Guys I can't poo
Discussion in 'Outdoors' started by EmergencyMaximum, Aug 3, 2023.
  1. Aug 4, 2023 at 7:51 AM
    #91
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Tripleconpanna likes this.
  2. Aug 4, 2023 at 9:10 AM
    #92
    EmergencyMaximum
    EmergencyMaximum [OP] Synthetic member
    Thank you, @Talon2006. Noted. I'm guilty of not drinking enough.
    @snomoman, please stop spreading falsehood.
  3. Aug 4, 2023 at 9:26 AM
    #93
    TommyTundra
    TommyTundra Oh God the anger’s changing me
    Long Island NY
    2019 PRO
    Oh man. That’s good eating. I just have a two hour window then I gotta be home for a while.
  4. Aug 4, 2023 at 10:19 AM
    #94
    Rigger
    Rigger New Member
    2025 Tundra Crewmax
    I'm laughing my butt off here at some of these comments but it is no fun to be constipated. If you are pushing hard, you can injure yourself. BM's should happen comfortably. In the short term, go see a doctor.
    I take two teaspoons of psyllium fiber each day in a glass of water. The stuff I use is a knockoff of Metamucil that Costco sells. You should definitely add this, or similar, to your diet.
    Good luck!
  5. Aug 4, 2023 at 10:27 AM
    #95
    EmergencyMaximum
    Thanks @Rigger . I try to avoid pushing hard. If it doesn't exit, I sit and let the pressures normalize and gently thrust to help it along the way. I'm eating plenty of bread, so getting enough fiber is not a problem.
  6. Aug 4, 2023 at 11:12 AM
    #96
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :threadjacked:
    This is now officially a pee thread :rain:
  7. Aug 4, 2023 at 11:27 AM
    #97
    SD Surfer
    Bruce
    So Cal
    OMG, that's disgusting!
  8. Aug 4, 2023 at 11:43 AM
    #98
    Tripleconpanna
    #PeeDiddy :laugh:
  9. Aug 4, 2023 at 8:53 PM
    #99
    snomoman
    snomoman New Member
    North Aurora, IL
    2020 Cement SR5 4WD Tundra
    Bed liner, truxedo tonneau cover, Westin step rails, cover king seat covers
    7FBE8018-2F49-442A-B976-9B1AF56FC929.jpg C88D13F3-A85B-4D25-AF6B-0F615106C27C.jpg
    I stand corrected, It was actually 48 mph, had to re-search that thread about the 20+ miles per gallon thread but I found it, here are some screenshots of it
  10. Aug 4, 2023 at 9:03 PM
    #100
    EmergencyMaximum
    Yes, thank you. And average is 55 actually. I decelerate uphill down to 50. It's very rare when it dips below that.
    snomoman likes this.
  11. Aug 4, 2023 at 9:07 PM
    #101
    snomoman
    snomoman New Member
    North Aurora, IL
    Back to the subject, I remember my grandparents saying a teaspoon or tablespoon of Castor oil. Another remedy..hope this helps
    EmergencyMaximum[OP] and TILLY like this.
  12. Aug 4, 2023 at 9:15 PM
    #102
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Old remedies are awesome till you have to taste it. Has anyone here ever consumed Cod Liver Oil? :cheers:
  13. Aug 4, 2023 at 9:15 PM
    #103
    EmergencyMaximum
    Thank you, but I think everything is more or less back to normal. And I'm drinking more water!:hattip:
    Rigger likes this.
  14. Aug 4, 2023 at 9:23 PM
    #104
    TILLY
    Massachusetts
    Glad it worked out for you in the end, just for clarification, are you Male or Female so we know how to preface our questions and answers.
  15. Aug 4, 2023 at 9:23 PM
    #105
    EmergencyMaximum
    Boy:hattip:
    And thank you everyone.
  16. Aug 5, 2023 at 5:59 AM
    #106
    PermaFrostTRD
    Northern NY
    Whole grain breads have fiber, “white” breads do not. Be discerning, as the wrong bread could put you back in the same spot.
    Back in the day coming back from a fortnight of MRE’s or worse we’d go hit up a local Mexican dive for some musical fruit. That first time back in the saddle was like a soup can coming out but the frijoles got things back to normal in a day or 2.
    glad you’re doing better
  17. Aug 5, 2023 at 7:12 AM
    #107
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Question is... drink a little, now to drain the fiddle, standing or sitting while the room is spinning?
  18. Aug 5, 2023 at 7:25 AM
    #108
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Glad everything came out OK. :laughing:
  19. Aug 5, 2023 at 6:08 PM
    #109
    Rigger
    Rigger New Member
    2025 Tundra Crewmax
    Very glad to hear that the plumbing is working.
    EmergencyMaximum[OP] likes this.
  20. Aug 5, 2023 at 6:20 PM
    #110
    I once took 8 days to take a crap.
    I thought something was wrong with me so I went to the emergency room.
    Took a shit while I waited 4 hours to see a doctor. What a waste.
  21. Aug 5, 2023 at 6:32 PM
    #111
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    More fiber, more water, get a squat toilet.
    Worst is when recovering from multiple surgeries with associate nerve blockers and narcotics. Damn near have to get a pick axe and pry bar.
  22. Aug 5, 2023 at 6:39 PM
    #112
    PKFan
    2018 Inferno! DC SR5 4x4
    Or you've just add hemorrhoids to the mix. :eek2:
  23. Aug 5, 2023 at 6:48 PM
    #113
    IBS w/constipation + too much coffee as an only drink + diuretic high blood pressure meds = bad poo-poo mojo
  24. Aug 5, 2023 at 7:05 PM
    #114
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    The 'Be discerning' part is the most important thing because many 'whole grain breads' in the US contain few whole grains and a lot of refined flour, which means your fibre intake might not be as much as you think.
  25. Aug 5, 2023 at 7:14 PM
    #115
    EmergencyMaximum
    Well, I eat a lot of things. Borsch red and green, bakery stuff.. There must be enough of everything in there? Either way, Im cutting back on coffee for now.
  26. Aug 5, 2023 at 7:32 PM
    #116
    You really just need to offset it by drinking more water. Caffeine is a diuretic.
  27. Aug 5, 2023 at 7:57 PM
    #117
    EmergencyMaximum
    Yes, thank you. I started drinking water, more water. Also i made "elixir of life". It consists of lukewarm water, baking soda, honey and apple cider vinegar. Nasty combination, but my belly feels better now.
    I almost threw up while finishing the cup. Uber nasty, but I cant really point a finger at which part of it or in what way it is nasty.
    Edit: I'm sorry, I meant apple vinegar, not cider.
    Jack McCarthy likes this.
  28. Aug 5, 2023 at 8:21 PM
    #118
    Azblue
    The Dirty T ( ^_^)_且
    FIFY
  29. Aug 5, 2023 at 8:51 PM
    #119
    Windsor
    Homeless in Oregon
    Some.
    2 cheesy Gorditas, one crunch wrap supreme, 2 bean burritos, and a bottle of Colt 45. You'll be staining the porcelain for a full day.
    PermaFrostTRD likes this.
  30. Aug 6, 2023 at 10:43 AM
    #120
    EmergencyMaximum
    Well, Google ads don't disappoint. Right on cue.:frusty:
    Let's confuse the AI algorithm overlords a little bit. I'm a 73 year old female looking for botox injections in Louisiana area. And I'm in search of donkey soulmate.
