Front diff bushing?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Mission Critical, Aug 5, 2023.
  1. Aug 5, 2023 at 10:13 AM
    Mission Critical
    Mission Critical [OP] New Member
    2014 TRD
    I was changing the oil for the first time on my 2014 Tundra. Noticed that the bushing pictured on the passenger side was loose and hanging a half inch low. The driver side was tight.
    Is this a front dif bushing? If not what is it and how do I fix it?20230805_094528.jpg 20230805_094538.jpg
  2. Aug 5, 2023 at 11:27 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Yes, it is a mount for your front diff. Have you tried tightening it? I’d probably take it out and put some red loctite on it first.
    TG705 and reywcms like this.
  3. Aug 5, 2023 at 12:32 PM
    TG705
    TG705 Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    What @Cruzer said, there's a nut on the top side that just needs to be tightened. There's not a whole lot of space up there, box wench is your best bet.
  4. Aug 5, 2023 at 2:14 PM
    Mission Critical
    2014 TRD
    I did try to tighten it. It didn't seem to be catching on anything and just spun...
    I will try to feel around up there and see if the nut is sitting up there..
