to fish the wire under the dash. No other trim to remove.
    legiz[QUOTED][OP] likes this.
  12. Aug 2, 2023 at 2:48 PM
    Glocklynn
    Glocklynn New Member
    2018 SR5 Crewmax Blazing Blue Pearl
    Katzkin leather, tint, BF Goodrich KO2’s, Tiger bed cover, aftermarket stereo
    This will be my first post, as I am a long time lurker, first time poster. I just recently installed a sony setup from Trail Grid Pro and it came with a bracket to mount the mic in the factory location in the console of the headliner. It fit perfect and running the wire was easy. Also I have had great feedback about the sound quality. Hope this helps.
    TRDSnowInTX and Elbman like this.
  13. Aug 5, 2023 at 11:41 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    There's a thread on this somewhere.
