Does this look like an oil leak? 2020 SR5
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1970CST/10, Aug 4, 2023.
  1. Aug 4, 2023 at 10:43 AM
    1970CST/10
    1970CST/10 [OP] New Member
    Shea
    Van Buren, AR
    2020 Black SR5 CrewMax
    Hey guys need some advice. Popped the hood the other day to jump someone at the gas station. I noticed what looked to me like oil on driver side valve cover.
    The truck only has 31k miles and has had all service done at the dealership. I called and scheduled an appointment just got a call back a while ago saying this isn’t oil, and furthermore it’s physically impossible for oil to leak at the top of a valve cover.
    I’m definitely no mechanic so I just wanted to get a few more opinions on this while it’s still under warranty before I just lay down and accept their answer.
    I also had them look at my dash, which looks like a washboard with all the waves in it. And they said well we looked at another one on the lot that looks similar so they’re declining warranting that issue as well. This is my first Toyota and I love it but they were super snappy and basically said there isn’t anything else to discuss, come and get your vehicle.
  2. Aug 4, 2023 at 10:53 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    someone spill oil on top, just wipe it off
  3. Aug 4, 2023 at 11:04 AM
    1970CST/10
    Shea
    Van Buren, AR
    Thanks, I asked him that and he said no thats not possible either. He said if they’d spilled oil during the last oil change it would’ve been burned off by now and that I would’ve seen it smoking or smelled it.
  4. Aug 4, 2023 at 11:14 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    If that's the top of the valve cover, that looks like a spill and not a leak. They also don't get hot enough to burn oil off, which is literally why you notice any legitimate oil leaks in the first place. Your dealer is definitely blowing you off, but I would clean it off w/ brake clean and keep an eye on it to see if it returns. Document with timestamped pictures and if it comes back press the dealer again.
    Do you have any pictures of the wavy dashboard?
    Leo's first likes this.
  5. Aug 4, 2023 at 11:19 AM
    yakeng
    yakeng 3URFE Apologist
    Being it is the drivers side, I’d say it’s more than likely spilled oil or a funnel was placed there. BTDT
    I’d wipe it down with a shop towel and just monitor it if you are concerned.
  6. Aug 4, 2023 at 11:22 AM
    1970CST/10
    Shea
    Van Buren, AR
    Thanks, I appreciate the advice. No I do not but I’ll get some this evening when I pick it up. When I noticed it I came on here and sure enough there are several threads with the same issue on the dashboard.
    Sounds like it’s pretty much at the dealer’s discretion on whether they’ll fix it or not. If I recall, one of the threads id seen where the dealer had fixed it it was basically an install issue from the factory is what he was told.
    Even the service guy came out and looked at it this morning and said wow that’s terrible and will probably continue to get worse.
    I know it’s a cosmetic issue but it is aggravating that their out was oh well we have another one here that looks like that so we’re not going to do anything about it. These are literally the first issues I’ve taken my truck in for, not like ive nit picked it to death.
    Leo's first and Tbrandt[QUOTED] like this.
  7. Aug 4, 2023 at 2:24 PM
    1970CST/10
    Shea
    Van Buren, AR
    Here are the pictures of the dashboard.
  8. Aug 4, 2023 at 5:09 PM
    Tbrandt
    Tristan
    Kansas City
    Mine looks pretty much the same. It’s unfortunately common on these trucks.16DB9E49-2F0C-4ED0-99E4-5F8B15F5B1EA.jpg
  9. Aug 5, 2023 at 2:08 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Mine looks the same. Not sure I want a dealership tearing apart the entire dash for something I rarely notice. May cause more problems than you currently have if they don’t put everything back together just right
    Leo's first and DRiedel like this.
  10. Aug 5, 2023 at 1:52 PM
    bfunke
    bfunke Tundra Curmudgeon
    Get a rag and some throttle body clear and spray that area while hold the rag there to clean the oil. If it recurs buy a new bolt from Toyota. These bolts have an integrated washer and rubber seal that get hard which is why many note there bolts are loose.
