  1. Aug 4, 2023 at 8:25 PM
    :facepalm:
  2. Aug 4, 2023 at 8:26 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Found it! Got it loaded up this evening. Haven’t really tested it out but it does seem smoother and more responsive. Thanks!!
    Tundra234[QUOTED] likes this.
  3. Aug 5, 2023 at 10:58 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    Accumulating parts for rear window switch relocation and future heated seat switches. The led bar switch is going to fill the factory rear window switch location.
    coTony, Jego, mgm16trdpro and 6 others like this.
  4. Aug 5, 2023 at 11:30 AM
    drpheta
    drpheta New Member
    Super White 2014 TRD Off-Road DC
    Drilled out the old busted OEM bump stop pins, tapped new threads, and installed Durobumps.
  5. Aug 5, 2023 at 2:38 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I borrowed a buddy's AC kit and topped off the refrigerant in the truck before heading to CA in a couple weeks as it just didn't feel like it was cold enough...Holy crap! She's almost too cold now! Haha absolutely incredible...I don't see any leaks and letting her sit for 30 min didn't degrade in pressure so I'm glad I did this...once the pressures were stabilized at 38psi on the low and 145psi on the high side, I quit it...used about 70grams of the refrigerant to get to the 648g of the oe setup...life is good...oh, and I finally threw in the 5.9A USB sockets in the rear of the center console...both jobs took about an hour to complete...
  6. Aug 5, 2023 at 3:49 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Replaced the little rubber base thing for the antenna since the old one dried up and crumbled off, and gave her a quick rinse.
  7. Aug 5, 2023 at 3:57 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    bumper looks sharp.
    Ryuu[QUOTED] likes this.
  8. Aug 5, 2023 at 4:28 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    -1 factory bs, +1 suspension flex
  9. Aug 5, 2023 at 4:45 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    thanks!
  10. Aug 5, 2023 at 4:56 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Got the baja SAE amber fogs in
  11. Aug 5, 2023 at 5:47 PM
    J&ATundra
    J&ATundra |-|/-\\/\//-\| |
    Texas but from Hawaii
    2018 Cement Toyota Tundra
    Lovin the look:101010:
    Ryuu[QUOTED] and Y0TA PR0 like this.
  12. Aug 5, 2023 at 6:02 PM
    drpheta
    drpheta New Member
    I need to do this.
    HulkSmurf14[QUOTED] likes this.
  13. Aug 5, 2023 at 6:30 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    thank you! :fistbump:
  14. Aug 5, 2023 at 9:21 PM
    MountainMan
    MountainMan New Member
    Idaho/Washington border
    2021 1794 Edition
    Bilstein 5100s, 285/70R17s, Tuff Country rear add-a-leaves, Rough Country rear bumper, Rough Country CAI, Dirty Deeds Ind. straight pipe kit, Ironman Raid front bumper, 13k lb. winch, Leer topper, custom rack, Decked bed drawer system, AuxBeam fogs, Midland CB radio.
    I installed my Decked system today. Not too bad, but fairly exhausting in high temps and high humidity. Turned out great and can't wait to get all my gear stowed and organized.
  15. Aug 5, 2023 at 9:45 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    Driving today and my fuel door just falls off. The actual metal disk shaped door, not the hinge assembly or the plastic that the metal attaches to. I’ll attach pic tomorrow, anybody know of a good replacement? I see many online but it appears that they fix themselves to the metal rather than the hinge?
  16. Aug 6, 2023 at 7:14 AM
    coTony
    Tony
    Montrose, CO
    Playing in a trail that unbeknownst to us had rain like they have not seen in years. Came to a lake where the trail went maybe a few feet from the lake bed and it was way over full. Just glad we got out of there with no damage or rubbing. Then going through pics I see this is the only one I have before we went in the muddy trail. Was not interested in pictures when it started getting to the point where it was getting to be a very tight trail of cut/fallen trees and more mud. Oh well, we had fun
  17. Aug 6, 2023 at 8:25 AM
    Skaufma0
    Skaufma0 Just a little stitious.
    Rock Hill, SC
    2018 MBM Limited CM
    Installed the Rough Country hard fold tonneau cover. Not a bad install. Anyone have a bulkhead seal recommendation for a line-x'd bed?
  18. Aug 6, 2023 at 9:04 AM
    AZBoatHauler
    So.Arizona
    Where’d you go?
  19. Aug 6, 2023 at 9:43 AM
    biebs96
    PA
    my buddy just flipped the peal and stick seal and attached it to the underside of the flap that hangs over top of the bulkhead.
    Still seals the same, just wouldn’t adhere to the line x.
  20. Aug 6, 2023 at 10:43 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Unfortunately bringing my Tundra to the dealership tomorrow after not finding a fix. Last Sunday, my car alarm randomly started going off and has been randomly going off ever since.
    I think (hope?) it's just a bad door sensor switch because it was good for a few days when I wasn't driving it and then came back after I opened the front/back driver's side door to go swimming on Friday. I've had the battery disconnected since.
    Really upset about this because I want to keep this truck for the next 30 years, and issues like this would be a deal breaker if it can't be resolved. Definitely getting an extended warranty now.
  21. Aug 6, 2023 at 11:19 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    2nd this ^^^ it's exactly what I did, and if I recall the instructions on my armorflex cover had mentioned it as well... I'm happy w/how it turned out!!! @Skaufma0
    Skaufma0 and biebs96[QUOTED] like this.
  22. Aug 6, 2023 at 12:28 PM
    Skaufma0
    Rock Hill, SC
    2018 MBM Limited CM
    Wow...I didn't even think of that. I'll have to probably order a new strip, thanks for the fix!
    Makes perfect sense. I can't believe I didn't see that that would work.
  23. Aug 6, 2023 at 12:53 PM
    Tripleconpanna
    It's all good, that's why this forum is here... well, that and to help you spend your money on $hit you really don't need for your truck... :D
    bulldog93 and Beach Toy like this.
  24. Aug 6, 2023 at 1:38 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Had to take the truck out and give it a good flex after puling the sway bar yesterday. Definitely happy with how it performs, now I need to address the rear. It never ceases to annoy me how lame the pictures look compared to how it feels in real life
    BR73, Wallygator, junior and 15 others like this.
  25. Aug 6, 2023 at 1:45 PM
    biebs96
    PA
    The
    you ain’t lying… Who knew I needed a roof rack and matching 35 under the bed
    mr0351, Skaufma0, Tundra234 and 2 others like this.
  26. Aug 6, 2023 at 3:04 PM
    SAGE63
    San Diego County
    check out the extended warranty thread great pricing from a couple of folks...
    bulldog93 and PomDad[QUOTED] like this.
  27. Aug 6, 2023 at 3:07 PM
    2020cement_tundra
    2020cement_tundra New Member
    SC
    2020 tundra
    Hey, did you have the same wheels as mine? If you did you paint them or what method to get them black? TIA67FDC9ED-557F-42DA-BE64-BF66F6592CF4.jpg
    mgm16trdpro and Cl8NL[QUOTED] like this.
  28. Aug 6, 2023 at 3:14 PM
    biebs96
    PA
    I could be wrong, but judging (not in a negative way) by everything being the same color black (center caps, wheel lugs, logo) @Cl8NL most likely went the plastidip route.
    Cl8NL likes this.
  29. Aug 6, 2023 at 3:26 PM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Thank you for the suggestion, but already done! I was just a bit on the fence if I wanted to buy it, but this will definitely tip me over to do that.
    SAGE63[QUOTED] likes this.
  30. Aug 6, 2023 at 3:58 PM
    Look into getting them powdercoated. That will be the best for longevity.
